Arduino 4.0 TFT ili9488
I am having trouble getting my TFT screen working. I'm not using a shield since I bought a module from AliExpress (this one: https://www.aliexpress.com/item/33015586094.html?spm=a2g0o.order_list.order_list_main.16.7acf1802vXK5D0). I found a library named MCUFRIEND_kbv that supports the screen driver ili9488. I downloaded it through the IDE Library Manager and opened the example code "graphictest_kbv". Since I am not using a shield, the code instructs me to use a constructor, so I wired it accordingly. I am using an Arduino Uno from the student kit.
On the left, I have written the label on the screen, and on the right, what it is connected to on the Arduino:
  • SDO (MISO) - A1
  • LED - 3.3V
  • SDI (MOSI) - A0
  • DC/RS - A2
  • RESET - A4
  • CS - A3
  • GND - GND
  • VCC - 3.3V
I have made a small change to the code, which was to add "#define SUPPORT_9488_555". From what I read on the GitHub, it seems like it was necessary.
#if defined(__AVR_ATmega32U4__)    //Leonardo
#define HOW_SLIM 3
#else
#define HOW_SLIM 0                 //no slimming measures
#endif
// All the mcufriend.com UNO shields have the same pinout.
// i.e. control pins A0-A4.  Data D2-D9.  microSD D10-D13.
// Touchscreens are normally A1, A2, D7, D6 but the order varies
// This demo should work with most Adafruit TFT libraries
// If you are not using a shield,  use a full Adafruit constructor()
// e.g. Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
#define LCD_CS A3; // Chip Select goes to Analog 3
#define LCD_CD A2; // Command/Data goes to Analog 2
#define LCD_WR A1; // LCD Write goes to Analog 1
#define LCD_RD A0; // LCD Read goes to Analog 0
#define LCD_RESET A4; // Can alternately just connect to Arduino's reset pin
#define SUPPORT_9488_555 # I added this
#if ARDUINO < 165
#define USE_GFX_KBV
#include "ADA_GFX_kbv.h"
#else
#include "Adafruit_GFX.h"
#endif
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <Adafruit_TFTLCD.h>
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET); # ERROR HAPPENDS HERE
// Assign human-readable names to some common 16-bit color values:
#define    BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#ifndef min
#define min(a, b) (((a) < (b)) ? (a) : (b))
#endif
void setup(void);
void loop(void);
unsigned long testFillScreen();
unsigned long testText();
unsigned long testLines(uint16_t color);
unsigned long testFastLines(uint16_t color1, uint16_t color2);
unsigned long testRects(uint16_t color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2);
unsigned long testFilledCircles(uint8_t radius, uint16_t color);
unsigned long testCircles(uint8_t radius, uint16_t color);
unsigned long testTriangles();
unsigned long testFilledTriangles();
unsigned long testRoundRects();
unsigned long testFilledRoundRects();
void progmemPrint(const char *str);
void progmemPrintln(const char *str);
void runtests(void);
uint16_t g_identifier;
void setup(void) {
#if HOW_SLIM < 1
    uint32_t when = millis();
    //    while (!Serial) ;   //hangs a Leonardo until you connect a Serial
    if (!Serial) delay(5000);           //allow some time for Leonardo
    Serial.println("Serial took " + String((millis() - when)) + "ms to start");
#endif
    static uint16_t identifier;
    tft.reset();                 //we can't read ID on 9341 until begin()
    g_identifier = tft.readID(); //
#if HOW_SLIM < 1
    Serial.print("ID = 0x");
    Serial.println(g_identifier, HEX);
#endif
    if (g_identifier == 0x00D3) g_identifier = 0x9481; // write-only shield
    if (g_identifier == 0xFFFF) g_identifier = 0x9341; // serial
    //    g_identifier = 0x7789;                             // force ID
    tft.begin(g_identifier);
#if defined(MCUFRIEND_KBV_H_)
uint16_t scrollbuf[480];    // my biggest screen is 320x480
#define READGRAM(x, y, buf, w, h)  tft.readGRAM(x, y, buf, w, h)
#else
uint16_t scrollbuf[320];    // Adafruit only does 240x320
// Adafruit can read a block by one pixel at a time
int16_t  READGRAM(int16_t x, int16_t y, uint16_t *block, int16_t w, int16_t h)
    uint16_t *p;
    for (int row = 0; row < h; row++) {
        p = block + row * w;
        for (int col = 0; col < w; col++) {
