A post was split to a new topic: IDE hangs on startup: "Error verifying signature: openpgp: signature expired"
Arduino IDE 2.3.2 works great. Tried it on Raspberry Pi Pico and Espressif ESP32S3. Arduino Nano ESP32 ESP32-S3 on order will test that.
I ran two different processors at the same time! I didnât even check if that was possible. Great work!
A post was split to a new topic: Is there a partition scheme option for ESP32?
A post was split to a new topic: "Go to definition" does not work any more
A post was split to a new topic: Problems with IDE 2.x
A post was split to a new topic: IDE 2.3.2 not opening
3 posts were split to a new topic: I am disappointed by the lack of a Linux ARM64 build
Hi - I am using 2.3.2
Is there a way of cancelling a verify or upload after it has started yet? I have seen numerous posts about it coming but have not found out how to do it as yet.
There are times when you press upload or verify and know it is going to fail but you just have to wait it all out before you can try again.
Hopefully the function is in the IDE now and someone can point me to it.
Thanks
Do not know about 2.3.2 but with the nightly 2.3.3, which I currently use, the bottom right message box displays a Cancel button during compile and upload.
It works as advertised.
Ahhh... Wonderful - thanks - will look at the nightlies.
Side note:
I am running the nightly builds. In fact I updated today on general principle as I was running one that was about a month old.
However, AFAIK the last change made to IDE that was brought into the nightly builds
is now something like 5 or 6 months ago.
I see still the same bug as described for 2.0.2 here:
This should be handled properly.
Occasionally happening to Pro Micro:
A post was split to a new topic: IDE hangs when loading Marlin sketch
A post was split to a new topic: Still no upload without recompile
A post was split to a new topic: Hay alguna guĂa en español?
