OK, I checked the .json in preferences and it was correct.
However, the board manager showed all the ESP8266 boards, obviously, as the verbose output from the compiler shows:
Arduino: 1.6.9 (Windows 7), Board: "Adafruit HUZZAH ESP8266, 80 MHz, 115200, 4M (3M SPIFFS)"
So I fumbled around, closed the Arduino IDE and restarted. I got:
Could not find boards.txt in C:\Users\Main User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0. Is it pre-1.5?
So I went into boards manager and deleted the ESP8266 boards (2.2.2 and 2.3.0).
All ESP references disappeared. I looked in the Arduino15/packages and found zips of 2.2.0 and 2.3.0 in the subfolder "staging". I used the install zip library option but it didn't work. So I installed ESP8266 version 1.0, and the ESP8266 libraries reappeared. Then I updated to version 2.3.0 and the boards manager showed version 2.3.0 as the current version.
I attempted to compile the program and still got:
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files\Arduino\hardware" -hardware "C:\Users\Main User\AppData\Local\Arduino15\packages" -hardware "C:\Users\Main User\Documents\Arduino\myprogs\hardware" -tools "C:\Program Files\Arduino\tools-builder" -tools "C:\Users\Main User\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files\Arduino\libraries" -libraries "C:\Users\Main User\Documents\Arduino\myprogs\libraries" -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10609 -build-path "C:\Users\MAINUS~1\AppData\Local\Temp\buildbd8cd7232fa3fa28ec64aa67052c1903.tmp" -warnings=default -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Main User\Documents\Arduino\myprogs\newESPtempRead\newESPtempRead.ino"
Board huzzah (platform esp8266, package esp8266) is unknown
Error compiling for board Adafruit HUZZAH ESP8266.
The library "2.3.0" cannot be used.
Library names must contain only basic letters and numbers.
(ASCII only and no spaces, and it cannot start with a number)
OK