            *p++ = tft.readPixel(x + col, y + row);
#endif
void windowScroll(int16_t x, int16_t y, int16_t wid, int16_t ht, int16_t dx, int16_t dy, uint16_t *buf)
    if (dx) for (int16_t row = 0; row < ht; row++) {
            READGRAM(x, y + row, buf, wid, 1);
            tft.setAddrWindow(x, y + row, x + wid - 1, y + row);
            tft.pushColors(buf + dx, wid - dx, 1);
            tft.pushColors(buf + 0, dx, 0);
    if (dy) for (int16_t col = 0; col < wid; col++) {
            READGRAM(x + col, y, buf, 1, ht);
            tft.setAddrWindow(x + col, y, x + col, y + ht - 1);
            tft.pushColors(buf + dy, ht - dy, 1);
            tft.pushColors(buf + 0, dy, 0);
void loop(void) {
    uint8_t aspect;
    uint16_t pixel;
    char *aspectname[] = {
        "PORTRAIT", "LANDSCAPE", "PORTRAIT_REV", "LANDSCAPE_REV"
    char *colorname[] = { "BLUE", "GREEN", "RED", "GRAY" };
    uint16_t colormask[] = { 0x001F, 0x07E0, 0xF800, 0xFFFF };
    uint16_t dx, rgb, n, wid, ht;
    tft.setRotation(1);
    runtests();
    delay(2000);
    if (tft.height() > 64) {
        for (uint8_t cnt = 0; cnt < 4; cnt++) {
            aspect = (cnt + 0) & 3;
            tft.setRotation(aspect);
            wid = tft.width();
            ht = tft.height();
            testText();
            dx = wid / 32;
            for (n = 0; n < 32; n++) {
                rgb = n * 8;
                rgb = tft.color565(rgb, rgb, rgb);
                tft.fillRect(n * dx, 48, dx, 64, rgb & colormask[aspect]);
            tft.setTextSize(2);
            tft.setTextColor(colormask[aspect], BLACK);
            tft.setCursor(0, 72);
            tft.print(colorname[aspect]);
            tft.setTextColor(WHITE);
            tft.println(" COLOR GRADES");
            tft.setTextColor(WHITE, BLACK);
            tft.setCursor(0, 184);
            tft.println(aspectname[aspect]);
            tft.drawPixel(0, 0, YELLOW);
            pixel = tft.readPixel(0, 0);
#if HOW_SLIM < 3
            extern const uint8_t penguin[];
            tft.setAddrWindow(wid - 40 - 40, 20 + 0, wid - 1 - 40, 20 + 39);
            tft.pushColors(penguin, 1600, 1);
#endif
            tft.println("VERTICAL SCROLL UP");
            uint16_t maxscroll;
            if (tft.getRotation() & 1) maxscroll = wid;
            else maxscroll = ht;
            for (uint16_t i = 1; i <= maxscroll; i++) {
                tft.vertScroll(0, maxscroll, i);
                delay(10);
            tft.vertScroll(0, maxscroll, 0);
            tft.setCursor(0, 200);
            tft.println("VERTICAL SCROLL DN");
                tft.vertScroll(0, maxscroll, 0 - (int16_t)i);
                delay(10);
            if ((aspect & 1) == 0) { //Portrait
                tft.setTextColor(BLUE, BLACK);
                tft.println("ONLY THE COLOR BAND");
                for (uint16_t i = 0; i < 64; i++) {
                    tft.vertScroll(48, 64, i + 1);
                    delay(20);
#endif
            tft.setTextColor(YELLOW, BLACK);
            if (pixel == YELLOW) {
                tft.println("SOFTWARE SCROLL    ");
#if 1
                for (int16_t i = 45, dx = 2, dy = 1; i > 0; i -= dx) {
                    windowScroll(24, 8, 90, 40, dx, dy, scrollbuf);
#else
                // scroll a whole width of the screen
                for (int16_t i = wid, dx = 4, dy = 0; i > 0; i -= dx) {
                    windowScroll(0, 200, wid, 16, dx, dy, scrollbuf);
#endif
            else if (pixel == CYAN)
                tft.println("readPixel() reads as BGR");
            else if (pixel == 0xFFFF)
                tft.println("readPixel() should be 24-bit");
            else {
                tft.print("readPixel() reads 0x");
                tft.println(pixel, HEX);
            delay(5000);
    tft.println("INVERT DISPLAY");
    tft.invertDisplay(true);
    delay(2000);
    tft.invertDisplay(false);
typedef struct {
    PGM_P msg;
    uint32_t ms;
} TEST;
TEST result[12];
#define RUNTEST(n, str, test) { result[n].msg = PSTR(str); result[n].ms = test; delay(500); }
void runtests(void)
    uint8_t i;
    uint32_t total;
    RUNTEST(0, "FillScreen               ", testFillScreen());
