HI,
I've follow this video tutorial about my setup :
I follow everything but it's now perfect because i have two issue.
Some flickering happear on the LEDs, i just read that maybe it's the 470 Ohm resistor can help. I will try that but my main problem are these : (see attachment)
I have more Led on the Left Side than the right side;
Due to my monitor configuration, i have 25 leds into the left side, and 23 on the right side. Bottom and top have a total of 41 each, which results by 130 leds in my project.
I have no way to balance that in the Arduino project and also in AmbiBox.
Here are the code of the arduino project :
#include <bitswap.h>
#include <chipsets.h>
#include <color.h>
#include <colorpalettes.h>
#include <colorutils.h>
#include <controller.h>
#include <cpp_compat.h>
#include <dmx.h>
#include <FastLED.h>
#include <fastled_config.h>
#include <fastled_delay.h>
#include <fastled_progmem.h>
#include <fastpin.h>
#include <fastspi.h>
#include <fastspi_bitbang.h>
#include <fastspi_dma.h>
#include <fastspi_nop.h>
#include <fastspi_ref.h>
#include <fastspi_types.h>
#include <hsv2rgb.h>
#include <led_sysdefs.h>
#include <lib8tion.h>
#include <noise.h>
#include <pixelset.h>
#include <pixeltypes.h>
#include <platforms.h>
#include <power_mgt.h>
#define NUM_LEDS 130 // Nombre de LEDs de votre projet
#define DATA_PIN 5 // Pin utilisé pour la gestion de la bande de led
#define BRIGHTNESS 96 // Luminosité max
#define SPEED 1000000 // Vitesse de transmission
uint8_t prefix[] = {'A', 'd', 'a'}, hi, lo, chk, i;
CRGB leds[NUM_LEDS];
// pinMode(GROUND_PIN, OUTPUT);
// digitalWrite(GROUND_PIN, LOW);
FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
//FastLED.addLeds<APA102, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
//FastLED.addLeds<WS2801, RGB>(leds, NUM_LEDS);
FastLED.setCorrection(TypicalSMD5050);
Serial.begin(SPEED);
Serial.print("Ada\n"); // Send "Magic Word" string to host
// wait for first byte of Magic Word
for(i = 0; i < sizeof prefix; ++i) {
waitLoop:
while (!Serial.available());
if (prefix[i] == Serial.read()) continue;
i = 0;
goto waitLoop;
// Hi, Lo, Checksum
hi = Serial.read();
lo = Serial.read();
chk = Serial.read();
// if checksum does not match go back to wait
if (chk != (hi ^ lo ^ 0x55)) {
i = 0;
goto waitLoop;
Serial.readBytes((char*)leds, NUM_LEDS*3);
// shows new values
FastLED.show();
Also, the speed and color seem's to not really perfectly match what i've on screen.
I don't know how to resolve the LED configurations and also the flickering issue.
Thanks for help.
