I want to order some 28BYJ-48 Stepper Motors for general projects. i noticed they have 5V and 12v. If anyone has used both, can you advice which is better, or what the operational differences are.
I'll be using these with a Nano. I realize 5v is simpler since the Nano uses 5v, but I have no problem supplying 12v either. Is it worth spending more for the 12v?
You can run a 5V 28BYJ motor as a bipolar 12V motor, by severing the center tap. That allows you to use standard bipolar motor drivers, and also increases the available torque and power.
In fact, it works just fine to ignore the center tap and not bother with the modification, but the purists might object.
