About I2C multi devices address init problem
Hi all.
The sketch below works well for dfrobot voice recognition module, with library:
Question is when I try to add another I2C device SSD1306, and respectively init them:
oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);
while (!(asr.begin(0x64)));
got compiling error of: no matching function for call to 'DFRobot_DF2301Q_I2C::begin(int)'
how to fix please.
Thanks
Adam
 * @file  i2c.ino
 * @brief Control the voice recognition module via I2C
 * @n  Get the recognized command ID and play the corresponding reply audio according to the ID;
 * @n  Get and set the wake-up state duration
 * @copyright  Copyright (c) 2010 DFRobot Co.Ltd (http://www.dfrobot.com)
 * @licence  The MIT License (MIT)
 * @author  [qsjhyy](yihuan.huang@dfrobot.com)
 * @version  V1.0
 * @date  2022-04-02
 * @url  https://github.com/DFRobot/DFRobot_DF2301Q
#include "DFRobot_DF2301Q.h"
#define Led 8
//I2C communication
DFRobot_DF2301Q_I2C asr;
  pinMode(Led, OUTPUT);    //Init LED pin to output mode
  digitalWrite(Led, LOW);  //Set LED pin to low
  // Init the sensor
  while (!(asr.begin())) {
    Serial.println("Communication with device failed, please check connection");
    delay(3000);
  Serial.println("Begin ok!");
   * @brief Set voice volume
   * @param voc - Volume value(1~7)
  asr.setVolume(4);
     @brief Set mute mode
     @param mode - Mute mode; set value 1: mute, 0: unmute
  asr.setMuteMode(0);
     @brief Set wake-up duration
     @param wakeTime - Wake-up duration (0-255)
  asr.setWakeTime(20);
     @brief Get wake-up duration
     @return The currently-set wake-up period
  uint8_t wakeTime = 0;
  wakeTime = asr.getWakeTime();
  Serial.print("wakeTime = ");
  Serial.println(wakeTime);
  // asr.playByCMDID(1);   // Wake-up command
     @brief Play the corresponding reply audio according to the ID
     @param CMDID - command word ID
  //asr.playByCMDID(23);  // Command word ID
     @brief Get the ID corresponding to the command word
     @return Return the obtained command word ID, returning 0 means no valid ID is obtained
  uint8_t CMDID = asr.getCMDID();
  switch (CMDID) {
    case 103:                                                  //If the command is “Turn on the light”
      digitalWrite(Led, HIGH);                                 //Turn on the LED
      Serial.println("received'Turn on the light',command flag'103'");  //Serial transmits "received"Turn on the light",command flag"103
    case 104:                                                  //If the command is “Turn off the light”
      digitalWrite(Led, LOW);                                  //Turn off the LED
      Serial.println("received'Turn off the light',command flag'104'");  //The serial transmits "received"Turn off the light",command flag"104""
    default:
      if (CMDID != 0) {
        Serial.print("CMDID = ");  //Printing command ID
        Serial.println(CMDID);
  delay(300);
ERROR:
Arduino: 1.8.19 (Windows 7), Board: "ESP32 Dev Module, Disabled, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Enabled"
C:\Users\HUA.DELLV-PC\Documents\Arduino\ESP32_DFRobot_AA2\ESP32_DFRobot_AA2.ino: In function 'void setup()':
ESP32_DFRobot_AA2:39:27: error: no matching function for call to 'DFRobot_DF2301Q_I2C::begin(int)'
    while (!(asr.begin(0x64))) {   // add address
In file included from C:\Users\HUA.DELLV-PC\Documents\Arduino\ESP32_DFRobot_AA2\ESP32_DFRobot_AA2.ino:21:
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\DFRobot_DF2301Q-master/DFRobot_DF2301Q.h:137:16: note: candidate: 'virtual bool DFRobot_DF2301Q_I2C::begin()'
   virtual bool begin(void);
C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\DFRobot_DF2301Q-master/DFRobot_DF2301Q.h:137:16: note:   candidate expects 0 arguments, 1 provided
exit status 1
option enabled in File -> Preferences.
In your example code the function begin
called without parameter.
Why did you try to call the function with parameter?
Thanks.
I try to add another I2C device OLED ssd1306, code doesn't run well without I2C address inserted.
The reason is something else.
Just because you don't explicitly indicate an address - doesn't mean the address doesn't exist. No i2c device can operate without an address, even if there is only one device on the bus. The library DFRobot_DF2301Q.h itself assigns the address to your module (and exactly 0x64, as you wanted to indicate)
Thank you.
I'll test them more.
the OLED and DFRobot works well individually now. stopped in setup as long as combined their code together.
Do you have a pullup resistors on SDA and SCL lines?
not yet, I'll set that and test.