    RUNTEST(1, "Text                     ", testText());
    RUNTEST(2, "Lines                    ", testLines(CYAN));
    RUNTEST(3, "Horiz/Vert Lines         ", testFastLines(RED, BLUE));
    RUNTEST(4, "Rectangles (outline)     ", testRects(GREEN));
    RUNTEST(5, "Rectangles (filled)      ", testFilledRects(YELLOW, MAGENTA));
    RUNTEST(6, "Circles (filled)         ", testFilledCircles(10, MAGENTA));
    RUNTEST(7, "Circles (outline)        ", testCircles(10, WHITE));
    RUNTEST(8, "Triangles (outline)      ", testTriangles());
    RUNTEST(9, "Triangles (filled)       ", testFilledTriangles());
    RUNTEST(10, "Rounded rects (outline)  ", testRoundRects());
    RUNTEST(11, "Rounded rects (filled)   ", testFilledRoundRects());
    tft.setRotation(1);
    tft.fillScreen(BLACK);
    tft.setCursor(0, 0);
    tft.setTextSize(2);
    tft.println("MCUFRIEND for UNO");
    tft.setTextSize(1);
    total = 0;
    for (i = 0; i < 12; i++) {
        PGM_P str = result[i].msg;
        char c;
        if (i < 10) tft.print(" ");
        tft.print(i);
        tft.print(": ");
        while (c = pgm_read_byte(str++)) tft.print(c);
        tft.println(result[i].ms);
        total += result[i].ms;
    tft.setTextSize(2);
    tft.print("Total:");
#if HOW_SLIM < 2
    tft.print(0.000001 * total);
    tft.println("sec");
#else
    tft.print(total / 1000, DEC);
    tft.println(" ms");
#endif
    tft.print("ID: 0x");
    tft.println(tft.readID(), HEX);
    tft.print("Reg(00):0x");
    tft.println(tft.readReg(0x00), HEX);
    tft.print("F_CPU:");
#if HOW_SLIM < 2
    tft.print(0.000001 * F_CPU);
#else
    tft.print((int)(F_CPU/1000000));
#endif
#if defined(__OPTIMIZE_SIZE__)
    tft.println("MHz -Os");
#else
    tft.println("MHz");
#endif
    delay(10000);
// Standard Adafruit tests.  will adjust to screen size
unsigned long testFillScreen() {
    unsigned long start = micros();
    tft.fillScreen(RED);
    tft.fillScreen(GREEN);
    tft.fillScreen(BLUE);
    return micros() - start;
unsigned long testText() {
    unsigned long start;
    start = micros();
    tft.setTextColor(WHITE);  tft.setTextSize(1);
    tft.println("Hello World!");
    tft.setTextColor(YELLOW); tft.setTextSize(2);
#if HOW_SLIM < 2
    tft.println(123.45);
#else
    tft.println("456.78");
#endif
    tft.setTextColor(RED);    tft.setTextSize(3);
    tft.println(0xDEADBEEF, HEX);
    tft.println();
    tft.setTextColor(GREEN);
    tft.setTextSize(5);
    tft.println("Groop");
    tft.setTextSize(2);
    tft.println("I implore thee,");
    tft.setTextSize(1);
    tft.println("my foonting turlingdromes.");
    tft.println("And hooptiously drangle me");
    tft.println("with crinkly bindlewurdles,");
    tft.println("Or I will rend thee");
    tft.println("in the gobberwarts");
    tft.println("with my blurglecruncheon,");
    tft.println("see if I don't!");
unsigned long testLines(uint16_t color) {
    unsigned long start, t;
    int           x1, y1, x2, y2,
                  w = tft.width(),
                  h = tft.height();
    x1 = y1 = 0;
    y2    = h - 1;
    start = micros();
    for (x2 = 0; x2 < w; x2 += 6) tft.drawLine(x1, y1, x2, y2, color);
    x2    = w - 1;
    for (y2 = 0; y2 < h; y2 += 6) tft.drawLine(x1, y1, x2, y2, color);
    t     = micros() - start; // fillScreen doesn't count against timing
    x1    = w - 1;
    y1    = 0;
    y2    = h - 1;
    start = micros();
    x2    = 0;
    t    += micros() - start;
    x1    = 0;
    y1    = h - 1;
    y2    = 0;
    start = micros();
    x2    = w - 1;
    x1    = w - 1;
    y1    = h - 1;
    y2    = 0;
    start = micros();
    x2    = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
    int           x, y, w = tft.width(), h = tft.height();
    start = micros();
    for (y = 0; y < h; y += 5) tft.drawFastHLine(0, y, w, color1);
    for (x = 0; x < w; x += 5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
    int           n, i, i2,
                  cx = tft.width()  / 2,
                  cy = tft.height() / 2;
    n     = min(tft.width(), tft.height());
    start = micros();
    for (i = 2; i < n; i += 6) {
        i2 = i / 2;
