David,
Thank you for your prompt response. I purchased this on EBAY:http://www.ebay.co.uk/itm/2-4-inch-TFT-LCD-Display-Shield-Touch-Panel-ILI9341-240X320-for-Arduino-UN-D1E3-/112639859701?_trksid=p2349526.m4383.l4275.c10#. Whilst the seller says it uses a 1L19341 controller it doesnt, having read your posts about the stuff sold on EBAY and using the test in MCUFRIEND_kbv it identifies it as a HE8347D. Setting this as controller in the Library code (.cpp file) it runs through all the graphicstest_kbv tests perfectly.
The sketch I am using is as follows:
[code//LTC2400 24bit ADC Module
//Application Demo: 7 digit voltmeter interfacing with CTE UART TFT LCD
//24bit ADC IC: LTC2400
//4.096 precision reference: TI REF3040
//By coldtears electronics
//LTC2400 code is adapted from Martin Nawrath
//Kunsthochschule fuer Medien Koeln
//Academy of Media Arts Cologne
//UART TFT Library from coldtears electronics is used
//as to display results
#include <UARTLCD.h>
#include <Stdio.h>
#include<stdlib.h>
UARTLCD uartlcd(true,false); //(single wire mode,checksum enable)
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
#define LTC_CS 2 // LTC2400 Chip Select Pin on Portb 2
#define LTC_MISO 4 // LTC2400 SDO Select Pin on Portb 4
#define LTC_SCK 5 // LTC2400 SCK Select Pin on Portb 5
cbi(PORTB,LTC_SCK); // LTC2400 SCK low
sbi (DDRB,LTC_CS); // LTC2400 CS HIGH
cbi (DDRB,LTC_MISO);
sbi (DDRB,LTC_SCK);
Serial.begin(38400);
uartlcd.Clr_screen(BLACK); delay(400); //Clear screen Black color
uartlcd.Draw_image(412,15,6); delay(100);
uartlcd.Draw_text(BLACK, PURPLE,"LTC2400 24bit", 100, 4, 319,230, 6); delay(70);
uartlcd.Draw_text(BLACK, CYAN,"ADC Module ", 110, 35, 319,230, 6); delay(70);
// init SPI Hardware
sbi(SPCR,MSTR) ; // SPI master mode
sbi(SPCR,SPR0) ; // SPI speed
sbi(SPCR,SPR1); // SPI speed
sbi(SPCR,SPE); //SPI enable
//Serial.println("LTC2400 ADC Test");
float volt;
float v_ref=4.094; // Reference Voltage, 5.0 Volt for LT1021 or 3.0 for LP2950-3
long int ltw = 0; // ADC Data ling int
int cnt; // counter
byte b0; //
byte sig; // sign bit flag
char st1[20]; // float voltage text
cbi(PORTB,LTC_CS); // LTC2400 CS Low
delayMicroseconds(1);
if (!(PINB & (1 << 4))) { // ADC Converter ready ?
// cli();
ltw=0;
sig=0;
b0 = SPI_read(); // read 4 bytes adc raw data with SPI
if ((b0 & 0x20) ==0) sig=1; // is input negative ?
b0 &=0x1F; // discard bit 25..31
ltw |= b0;
ltw <<= 8;
b0 = SPI_read();
ltw |= b0;
ltw <<= 8;
b0 = SPI_read();
ltw |= b0;
ltw <<= 8;
b0 = SPI_read();
ltw |= b0;
sbi(PORTB,LTC_CS); // LTC2400 CS Low
if (sig) ltw |= 0xf0000000; // if input negative insert sign bit
ltw=ltw/16; // scale result down , last 4 bits have no information
volt = ltw * v_ref / 16777216; // max scale
char tmp[10];
dtostrf(volt,6,6,tmp);
tmp[8]='V';
tmp[9]='\n';
// Serial.print(cnt++);
// Serial.print("; ");
// printFloat(volt,6); // print voltage as floating number
// Serial.println(" ");
uartlcd.Draw_text(BLACK, YELLOW,tmp, 10, 100, 319, 220, 9); delay(50);
sbi(PORTB,LTC_CS); // LTC2400 CS hi
delay(20);
byte SPI_read()
SPDR = 0;
while (!(SPSR & (1 << SPIF))) ; /* Wait for SPI shift out done */
return SPDR;
// printFloat from tim / Arduino: Playground
// printFloat prints out the float 'value' rounded to 'places' places
//after the decimal point
void printFloat(float value, int places) {
// this is used to cast digits
int digit;
float tens = 0.1;
int tenscount = 0;
int i;
float tempfloat = value;
// if value is negative, set tempfloat to the abs value
// make sure we round properly. this could use pow from
//<math.h>, but doesn't seem worth the import
// if this rounding step isn't here, the value 54.321 prints as
// calculate rounding term d: 0.5/pow(10,places)
float d = 0.5;
if (value < 0)
d *= -1.0;
// divide by ten for each decimal place
for (i = 0; i < places; i++)
d/= 10.0;
// this small addition, combined with truncation will round our
tempfloat += d;
if (value < 0)
tempfloat *= -1.0;
while ((tens * 10.0) <= tempfloat) {
tens *= 10.0;
tenscount += 1;
// write out the negative if needed
if (value < 0)
Serial.print('-');
if (tenscount == 0)
Serial.print(0, DEC);
for (i=0; i< tenscount; i++) {
digit = (int) (tempfloat/tens);
Serial.print(digit, DEC);
tempfloat = tempfloat - ((float)digit * tens);
tens /= 10.0;
// if no places after decimal, stop now and return
if (places <= 0)
return;
// otherwise, write the point and continue on
Serial.print(',');
for (i = 0; i < places; i++) {
tempfloat *= 10.0;
digit = (int) tempfloat;
Serial.print(digit,DEC);
// once written, subtract off that digit
tempfloat = tempfloat - (float) digit;
I also have a serial out sketch which works fine. If i had carried on failing so dramatically i was going to try and convert this to output to a TFT display :o
Hardware: Arduino R3, LTC2400 on breakout, TFT panel. I have had the DVM working fine and the TFT panel working fine , just not with this sketch.
I don't need anything clever on the display:
| PSU N | N = Constant 1 or 2
| XX.XXXX Volts |
| X.XXXX Amps |
If you can help me with the basics I am sure I can tart this up. As I said if I could get a copy of the original Library (UARtLCD so I could compile the sketch I have, I am sure I could have solved this myself, however I am most grateful for whatever help you can give.
I have to add some logic to the DVM so I can switch the input between the two measurements being made (Voltage and Current). This will require me to hang an output onto the arduino/sketch so the input matches what is being displayed (or vice versa).
Once again many thanks for the help
Don
