been looking for tutorials on this - (i just finished soldering it altogether and i want to use it),but none really to be found..
thanks in advance
k,, ty.. but also looking how to hook up the outer pins to the arduino..
Never used one but from the code, I saw this:
int dataIn = 2;
int load = 3;
int clock = 4;
and on the left of your picture are the connections:
DIN
CS
CLK
so I think they match up like this:
int dataIn = 2; //DIN
int load = 3; //CS
int clock = 4; //CLK
but there are 10 pins.. only 3 to make this work?
Ruffsta:
Looks that way. Check out the link to the tutorial in the code that pyro_65 linked to. It'll be 5 of course though since you'll need vcc and ground.
3 are already mentioned. The other 2 are Gnd and Vcc, not much imagination required here.
The other 5 pins are the same and they are the output side (DOUT is the opposite of DIN). These modules can be daisy chained. If you wanted to add the second or more modules you connect the 'output' of one board to the 'input' of another.
k, ty
code doesn't work..
int dataIn = 2;
int load = 3;
int clock = 4;
int maxInUse = 1; //change this variable to set how many MAX7219's you'll use
int e = 0; // just a varialble
// define max7219 registers
byte max7219_reg_noop = 0x00;
byte max7219_reg_digit0 = 0x01;
byte max7219_reg_digit1 = 0x02;
byte max7219_reg_digit2 = 0x03;
byte max7219_reg_digit3 = 0x04;
byte max7219_reg_digit4 = 0x05;
byte max7219_reg_digit5 = 0x06;
byte max7219_reg_digit6 = 0x07;
byte max7219_reg_digit7 = 0x08;
byte max7219_reg_decodeMode = 0x09;
byte max7219_reg_intensity = 0x0a;
byte max7219_reg_scanLimit = 0x0b;
byte max7219_reg_shutdown = 0x0c;
byte max7219_reg_displayTest = 0x0f;
void putByte(byte data) {
byte i = 8;
byte mask;
while(i > 0) {
mask = 0x01 << (i - 1); // get bitmask
digitalWrite( clock, LOW); // tick
if (data & mask){ // choose bit
digitalWrite(dataIn, HIGH);// send 1
}else{
digitalWrite(dataIn, LOW); // send 0
digitalWrite(clock, HIGH); // tock
--i; // move to lesser bit
void maxSingle( byte reg, byte col) {
//maxSingle is the "easy" function to use for a //single max7219
digitalWrite(load, LOW); // begin
putByte(reg); // specify register
putByte(col);//((data & 0x01) * 256) + data >> 1); // put data
digitalWrite(load, LOW); // and load da shit
digitalWrite(load,HIGH);
void maxAll (byte reg, byte col) { // initialize all MAX7219's in the system
int c = 0;
for ( c =1; c<= maxInUse; c++) {
void maxOne(byte maxNr, byte reg, byte col) {
//maxOne is for adressing different MAX7219's,
//whilele having a couple of them cascaded
int c = 0;
for ( c = maxInUse; c > maxNr; c--) {
putByte(0); // means no operation
for ( c =maxNr-1; c >= 1; c--) {
void setup () {
pinMode(dataIn, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(load, OUTPUT);
beginSerial(9600); //------------------------------------first error, this is not defined
digitalWrite(13, HIGH);
//initiation of the max 7219
maxAll(max7219_reg_scanLimit, 0x07);
maxAll(max7219_reg_decodeMode, 0x00); // using an led matrix (not digits)
maxAll(max7219_reg_shutdown, 0x01); // not in shutdown mode
maxAll(max7219_reg_displayTest, 0x00); // no display test
for (e=1; e<=8; e++) { // empty registers, turn all LEDs off
maxAll(e,0);
maxAll(max7219_reg_intensity, 0x0f & 0x0f); // the first 0x0f is the value you can set
// range: 0x00 to 0x0f
void loop () {
//if you use just one MAX7219 it should look like this
maxSingle(1,1); // + - - - - - - -
maxSingle(2,2); // - + - - - - - -
maxSingle(3,4); // - - + - - - - -
maxSingle(4,8); // - - - + - - - -
maxSingle(5,16); // - - - - + - - -
maxSingle(6,32); // - - - - - + - -
maxSingle(7,64); // - - - - - - + -
maxSingle(8,128); // - - - - - - - +
delay(2000);
Time to get your scope out.
let me use yours so i can see what you see..
