Compilation error: library_name.h: No such file or directory I get this and this D6
I have search reloaded ever Library
Your message is not very informative.
Please read a sticked topic "How to get the best out of the forum"
I have deleted your other cross-post @mstrunk4.
Cross-posting is against the Arduino Forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Were you planning to post your code using proper code tags? Less your code I don’t see a resolution.
Ron
Hi @mstrunk4. I'm going to ask you to provide the full verbose output from a compilation.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
<CODE/> icon on the post composer toolbar.```) to your reply to make sure the error messages are correctly formatted.In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here.
.txt format..txt file you saved from the "Open" dialog.Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
Do you want to copy the code and send it ?
marquee.ino (66.1 KB)
