After setup function my code doesn't execute and the loop() don't start.
After setup function my code doesn't execute and the loop() don't start :confused: :confused: :confused: :confused: . Thanks In Advance.
Here is my code with which i have tried:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
//#include <Fonts/FreeMonoBoldOblique12pt7b.h>
//#include <Fonts/FreeSerif9pt7b.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH 16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ B00000000, B11000000,
B00000001, B11000000,
B00000011, B11100000,
B11110011, B11100000,
B11111110, B11111000,
B01111110, B11111111,
B00110011, B10011111,
B00011111, B11111100,
B00001101, B01110000,
B00011011, B10100000,
B00111111, B11100000,
B00111111, B11110000,
B01111100, B11110000,
B01110000, B01110000,
B00000000, B00110000
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64)
// init done
// Show image buffer on the display hardware.
// Since the buffer is intialized with an Adafruit splashscreen
// internally, this will display the splashscreen.
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(10, 0);
display.clearDisplay();
display.println("Welcome TO Access Control System");
display.display();
delay(2000);
// invert the display
display.invertDisplay(true);
display.invertDisplay(false);
// draw a bitmap icon and 'animate' movement
while (1) {
display.println("Welcome To Access Control System");
printText();
void printText(void) {
String s, p1, pc;
if (Serial.available())
display.println("Input Your Password:");
s = Serial.readString(); //getting string input in variable "s"
display.println("Type Again:");
pc = Serial.readString();
p1 = s;
if (p1 == pc) {
display.println("Password Matched...");
display.println("\n");
display.println("Confirm?");
display.println("Continue?");
char ch;
ch = Serial.read();
if (ch == 'y') {
p1 = s;
if (p1 == s) {
display.println("Accesses Granted Please Poceed");
while (1) {
display.println("input:");
printText();
if(ch == 'n') {
display.println("TRY AGAIN!!! THANK YOU");
// display.println(s);
display.display();
delay(1);
looks like it gets stuck in your infinite loops
while (1) {
The main loop will do this anyway, so whack that one for sure. Any other place this exists without a way to exit the loop is probably an error.
Are you waiting for it to display "Input Your Password:"? You have to send it your password first.
Also, please read Nick Gammon's post at the top of this Forum on how to use this Forum, especially the use of code tags when posting source code.
