Hello CatweazleNZ,
Thanks for your suggestion, I will look deep into it.
As you said it looks really hard stuff.
Hello drmpf,
Thanks for your suggestion too.
But in this case I don't want to restrict acess only to cell phones, and my site design is already done and I liked the result.
Acctually I was thinking in a simple sollution, I was trying to do it this way, but when I upload this code the Serial Monitor goes crazy printing a bunch of caracters and the web server doesn't even start.
#define WEBDUINO_AUTH_REALM "Automação Residencial"
#include <SPI.h>
#include <Ethernet.h>
#include <WebServer.h>
#include <EthernetUdp.h>
#include <SD.h>
#include <livolo.h>
#define REQ_BUF_SZ 20 // size of buffer used to capture HTTP requests
EthernetUDP Udp;
Livolo livolo(8); // transmitter connected to pin #8
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte TargetMac[] = {0x60, 0xA4, 0x4C, 0x63, 0x61, 0xD6}; // PC's MAC address
IPAddress ip(192, 168, 1, 5); // IP address, may need to change depending on network
byte broadcast[] = {192, 168, 1, 255}; // Broadcast IP address
EthernetServer server(80); // create a server at port 80
File webFile; // handle to files on SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0; // index into HTTP_req buffer
WebServer webserver("", 80);
void Login(WebServer &server, WebServer::ConnectionType type, char *, bool) {
if (webserver.checkCredentials("YWRtaW46YWRtaW4=")) {
webserver.httpSuccess();
if (type != WebServer::HEAD) {
P(helloMsg) = "<h1>Hello Admin</h1>";
webserver.printP(helloMsg);
StartWeb();
else {
webserver.httpUnauthorized();
void setup(){
pinMode(10, OUTPUT); // disable Ethernet chip
digitalWrite(10, HIGH);
Serial.begin(9600); // for debugging
Serial.println("Initializing SD card..."); // initialize SD card
if (!SD.begin(4)) {
Serial.println("ERROR - SD card initialization failed!"); // initialization failed
return;
Serial.println("SUCCESS - SD card initialized.");
if (!SD.exists("index.htm")) { // check for index.htm file
Serial.println("ERROR - Can't find index.htm file!");
return; // can't find index file
Serial.println("SUCCESS - Found index.htm file.");
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
webserver.setDefaultCommand(&Login);
webserver.begin();
Udp.begin(9);
void loop(){
char buff[64];
int len = 64;
webserver.processConnection(buff, &len);
void StartWeb() {
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
Serial.write(c); // print HTTP request character to serial monitor
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
// if GET request
if (StrContains(HTTP_req, "GET / ") || StrContains(HTTP_req, "index.htm")) {
webFile = SD.open("index.htm"); // open web page file
else if (StrContains(HTTP_req, "1Andar.htm")) {
webFile = SD.open("1Andar.htm"); // open web page file
else if (StrContains(HTTP_req, "2Andar.htm")) {
webFile = SD.open("2Andar.htm"); // open web page file
else if (StrContains(HTTP_req, "3Andar.htm")) {
webFile = SD.open("3Andar.htm"); // open web page file
// if POST request
if (StrContains(HTTP_req, "POST /")){
String POST = "";
while(client.available()){
c = client.read();
POST += c;
if(StrContains(HTTP_req, "/livolo")) {
String controlvalue = POST.substring(0, POST.indexOf('&'));
String buttonvalue = POST.substring(POST.indexOf('&') + 1, POST.length());
String control = controlvalue.substring(controlvalue.indexOf('=') + 1, controlvalue.length());
String button = buttonvalue.substring(buttonvalue.indexOf('=') + 1, buttonvalue.length());
livolo.sendButton(control.toInt(), button.toInt());
else if (POST != "") {
String cmdname = POST.substring(0, POST.indexOf('&'));
String cmdvalue = POST.substring(POST.indexOf('&') + 1, POST.length());
String name = cmdname.substring(cmdname.indexOf('=') + 1, cmdname.length());
String value = cmdvalue.substring(cmdvalue.indexOf('=') + 1, cmdvalue.length());
if (name == "Garagem") {
//command
if (name == "Portao") {
//command
if (name == "Alarme") {
//command
if (name == "Cobertura") {
//command
if (name == "PC" && value.toInt() == 1) {
WOL(TargetMac);
XML_response(client); // send XML file
if (webFile) { // send web page to client
while(webFile.available()) {
client.write(webFile.read());
webFile.close();
req_index = 0;
StrClear(HTTP_req, REQ_BUF_SZ);
if (c == '\n') {
else if (c != '\r') {
currentLineIsBlank = false;
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
void StrClear(char *str, char length){
for (int i = 0; i < length; i++) {
str[i] = 0;
void XML_response(EthernetClient cl) { // send the XML file
cl.print("<?xml version = \"1.0\"?>");
cl.print("<response>");
cl.print("Ok");
cl.print("</response>");
void WOL(byte mac[]) {
byte preamble[] = {
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
int i = 0;
Udp.beginPacket(broadcast, 9);
Udp.write(preamble, sizeof preamble);
while (i<16){
Udp.write(TargetMac, sizeof TargetMac);
i++;
Udp.endPacket();
char StrContains(char *str, char *sfind){
char found = 0;
char index = 0;
char len;
len = strlen(str);
if (strlen(sfind) > len) {
return 0;
while (index < len) {
if (str[index] == sfind[found]) {
found++;
if (strlen(sfind) == found) {
return 1;
else {
found = 0;
index++;
return 0;
