Ok, so i am gutting my old camper trailer and turning it into a CNC router workshop. I got thinking, wouldn't it be handy to have an Arduino handle the whole of the remaining camper functions, such as monitoring battery volts, and 12V circuit over-current shutdown (possibly even AC as well).
the "breakers" will be relays, and i will use fuses rated for the relay capability as a backup. the idea will be a programmable breaker point, anywhere between 0A (circuit unused) and a little under the backup fuse value.
The current will not be huge, as i will mainly use the 12V for lighting, and whatever else i build in.
the current sensor will likely be something like THIS. for AC current, i will use a split-core sensor.
Ok, now the question i have is will the relays be able to interrupt a shorted circuit, without welding themselves? i will have fuses as backups, but i want to make sure.
I haven't any code yet, nor do i have a schematic, as i am first checking the feasibility first. I don't plan on blowing a lot of fuses. i just thought it would be a neat project to work on.
Thanks in advance for any help
~Travis
