Adding Another Relay to the ESP32 Automatic Water Plant Control System
I am trying to add a second relay to my automatic plant watering system to use it for a second plant. The first relay is connected to volt 3, gnd and pin 5. The second relay is connected to volt 5, gnd and pin 27. The second relay wont work so I tried different combinations but none of them worked. If you have any suggestions for me, please let me know.
Here is my code:
#include <WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
// WiFi parameters
#define WLAN_SSID       "CommunityFibre10Gb_989A1"
#define WLAN_PASS       "m60qhnafv2"
// Adafruit IO
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    "ElectroMasterOP"
#define AIO_KEY         "aio_OuuD72fe69CKuZ7gvDMObSdTyf65"
WiFiClient client;
//Connects to output_value2 feed
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
Adafruit_MQTT_Publish OutPut_Value = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/OutPut_Value2");
Adafruit_MQTT_Publish OutPut_Value2 = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/OutPut_Value");
byte moisture;
//Creates variables for watering function.
const int relay = 5;
const int relay2 = 27;
const int sensor_pin = 32;
const int sensor_pin2 = 33;
const int led = 18;
int output_value;
int output_value2;
int switch_number;
//Creates statefunction and its cases.
enum State {
  INIT,
  CONNECT_WIFI,
  CONNECT_MQTT,
  READ_SENSOR,
  WATER_PLANT,
  WATER_PLANT2,
  RECHECK_1,
  PUBLISH_DATA
//Starts the statefunction up.
State currentState = INIT;
  Serial.begin(115200); //Connects to serial monitor
  Serial.println(F("Adafruit IO Example"));
  pinMode(led, OUTPUT);
  pinMode(relay, OUTPUT);
  digitalWrite(relay, LOW);
  switch (currentState) {
    case INIT:
      Serial.println(F("Initializing...")); //Initialization
      currentState = CONNECT_WIFI; //Next step start-off
      break;//Goes to next step
    case CONNECT_WIFI:
      //Connects to wifi using the parameters
      Serial.print(F("Connecting to WiFi: "));
      Serial.println(WLAN_SSID);
      WiFi.begin(WLAN_SSID, WLAN_PASS);
      //Checks for issues then reconnects if so.
        Serial.print(F("."));
      //Prints local IP/allows user to know its ready to go on.
      Serial.println(F("WiFi connected"));
      Serial.print(F("IP address: "));
      currentState = CONNECT_MQTT;//Next step start-off
      break;//Allowing to go to next step
    case CONNECT_MQTT:
      Serial.print(F("Connecting to Adafruit IO... "));
      //Connects to adafruit using AIO_KEY put in at the top.
      if (mqtt.connect() == 0) {
        Serial.println(F("Adafruit IO Connected!"));
        currentState = READ_SENSOR;//Next step start-off
        //Retrying because there were errors
        Serial.println(F("Connection failed, retrying..."));
        delay(10000);
    case READ_SENSOR:
      digitalWrite(relay, LOW);//Turns relay/pump off
      output_value = analogRead(sensor_pin);
      output_value = map(output_value, 550, 0, 0, 100);//Checks moisture
      output_value2 = analogRead(sensor_pin2);
      output_value2 = map(output_value2, 550, 0, 0, 100);//Checks moisture
      Serial.print("Moisture : ");//Printing value
      Serial.print(output_value);
      Serial.println("%");
      Serial.print("Moisture2 : ");//Printing value
      Serial.print(output_value2);
      delay(50);
      if (output_value <= -200) {
        currentState = WATER_PLANT;
        if (output_value2 <= -200) {
          currentState = WATER_PLANT2;//Next step start-off(forking off No.1)
          currentState = PUBLISH_DATA;//Next step start-off(forking off No.2)
      //      if (output_value2 <= -200) {
      //        currentState = WATER_PLANT2;//Next step start-off(forking off No.1)
      //      } else {
      //        currentState = PUBLISH_DATA;//Next step start-off(forking off No.2)
    case WATER_PLANT:
      //No.1
      digitalWrite(led, HIGH);
      digitalWrite(relay, HIGH);//Pump on/Water pouring
      Serial.println("Current Flowing");
      delay(1250);//Water pours for 1250ms
      digitalWrite(relay, LOW);//Pump off.
      Serial.println("Pouring stopped");
      digitalWrite(led, LOW);
      currentState = RECHECK_1;//Next step start-off(No.2)
    case WATER_PLANT2:
      //No.1
      digitalWrite(relay2, HIGH);//Pump on/Water pouring
      digitalWrite(relay2, LOW);//Pump off.
      currentState = PUBLISH_DATA;//Next step start-off(No.2)
    case RECHECK_1:
    case PUBLISH_DATA:
      //No.2
      //Connect to adafruit.
      if (!mqtt.ping(3)) {
        // Reconnect to Adafruit IO
        if (!mqtt.connected()) {
      //Print on serial monitor and puts output_value+700 in the output_value2 feed to be plotted into a graph
      Serial.print("Output Value: ");
      Serial.println(output_value);
      moisture = output_value + 700;
      if (!OutPut_Value.publish(output_value + 700)) {
        //Fails data send/retrys
        Serial.println(F("Failed to send data"));
      if (!OutPut_Value2.publish(output_value2 + 700)) {
        Serial.println(F("Data sent!"));
        Serial.println("--------------------------");
      delay(5000);
      currentState = READ_SENSOR;//Loops again from reading sensor
      break;//Allowing to go to start of loop.
Perhaps a pinMode for relay2 ?
Thanks
If @anon85221860 solved your problem mark it closed.
It's not finished yet though. Everything was working perfectly until I put it in the final position. I didn't change the code and i just added an attachment to the wires. I think it is the circuit, what do u think.
Now muting.
What do you mean by that.
