APDS 9960 Gesture sensor not working
Hi All
I have several of the 9960 gesture sensor, i have used it on both UNO and MEGA. i can get the colour sensor to work but when i try to run the Gesture code out of the example code on arduino ide , i get this error on the serial log, and then nothing after that, i have tried several other modules but to no avail.
i have ensured that it is powered by the 3.3volt and not 5volt
any ideas?
SparkFun APDS-9960 - GestureTest
Something went wrong during APDS-9960 init!
Gesture sensor is now running
Did you use a level converter to connect the APDS 9960 to the UNO/Mega? The device must not have more than 3.8V on any of it's pins and both the UNO and the Mega have 5V on their I2C pins by default. You might have damaged the chip(s) already.
oh god,
no converter, i just plugged it in as per spark funs website
What breakout board do you use (you cannot connect the sensor without a breakout board, it's to tiny for that)? Post a link to the product! Post a wiring diagram.
Connecting to the UNO possibly did not damage it as the internal pullups are quite weak and may not have delivered enough current to do any harm. I'm not sure about the Mega though...
hey man
thanks for your response,
link is below
https://www.ebay.com.au/itm/RGB-Gesture-Proximity-Sensor-Module-I2C-Breakout-for-Arduino-APDS-9930/262929720379?hash=item3d37d5243b:g:sLMAAOSwmgJY6e32
picture attached,
yeah i am not too sure, maybe because i bought it of ebay.
This looks like an exact clone of the sparkfun board with the only change that cheaper parts are used and the sparkfun logo was removed.
The problem with these boards is that you don't know if you really got a APDS 9960 or just dummy chip that looks like the original one.
The capacitor seems to be a much smaller variant but I doubt that this disables the I2C interface.
The good news is that the board has pull-ups to 3V3, so at least if connected to an UNO the chip shouldn't get damaged as the voltage should be inside the allowed range (the two pull-ups build a voltage divider and the internal pulls resistors are very weak).
i may have been ripped off here :o
Because of what? Please define what parts you don't understand.
because ebay sold me a fake
I bought a clone from ebay as well.. the sparkfun library works great.. all examples seem to work but gesture example. it shows initialization complete.. gesture now running.. but nothing.. I bought this one that is sold as a sparkfun unit.. Apds-9960 Apds9960 RGB Gesture Breakout Module Infrared Move Sensor I2c for sale online | eBay
reading around I'm seeing lots of people having problems with that particular gesture file while it appears the other examples are working for more people..
I might be sold as that but it isn't. Sparkfun boards are red and they put their logo on it.
Buying cheap Chinese stuff might always result in hardware that doesn't react as expected. I only tried that sensor on 3V3, never tried it with 5V Arduino so it's possible that this sensor is reacting more sensitive on over-voltages in different modes.
I have found these low cost sensors off Alexpress etc work fine if the LED current is reduced.
The problem with these boards is that they do not have sufficient decoupling capacitance fitted to be able to cope with the full boost current for the IR LED.
The trick is to change this line in the library .cpp file to read:
    if( !setLEDBoost(LED_BOOST_100) ) {
If the gesture sketch still does not work then the current can be reduced further by changing this line in the library .h file to:
#define DEFAULT_LDRIVE LED_DRIVE_50MA
and also this line to:
#define DEFAULT_GLDRIVE LED_DRIVE_50MA
The sensor will also work with the unmodified library, but you must first add an additional 100uF capacitor (e.g. polarised electrolytic) between the GND and VCC pins (negative of electrolytic to GND), on the board. The leads to this capacitor need to be short.
I got an output on serial monitor that my gesture sensor is working but it doesn't log any gestures....kindly help
First: open your own thread if you don't have an immediate follow-up for the previous thread content.
If you need help, post all relevant information. Your post is missing the links to the used hardware (I doubt that you use the APDS 9960 without a breakout board) and the used libraries. You should also post a wiring diagram of your setup as well as the code of the sketch you were running (don't forget the code tags, that's the </> button in the editor). Also post the output your sketch is producing.
I solved the problem with the Chinese clones !!!!!!!!!!!!!! After about 2 months of torment. The ones that do not go to read the gestures but the other functionalities go .... those that receive the message "Something went wrong during APDS-9960 init!"... In the library, check if the sensor id is 0xAB .. but the id of the Chinese ones is 0xA8 . at least mine ... So ... you need to change in SpurkFun_APDS9960.h line #define APDS9960_ID_1 0xAB with 0xA8 .. and ready. if you use ESP8266 you still have to play with GAINE and BOOST on LEDs for more precise functionality .. other modules may have other ids.
aa. and something else. you can use gestures without interrupting pin.
In setup, at apds.enableGestureSensor (true) use (false) and modify the sketch.
Anyone who wants more details can contact me at ronin_boss@yahoo.com
I'm commenting to unlock this thread at the request of a forum user.
Looking at the breakout board and comparing with the data sheet, I found that in single supply operation it is recommended to have a 22 ohms / 1uF low pass on the power supply line.
There are pads reserved for the resistor on the board.
In single supply operation a 22 ohms resistor should be put there and Vcc should be applied to the VL pin while the PS pad jumper must be left open.
Believe me, in most situations it works without that. I only used a decoupling capacitor.
We don't know which board you're writing about. You failed to provide a link. The links in the older posts don't work anymore.
pylon:
Sure, I don't doubt that.
I just wanted to point out the recommended set from the data sheet.
As it says on page 34: "If operating from a single supply, use a 22-Ω resistor in series with the VDD supply line and a 1-μF low ESR capacitor to filter any power supply noise."
I am referring to this board: https://learn.sparkfun.com/tutorials/apds-9960-rgb-and-gesture-sensor-hookup-guide/all
It is also available as identically clones.
As you can see there are two pads to the right of PS which are obviously provided for the filter resistor.
No, I don't think that this is obvious, in contrary I'm quite sure these pads are for R4 which would allow to use a resistor instead of the direct connection of solder bridge SJ2 to drive the LED. So you can solder a resistor there but if you don't cute SJ2 it won't have any effect.
