What is the significance of that number?
That is just a randomly chosen number, could be any four digit number. Read the boot message if you like:
Serial.println(F("Pin 16 is used for communications, Pin 17 for forwading incoming communications, Pin 4 is outputting the PWM and Pin 2 is reading a analog voltage."));
Serial.println(F("Not every character was coded. More characters, words or direct function recognization can be added with a change in code."));
Serial.println(F("Always use TABS for message letter input as seen below. The currently coded characters are:"));
Serial.println(F("A, B, C, D, E, F, G, H, I, J, K, L, M, N, O, P, Q, R, S, T, U, V, W, -, ., , ?, -, =, :, 0, 1, 2, 3, 4, 5, 6, 7, 8, 9"));
Serial.println(F("Four digit function values or fourteen digit time-codes (YYYYMMDDHHMMSS) are detected inside the message automatically when using the following formats: FUNCTIONVALUE=, TIMECODE=, BYTE="));
Serial.println(F("The function values can be triggered at any time by inputting 'f' or by inputting 't' and then a fourteen digit time-codes (YYYYMMDDHHMMSS) through the serial monitor, they are then initiated and transmitted."));
Serial.println(F("With added coded one can call and transmit function values or time-codes automatically at specific events. Or add things like an NTP retrieval, RTCs or RF transmissions"));
Serial.println(F("Currently the following standard functions values are programmed and can be called..."));
Serial.println(F("Everything between 0000-5000 is reserved for a voltage, 6001-6999 sets the PWM output frequency in kHz, 7001-7100 sets the PWM duty-cycle, 7101 starts PWM, 7102 stops it, 7103 measures a voltage, 7104 sets the device voltage to 3.3V, 7105 sets it to 5V, 7107 starts foorwarding and 7106 stops forwarding."));
Serial.println(F("Finally: call a function value between 8001-9000 to update the maximum signal speed in microseconds on both the sending and receiving end. Call 9001 to retrieve the amount of messages send and received."));
