Guys
Loking for advice please
Iam getting a compilation error : AltSoftSerial.h: No such file or directory
I have checked the library directory in Arduinoin and AltSoftSerial is listed under libraries.
any help would be appreciated.
I am using Arduino Nano and HM-10
Guys
Thanks for the prompt repliies.
The path is as follows C:\Onedrive\name-Personel\Documents\Arduino\Libraries
Arduino is in the documents Library and AltSoftSerial is in the library directory of Arduino
click on Documents > Arduino>Libraries>AltSoftSerial
hope this makes sense>
Thanks oldguyjn
I am still confused as to what you are saying but it sounds like you have a folder named AltSoftSerial in the C:\Onedrive\name-Personel\Documents\Arduino\Libraries folder. If so, what is in that folder ?
I note that your Sketchbook folder is in the Onedrive folder. I have previously seen reports that this can cause problems, but I am not clear as to what causes it and whether it always causes problems
I am going to try and by bypass one drive and install Arduino directly onto the harddrive when I click on Documents I then click on the Arduino folder and this opens the library folder which is where AltSoftSerial is located
Thanks again for replying to my posts.
oldguyjn
