ArduCAM OV5642 + Arduino 101
I'd like to use ArduCAM 5MP [OV5642] on a Arduino 101. Is it supported? Are the compatible?
If yes, where can I find a connection scheme or explanation about how connect them?
Thank you in advance!
If you're planning to use a library or example sketch to interface with the ArduCAM then try compiling it for Arduino 101. You will find that a significant number of libraries and sketches you find online are specifically written for the AVR Arduino boards such as Uno, Mega, etc. and will not compile for the other architectures. Of course it is possible to port over the code to the 101 but unless someone has already done this for you it does make the project significantly more complex and time consuming.
