:Project:Allarm_Clock
:Author: Tiziano Bianchettin
:Date: 10/02/2017
:Revision: 2
:License: Public Domain
thanks to:
http://arduinoenonsolo.blogspot.it/2012/12/orologio-con-arduino-e-il-ds1307.html
http://www.mauroalfieri.it/
http://www.danielealberti.it/
http://www.maffucci.it/
My electronics laboratory professor "Perito Carli"
//************libraries**************//
#include <Wire.h>
#include <RTClib.h>
LiquidCrystal_I2C lcd(0x27,20,4); // Display I2C 20 x 4
RTC_DS1307 RTC;
//************Button*****************//
int P1=6; // Button SET MENU'
int P2=7; // Button +
int P3=8; // Button -
int P4=9; // SWITCH Alarm
//**************Alarm***************//
#define LED 13
#define buzzer 10
//************Variables**************//
int hourupg;
int minupg;
int yearupg;
int monthupg;
int dayupg;
int menu =0;
int setAll =0;
uint8_t alarmHours = 0, alarmMinutes = 0; // Holds the current alarm time
lcd.backlight();
lcd.clear();
pinMode(P1,INPUT_PULLUP); // https://www.arduino.cc/en/Tutorial/InputPullupSerial
pinMode(P2,INPUT_PULLUP);
pinMode(P3,INPUT_PULLUP);
pinMode(P4,INPUT_PULLUP);
pinMode(LED,OUTPUT);
pinMode(buzzer, OUTPUT); // Set buzzer as an output
printAllOff();
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// Set the date and time at compile time
RTC.adjust(DateTime(F(5/20/2021), F(7:54)));
// RTC.adjust(DateTime(__DATE__, __TIME__)); //removing "//" to adjust the time
// The default display shows the date and time
int menu=0;
// check if you press the SET button and increase the menu index
if(digitalRead(P1)== LOW)
menu=menu+1;
if((digitalRead(P2)== LOW)&&(digitalRead(P3)== LOW))
DisplaySetHourAll();
DisplaySetMinuteAll();
lcd.clear();
lcd.setCursor(5,0);
lcd.print("ALARM");
lcd.setCursor(5,1);
lcd.print(alarmHours, DEC);
lcd.print(":");
lcd.print(alarmMinutes, DEC);
lcd.clear();
// in which subroutine should we go?
if (menu==0)
DisplayDateTime(); // void DisplayDateTime
Alarm(); // Alarm control
if (menu==1)
DisplaySetHour();
if (menu==2)
DisplaySetMinute();
if (menu==3)
DisplaySetYear();
if (menu==4)
DisplaySetMonth();
if (menu==5)
DisplaySetDay();
if (menu==6)
StoreAgg();
menu=0;
delay(100);
void DisplayDateTime ()
// We show the current date and time
DateTime now = RTC.now();
lcd.setCursor(0, 2);
lcd.print("Hour : ");
if (now.hour()<=9)
lcd.print("0");
lcd.print(now.hour(), DEC);
hourupg=now.hour();
lcd.print(":");
if (now.minute()<=9)
lcd.print("0");
lcd.print(now.minute(), DEC);
minupg=now.minute();
lcd.print(":");
if (now.second()<=9)
lcd.print("0");
lcd.print(now.second(), DEC);
lcd.setCursor(0, 1);
lcd.print("Date : ");
if (now.day()<=9)
lcd.print("0");
lcd.print(now.day(), DEC);
dayupg=now.day();
lcd.print("/");
if (now.month()<=9)
lcd.print("0");
lcd.print(now.month(), DEC);
monthupg=now.month();
lcd.print("/");
lcd.print(now.year(), DEC);
yearupg=now.year();
char DOW[][10]={"Sunday ","Monday ","Tuesday ","Wednesday","Thursday ","Friday ","Saturday "};
lcd.setCursor(0, 0);
lcd.print("Day : ");
lcd.print(DOW[now.dayOfTheWeek()]); // if it appears error in the code, enter the code given below
//lcd.print(DOW[now.dayOfWeek()]);
void DisplaySetHour()
// time setting
lcd.clear();
if(digitalRead(P2)==LOW)
if(hourupg==23)
hourupg=0;
hourupg=hourupg+1;
if(digitalRead(P3)==LOW)
if(hourupg==0)
hourupg=23;
hourupg=hourupg-1;
lcd.setCursor(0,0);
lcd.print("Set time:");
lcd.setCursor(0,1);
lcd.print(hourupg,DEC);
delay(200);
void DisplaySetMinute()
// Setting the minutes
lcd.clear();
if (minupg==59)
minupg=0;
minupg=minupg+1;
