I am very new to arduino world, fairly new to programming, have practiced with Visual Studio before taking up the Arduino IDE 1.6.3
With various sketches I will get a “Visual Studio Just-IN-Time Debugger” window claiming “An unhandeld win 32 exception occurred in ID.exe [various numbers]”
Seems to be associated with serial print statements although sometimes just commenting out code or moving it around stops the problem.
When I say No to “Do you want to debug…” the arduino compiler will finish up, sometimes I can load the code and it works?
Most of the time it fails
"Arduino: 1.6.3 (Windows XP), Board: “Arduino Uno”
collect2.exe: error: ld returned 5 exit status
Error compiling.
“Show verbose output during compilation”
enabled in File > Preferences.
what’s going on, is this a visual studio false alarm sometimes?
Often I am dead in the water!
More info May 8
I disabled just in time debug in the registry
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger
now I get the usual “window application needs to close” but sketches that used to continue to compile now fail
the messaes from the Arduio IDE are attached
what the hey?
messages without debugger.txt (4.12 KB)
messages with debugger.txt (4.7 KB)
