I got an output on serial monitor that my gesture sensor is working but it doesn't log any gestures....kindly help
First: open your own thread if you don't have an immediate follow-up for the previous thread content.
If you need help, post all relevant information. Your post is missing the links to the used hardware (I doubt that you use the APDS 9960 without a breakout board) and the used libraries. You should also post a wiring diagram of your setup as well as the code of the sketch you were running (don't forget the code tags, that's the </> button in the editor). Also post the output your sketch is producing.