this code works.. just need to switch pins on the arduino to 8,9 and 10
unsigned char i;
unsigned char j;
/*port definition*/
int Max7219_pinCLK = 10;
int Max7219_pinCS = 9;
int Max7219_pinDIN = 8;
unsigned char disp1[38][8]={
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
{0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
{0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
{0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B
{0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C
{0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E
{0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F
{0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G
{0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H
{0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I
{0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J
{0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K
{0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L
{0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M
{0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O
{0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P
{0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q
{0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R
{0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S
{0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T
{0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
{0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V
{0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W
{0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
{0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y
{0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z
{0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//Chinese character
{0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//Chinese character
void Write_Max7219_byte(unsigned char DATA)
unsigned char i;
digitalWrite(Max7219_pinCS,LOW);
for(i=8;i>=1;i--)
digitalWrite(Max7219_pinCLK,LOW);
digitalWrite(Max7219_pinDIN,DATA&0x80);//Obtain the MSB of the data
DATA = DATA<<1;
digitalWrite(Max7219_pinCLK,HIGH);
void Write_Max7219(unsigned char address,unsigned char dat)
Write_Max7219_byte(address); //
Write_Max7219_byte(dat); //
digitalWrite(Max7219_pinCS,HIGH);
void Init_MAX7219(void)
Write_Max7219(0x09, 0x00); //decode: BCD
Write_Max7219(0x0a, 0x03); //Brightness
Write_Max7219(0x0b, 0x07); //
Write_Max7219(0x0c, 0x01); //
Write_Max7219(0x0f, 0x00); //
pinMode(Max7219_pinCLK,OUTPUT);
pinMode(Max7219_pinCS,OUTPUT);
pinMode(Max7219_pinDIN,OUTPUT);
delay(50);
Init_MAX7219();
for(j=0;j<38;j++)
for(i=1;i<9;i++)
Write_Max7219(i,disp1[j][i-1]);
k, what i don't get in this code.. is:
trying to make sense of it..
you can the code here: http://www.linksprite.com/download/showdownload.php?lang=en&id=223
or
here (takes you to the same exact same place): http://www.linksprite.com/upload/file/1347631413.txt
Moderator edit: Tags corrected
They're bit patterns, for your dot-matrix display.
Eight bytes per character, each byte with eight bits.
At the moment, they're consuming precious RAM - they might be better placed in PROGMEM.
again, i'm new.. so.. i'm at a loss here..
sorry, but i don't know how to do that yet or how to modify the code to do such..
i just got this for him and he soldered it all up - (since i have soldered for years, i taught him how to and he does exceptionally well).. so the coding is not what we are used to.
i thought getting this thing - (the arduino and such), for my son was going to be fun.. something we could do together as a father/son time thing, but in the end - it's more confusing than anything. starting to wonder why i even bothered getting him this even tho he's into building and coding stuff, but i think this may be just too much for him at 13 - i know it is for me at 39...
Never underestimate a 13 year old when it comes to computer technology ...
Did you start wih easier stuff like the LED blinker and reading an analog input? I find it is good to get the basics right and build on that.
is there a way to control each led in the matrix individually or a better way to display what we want it to display vs bit patterns?
I only said they "might" be better in PROGMEM - I don't know what else you have in mind to do with this device.
If you were going to build some kind of message matrix with multiple devices, it might be better to save RAM for user-specified messages.
However, there is nothing magical about PROGMEM, it is just another memory space on the processor, and there are lots of tutorials and threads on the topic.
marco_c:
Never underestimate a 13 year old when it comes to computer technology ...Did you start wih easier stuff like the LED blinker and reading an analog input? I find it is good to get the basics right and build on that.
yeah, we got tired of making leds blink, so i go on ebay and get random stuff (such as this) and then go from there.. we did a few digit leds, still trying to get the 3 digit and 2 digits to work.. but in time i guess.
we played around with a sensor (4 pin)..
we want to get into multiplexing - building cubes and dancing images.. he wants to build a torrent (or whatever he calls it).. i have a project i am working on with crossroads.
we have a couple of lcd's yet to play with.. but yeah, multiplexing and the such is what we want to accomplish the most,
AWOL:
If you were going to build some kind of message matrix with multiple devices, it might be better to save RAM for user-specified messages.However, there is nothing magical about PROGMEM, it is just another memory space on the processor, and there are lots of tutorials and threads on the topic.
we just want it to display different things.. .nothing special at this time.. i have more max7219's if ever needed.. i stocked up on those ![]()
i mean, it's a red dot 8x8 matrix.. nothing we really can use it for or need it for.. was just something to mess and learn with..
