i have downloaded the IDE 2.3.2 but it is not opening
When I suggested that you opened a new topic for your problem with the IDE I said
You did not start a new topic but instead hijacked an older one and you have not given any details as requested
sorry let me do as you said now
have done it
Why did you start another topic on this subject
I had already split this one from the one that you hijacked. Continue here and provide more details of the problem
is not opening
Which Operating System ?
What, if anything, is on the screen when you try to open the IDE ?
You can get some info about what is happening by following these instructions: My arduino IDE 2.2.1. is stuck on the loading screen - #2 by ptillisch
If the output is too large for the forum (around 120000 characters), you can save it to a file and attach to a reply.
Note:
I'm not a specialist so will probably not be able to help further. I also no longer use IDE 2.x.
the software is not lunching
Hi @nyamekong.
It will not be possible for us to help you with that problem based on such a vague description. Please provide a detailed description of what you mean by this in a reply on this forum thread, including:
- What did you do?
- What were the results you expected from doing that thing?
- What were the results you observed that did not match your expectations?
Make sure to include the full and exact text of any error or warning messages you might have encountered.
Please make a stronger effort to communicate. I guess you think you are saving time by making these vague short posts, but I assure you that is not so.
The people who take the time to provide the helpers here with sufficient information from the start often receive a solution within a matter of minutes. The ones who don't do that might go through days of frustrating back and forth as we struggle to squeeze the information out of them.
The choice of how this will go is yours to make.
If English isn't your first language, you are welcome to compose a detailed description in your native language and then use an automated translation service like Google Translate to translate it to English before posting.
i consider this solved!!
i also HAD this problem ArduinoIDE2.3.2 would not show the actual screen of the IDE only the tasks in the taskbar
i could not find how to solve this
but i have the same hardware and now the screen shows!
how?
i had windows 10 and now installed windows 11!!
it is solved!~
by the way windows 11 is a free upgrade if you own windows 10 on the pc
Did you have a dual monitor setup and removed one monitor and you had the IDE open in the monitor that you removed?
now the problem is solved
Great. How did you solve it?
