I would like to have an accurate estimate of altitude and i'm not sure how to go about it. I would love some guidance please!
Sensors: GY63 Pressure (and temp), GY521 6-axis Accel ( but also use 9axis MPU9250/ )
I know a Kalman filter is required, and there are press/temp kalman libraries out there :
, But are there any to include acceleration? Or, how do i go about adding the third state? I need the third state for accuracy, and if im going to learn this, i may as well go the whole hog!
Model rocket. So i need a good estimation of peak altitude. Everything i have read says use three states to improve accuracy. Ideally id like to get to sub 0.5m, with 0.1-0.3 being awesome.
Thanks- Id seen the first article but not the second. Ill read it later. I have my own main program for doing other things on this rocket ( thrust vectoring etc.) so i'm really hoping to build a stand alone function that does the altitude stuff. The Shultz program is written for C or something non Arduino/teensy. Id really like something arduino based.
The programming language for Arduino is C/C++, so no problem. You will need to split main() into setup() and loop() and change the file/print statements.
