Adafruit Motor Shield stops Arduino Ethernet from connecting
Hi All,
I am using an Arduino Ethernet and Adafruit Motor shield V2 on a project to control the motors over ethernet.
I have managed to get the ethernet control aspect to work, interpretting GET requests etc. and I have been controlling the on-board LED successfully.
When I connect the motor shields (I am using 2) and add in the coding to control the motors the arduino fails to connect to acquire an ethernet connection.
I have checked pin-outs etc. The motor shield uses the SDA and SCL pins of the arduino (nearest the reset button) and the ethernet capability uses pins 10-13. The motor shield communicates over I2C whereas the ethernet uses the SPI bus.
Firstly is this all correct?
Secondly can anyone suggest why these functions aren't working together
Hard to say. None of your links worked.
Let me think. No links. No schematic. No code. No.
How is the arduino and motors being powered?
///////////////////WEB MOTOR CONTROL////////////////////
///////////////////LIBRARIES////////////////////
#include <SPI.h>
#include <Ethernet.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
///////////////////DEFINITIONS////////////////////
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ   15
///////////////////VARIABLES////////////////////
String get;
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
int motor_steps = 20;            // set motor steps
///////////////////ETHERNET STUFF////////////////////
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x0E, 0x10, 0x70 };
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetServer server(80);
///////////////////MOTOR STUFF////////////////////
Adafruit_MotorShield ShieldBot(0x61); // Rightmost jumper closed
Adafruit_MotorShield ShieldTop(0x60); // Default address, no jumpers
//Connect Motors
Adafruit_StepperMotor *pitch_motor = ShieldBot.getStepper(200, 1); //Attach pitch motor
Adafruit_StepperMotor *yaw_motor = ShieldBot.getStepper(200, 2); //Attach yaw motor
Adafruit_StepperMotor *roll_motor = ShieldTop.getStepper(200, 2); //Attach roll motor
///////////////////SETUP////////////////////
  pinMode(9,OUTPUT);
  // Open serial communications:
  Serial.println("Started");
  ///////////////ETHERNET///////////////////
  // Start the Ethernet connection:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    digitalWrite(9,LOW);
    // no point in carrying on, so do nothing forevermore:
    for(;;)
  // print your IP address:
  Serial.print("IP address: ");
  for (byte thisByte = 0; thisByte < 3; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
  Serial.println(Ethernet.localIP()[3], DEC);
  digitalWrite(9,HIGH);
  ////////////////////MOTORS//////////////////
  //Begin Motor shields:
  ShieldBot.begin(); // Start the bottom shield
  ShieldTop.begin(); // Start the top shield
  // Start stepper motors
  pitch_motor->setSpeed(10);
  yaw_motor->setSpeed(10);
  roll_motor->setSpeed(10);
Code won't all fit in one post, see next post for loop
///////////////////LOOP////////////////////
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
        String get = HTTP_req;
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
         strstr(HTTP_req," H")[0] = 0;
           Serial.println(HTTP_req);
            // send a standard http response header
            client.println("Content-Type: text/html");
            client.println("Connection: close");  // the connection will be closed after completion of the response
            client.println();
            ///////////////////HTML////////////////////
            // send page
            client.println("<!DOCTYPE HTML>");
            client.println("<html>");
            client.println("<head>");
            client.println("</head>");
            client.println("<body>");
            client.println(" <h1>");
            client.println("  Motor Control");
            client.println(" </h1>");
            client.println(" <p>");
            client.println("  Use the buttons below to adjust the motors.");
            client.println(" </p>");
            client.println("<table width='100%' border='0'>");
            client.println("<tr>");
            client.println(" <td>");
            client.println(" </td>");
            client.println(" <td align='center'>");
            client.println("  <a href='/?up'>");
            client.println("   <button style='width:100%'>");
            client.println("    <h2>");
            client.println("     Up");
            client.println("    </h2>");
            client.println("   </button>");
            client.println("  </a>");
            client.println("</tr>");
            client.println("  <a href='/?left'>");
            client.println("     Left");
            client.println("  <a href='/?right'>");
            client.println("     Right");
            client.println("  <a href='/?down'>");
            client.println("     Down");
            client.println("<tr style='height:20px'>");
            client.println("  <a href='/?ccw'>");
            client.println("     CCW");
            client.println("  <a href='/?cw'>");
            client.println("     CW");
            client.println("</table>");
            client.println("
            client.println("</body>");
            client.println("</html>");
            Serial.println("Page Sent");
        //check for button presses
       if (strstr(HTTP_req, "GET /?up")!=0){
         //What to do when button press detected
          pitch_motor->step(motor_steps, FORWARD, INTERLEAVE);
          Serial.println("Move: Up");
       else if (strstr(HTTP_req, "GET /?down")!=0){
          pitch_motor->step(motor_steps, BACKWARD, INTERLEAVE);
          Serial.println("Move: Down");
      else if (strstr(HTTP_req, "GET /?left")!=0){
          yaw_motor->step(motor_steps, FORWARD, INTERLEAVE);
          Serial.println("Move: Left");
       else if (strstr(HTTP_req, "GET /?right")!=0){
          yaw_motor->step(motor_steps, BACKWARD, INTERLEAVE);
          Serial.println("Move: Right");
       else if (strstr(HTTP_req, "GET /?ccw")!=0){
          roll_motor->step(motor_steps, FORWARD, INTERLEAVE);
          Serial.println("Move: CCW");
       else if (strstr(HTTP_req, "GET /?cw")!=0){
          roll_motor->step(motor_steps, BACKWARD, INTERLEAVE);
          Serial.println("Move: CW");
       else{
         Serial.println("no change");
            req_index = 0;
            get = "";
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
      } // end of if client available
    } // end of while client connected
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
} // end of loop
There were no links in my original post, I was asking if my assumptions were correct and whether anyone had any ideas why it might not be working in principle.
I have been using one motor to test the sketch and have been powering off USB.
Also, I have got the motor shields working using example sketches
I think zoomkat was implying you should not power the motor(s) with the same power supply as the Arduino, and certainly not from the 5v pin. Have you tried the ethernet connection if you remove the motor and leave the motor shields connected?
I think that was the point that PaulS, in his inimitable way, was trying to make.
I can't help- my first thought was power- but I'm curious about the physical setup. Have you got the shields actually plugged in as shields?- ie an Arduino/ Ethernet shield/ Motor shield / Motor shield Dagwood?
Good point about the uncertainty of stacking shields. "Motor shield Dagwood" reminds me of the current US burger commercials, roll the eyes back and unhinge the jaws!
