Arduino IDE 2.0.0 - rc3
I have a problem with my board and programming. Here is listing of my problem:
Compilation complete.
esptool.py v3.0
Serial port COM3
Connecting……..…..…..…..…..…..….._____
Traceback (most recent call last):
File “C:\Users\ivang\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/tools/upload.py”, line 66, in
esptool.main(cmdline)
File “C:/Users/ivang/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 3552, in main
esp.connect(args.before, args.connect_attempts)
File “C:/Users/ivang/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py”, line 529, in connect
raise FatalError(‘Failed to connect to %s: %s’ % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
Upload error: Failed uploading: uploading error: exit status 1
Thank you for answer.
Ivan
More details please
I assume that you are using an ESP8266 and that you have the correct board and port selected
Can you upload a minimal sketch after doing File/New ?
Hi, thank you for your interest, in the meantime I tried again and today I succeeded, finally. I switched to a new computer, the old one was 32bit, the new one I now have 64-bit, I transfer these programs. I'm an amateur in these things. well thank you
Please do not post pictures of code and error messages
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
OK, I accept it.
