Another problem you might have is that it looks like it takes either 0-2 or 0-10 V, not 0-2.5V. But again, as James said, simply do not output the maximum value from the Due. As far as the minimum value goes, it looks like you can adjust the input buffer (look at pins 15 & 16, there is an ADJ and Voffset). Maybe someone more knowledgeable can explain further, but I think that's what you are looking for.
If you need a current output, you're pretty much going to need an external op-amp to do voltage-to-current conversion. That same op-amp can compensate for the goofy offset and range of the Due DAC, as well as scaling the output to give the range you want. You won't get a passive circuit to give you what you need.
On datasheet is written that for output 0-20mA need a input range of 0-2.5V .. or not?
( page 5 of the datasheet , table top right )
RayLivingston:
dimare, check out that other topic I linked to, Wawa actually found a great solution -- Analog Devices has several chips that have an SPI interface and 0-20mA out so that you don't have to worry about voltages from the DAC. I am going to use an AD5420 myself.
hello everyone ... after doing tests with the integrated ad694 , with poor results .. ( inprecisioni ) .. I found out that I can use as a 0-5V or 0-10V range also ... any of you know a Dashboard with i2c that communicates with arduino and output dAC converts 0-10v?
I have completely solved this problem using a simple operational amplifier. Look at my site: http://ardupiclab.blogspot.it/ for the scheme and explanations.
