Arduino Burning Bootloader Error
I've tried everything but I haven't found a solution, please help.
My device is a custom mega with an Atmega2560 chip.
It was working normally, and I accidentally tried to flash the bootloader without supplying 5V, and this is the result.
Here is the detailed error:
Using port            : COM5
Using programmer      : stk500v1
Setting baud rate     : 19200
AVR part              : ATmega2560
Programming modes     : SPM, ISP, HVPP, JTAG
Programmer type       : STK500
Description           : Atmel STK500 v1
HW Version            : 2
FW Version            : 1.18
Topcard               : Unknown
Vtarget               : 0.0 V
Varef                 : 0.0 V
Oscillator            : Off
SCK period            : 0.0 us
XTAL frequency        : 7.372800 MHz
AVR device initialized and ready to accept instructions
Device signature = 00 00 00 (retrying)
Error: invalid device signature
Error: expected signature for ATmega2560 is 1E 98 01
  - double check connections and try again, or use -F to carry on regardless
Avrdude done.  Thank you.
Failed chip erase: uploading error: exit status 1
I checked the connections and while I can flash a bootloader into other devices, I can't flash one onto this one.
Please help, and thank you in advance.
Have you considered the possibility that doing so has physically damaged the chip and it's game over?
Unfortunately it looks like that