if (minupg==0)
minupg=59;
minupg=minupg-1;
lcd.setCursor(0,0);
lcd.print("Set Minutes:");
lcd.setCursor(0,1);
lcd.print(minupg,DEC);
delay(200);
void DisplaySetYear()
// setting the year
lcd.clear();
yearupg=yearupg+1;
yearupg=yearupg-1;
lcd.setCursor(0,0);
lcd.print("Set Year:");
lcd.setCursor(0,1);
lcd.print(yearupg,DEC);
delay(200);
void DisplaySetMonth()
// Setting the month
lcd.clear();
if (monthupg==12)
monthupg=1;
monthupg=monthupg+1;
if (monthupg==1)
monthupg=12;
monthupg=monthupg-1;
lcd.setCursor(0,0);
lcd.print("Set Month:");
lcd.setCursor(0,1);
lcd.print(monthupg,DEC);
delay(200);
void DisplaySetDay()
// Setting the day
lcd.clear();
if (dayupg==31)
dayupg=1;
dayupg=dayupg+1;
if (dayupg==1)
dayupg=31;
dayupg=dayupg-1;
lcd.setCursor(0,0);
lcd.print("Set Day:");
lcd.setCursor(0,1);
lcd.print(dayupg,DEC);
delay(200);
void StoreAgg()
// Variable saving
lcd.clear();
lcd.setCursor(0,0);
lcd.print("SAVING IN");
lcd.setCursor(0,1);
lcd.print("PROGRESS");
RTC.adjust(DateTime(yearupg,monthupg,dayupg,hourupg,minupg,0));
delay(200);
void DisplaySetHourAll()// Setting the alarm minutes
while(digitalRead(P1)==HIGH){
lcd.clear();
if(alarmHours==23)
alarmHours=0;
alarmHours=alarmHours+1;
if(alarmHours==0)
alarmHours=23;
alarmHours=alarmHours-1;
lcd.setCursor(0,0);
lcd.print("Set HOUR Alarm:");
lcd.setCursor(0,1);
lcd.print(alarmHours,DEC);
delay(200);
delay(200);
void DisplaySetMinuteAll()// Setting the alarm minutes
lcd.clear();
if (alarmMinutes==59)
alarmMinutes=0;
alarmMinutes=alarmMinutes+1;
if (alarmMinutes==0)
alarmMinutes=59;
alarmMinutes=alarmMinutes-1;
lcd.setCursor(0,0);
lcd.print("Set MIN. Alarm:");
lcd.setCursor(0,1);
lcd.print(alarmMinutes,DEC);
delay(200);
delay(200);
void printAllOn(){
lcd.setCursor(0,3);
lcd.print("Alarm: ");
if (alarmHours <= 9)
lcd.print("0");
lcd.print(":");
if (alarmMinutes <= 9)
lcd.print("0");
void printAllOff() {
lcd.setCursor(0, 3);
lcd.print("Alarm: Off ");
void Alarm(){
if(digitalRead(P4)== LOW)
setAll=setAll+1;
if (setAll==0)
printAllOff();
noTone (buzzer);
digitalWrite(LED,LOW);
if (setAll==1)
printAllOn();
if ( now.hour() == alarmHours && now.minute() == alarmMinutes )
lcd.noBacklight();
digitalWrite(LED,HIGH);
tone(buzzer,880); //play the note "A5" (LA5)
delay (300);
tone(buzzer,698); //play the note "F6" (FA5)
lcd.backlight();
else{
noTone (buzzer);
if (setAll==2)
setAll=0;
delay(200);
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
from sketch\current_attempt_at_alarm_clock.ino.cpp:1:
C:\Users\21nmcrane\Documents\Arduino\current_attempt_at_alarm_clock\current_attempt_at_alarm_clock.ino: In function 'void setup()':
current_attempt_at_alarm_clock:68:31: error: initializer fails to determine size of '__c'
C:\Users\21nmcrane\Documents\Arduino\current_attempt_at_alarm_clock\current_attempt_at_alarm_clock.ino:68:25: note: in expansion of macro 'F'
current_attempt_at_alarm_clock:68:31: error: array must be initialized with a brace-enclosed initializer
current_attempt_at_alarm_clock:68:42: error: expected ')' before ':' token
C:\Users\21nmcrane\Documents\Arduino\current_attempt_at_alarm_clock\current_attempt_at_alarm_clock.ino:68:39: note: in expansion of macro 'F'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WString.h:38:74: error: initializer fails to determine size of '__c'
#define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/WString.h:38:74: error: array must be initialized with a brace-enclosed initializer
exit status 1
option enabled in File -> Preferences.
