APDS-9960 and UNO Gesture problems
Hi there,
I'm using the APDS-9960 Gesture and RGB Sensor (from the Sparkfun library) and having some real strange issues getting it to work.
The example code for the RGB and Proximity sensor work flawlessly, however the GestureTest and ProximityInterrupt don't work.
The one I want to use is the Gesture function, and just make a few small changes to the GestureTest example for my purposes.
It loads up fine and displays the message that the Gesture Sensor has initialized and now running. However in the base example code I get nothing after that. However if I change the sensor interrupt to be an INPUT_PULLUP instead, sometimes I will get one or more gestures read correctly, then it stops. Sometimes it still does nothing.
I know there seems to be a few known issues that people say can be fixed by altering the CPP and .h files. I've tried changing the LED BOOST to 100, and the GGAIN to 2x instead of the default 4x.
I have tried using a logic level converter in case that is the issue, but I get nothing, not even correct initialization if I use that.
My wiring is exactly as it should be according to the notes in the code.
I'm at a loss of what else I can try here. Please let me know if there's information I've missed out.
All I want to do is read the gesture and send a signal out for a GPIO dependent on the gesture. FOr now just reading them correctly will do!