        tft.drawRect(cx - i2, cy - i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
    unsigned long start, t = 0;
    int           n, i, i2,
                  cx = tft.width()  / 2 - 1,
                  cy = tft.height() / 2 - 1;
    for (i = n; i > 0; i -= 6) {
        i2    = i / 2;
        start = micros();
        tft.fillRect(cx - i2, cy - i2, i, i, color1);
        // Outlines are not included in timing results
        tft.drawRect(cx - i2, cy - i2, i, i, color2);
    return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
    int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
    start = micros();
    for (x = radius; x < w; x += r2) {
        for (y = radius; y < h; y += r2) {
            tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
    int           x, y, r2 = radius * 2,
                        w = tft.width()  + radius,
                        h = tft.height() + radius;
    // Screen is not cleared for this one -- this is
    // intentional and does not affect the reported time.
    start = micros();
    for (x = 0; x < w; x += r2) {
        for (y = 0; y < h; y += r2) {
            tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
    int           n, i, cx = tft.width()  / 2 - 1,
    n     = min(cx, cy);
    start = micros();
    for (i = 0; i < n; i += 5) {
        tft.drawTriangle(
            cx    , cy - i, // peak
            cx - i, cy + i, // bottom left
            cx + i, cy + i, // bottom right
            tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
    int           i, cx = tft.width()  / 2 - 1,
    start = micros();
    for (i = min(cx, cy); i > 10; i -= 5) {
        start = micros();
        tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
                         tft.color565(0, i, i));
        tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
                         tft.color565(i, i, 0));
    return t;
unsigned long testRoundRects() {
    int           w, i, i2, red, step,
    w     = min(tft.width(), tft.height());
    start = micros();
    red = 0;
    step = (256 * 6) / w;
    for (i = 0; i < w; i += 6) {
        i2 = i / 2;
        red += step;
        tft.drawRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(red, 0, 0));
unsigned long testFilledRoundRects() {
    int           i, i2, green, step,
    start = micros();
    green = 256;
    step = (256 * 6) / min(tft.width(), tft.height());
    for (i = min(tft.width(), tft.height()); i > 20; i -= 6) {
        i2 = i / 2;
        green -= step;
        tft.fillRoundRect(cx - i2, cy - i2, i, i, i / 8, tft.color565(0, green, 0));
@zani1, Hi, welcome to the forum!
The latest release of MCUFRIEND_kbv still doesn't support SPI displays, as far a I know.
It is the last release, sadly.
If you would tell which processor you use, you could get better advice.
For ESP32, ESP8266, RP2040 you could use TFT_eSPI..
For AVR processor you could look for an Adafruit library for the controller of your display.
I successfully used Arduino_GFX for several SPI TFTs. It supports many processors.
You find it in Library Manager, where it is known as GFX Library for Arduino.
Thank you for the answer! To be honest, it didn't cross my mind to check if the library supported SPI. I completely took it for granted. This might be a silly question, but when you mention "processor," are you referring to the microcontroller? I'm using Arduino Uno. Do you happen to know any newbie-friendly websites or example projects that I could explore? Once again, thank you so much for your help!
Yes, I meant microcontroller. Arduino UNO is a microcontroller board with an Atmega328 CPU (or processor, as we called it in old days before of the single-chip processors).
You need to be careful with the 5V IO pins of the Arduino UNO, as the controller of your display is for 3.3V data lines, if there is no level converter on the display board; there is none on the picture of the 4" display, but there seems to be a series regulator for VCC.
I am not familiar with tutorials. Arduino has tutorials, and Adafruit has a lot of information available.
I just found the post I had in mind: Problem with 3.5" tft display with ILI9488 driver.
