APDS-9960 sensor not recognizing any gestures
Hi, I have an APDS-9960 gesture sensor that I bought from aliexpress, all the other examples work, except for the gesture( i am using SparkFun's sketch examples that I got from GitHub to test out the new sensor aswell as the ardunio uno). The main reason I bought this was to sense gesture, which is the only one that does not work. can you please help me find out how? I am also 100% sure that I have wired everything correctly and made sure to use 3.3 volts. The ardunio says the sensor is ready but wont sense anything. I have tried to find the problem by looking at other forums, but none of them helps.
Thanks for your time to read this.
Are you sue you got an original sensor?
Why didn't you post a wiring diagram then? The schematics of the breakout board you bought is needed too as there might be more components on it than just the sensor chip.
Usually if the proximity example works at least some of the gestures work. Which gestures did you try?
hi thanks for responding, im not sure about its originality, but I bought the cheapest one I could find on aliexpress.
this is the wiring diagram, I tried all the gestures, but none of them worked
These are often fake chips or bad board designs. For example does your board also have the huge ceramic capacitor you see on the board fritzing shows? Get a board from the one of the known suppliers (Sparkfun, Adafruit, etc.) and try again.
Thank for helping, yes i think i need to buy another sensor from a well-reputed store
