Arduino IDE 2.3.3 is not working
I'm having a lot of trouble with the Arduino IDE 2.3.3. In tools, the port option doesn't even appear. The port manager doesn't generate any results. I can't open a new sketch. And the only message that appears in any action I take is "Error 14 UNAVAILABLE: No connection established".
Thanks in advance to any help given.
Edson
Hi @edson81. Please add a forum reply here to tell us which operating system you are using (e.g., "Windows")?
I ask because I would like to give you the appropriate instructions for your operating system.
Hello @ptillisch ! I'm using Windows 11.
I'm going to ask you to provide some additional information that might help us to identify the problem.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Quit from the Arduino IDE menus if it is running.
    All Arduino IDE windows will close.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
    A context menu will open.
  5. Select "Open PowerShell window here" from the menu.
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait for Arduino IDE to finish starting.
  9. Switch back to the PowerShell window.
  10. Press the Ctrl+Shift+A keyboard shortcut.
    This will select all the text in the PowerShell window.
  11. Press the Ctrl+C keyboard shortcut.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the "Reply" button.
  13. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  14. Press the Ctrl+V keyboard shortcut.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
PS C:\Users\edsoo\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 7944
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/edsoo/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-26T03:24:51.218Z root INFO Backend Object.initialize: 3.4 ms [Finished 0.381 s after backend start]
2024-10-26T03:24:51.218Z root INFO Backend Object.configure: 2.9 ms [Finished 0.382 s after backend start]
2024-10-26T03:24:51.218Z root INFO Backend a.onStart: 1.4 ms [Finished 0.382 s after backend start]
2024-10-26T03:24:51.219Z root INFO Backend a.configure: 0.3 ms [Finished 0.400 s after backend start]
2024-10-26T03:24:51.220Z root INFO Backend d.onStart: 0.2 ms [Finished 0.400 s after backend start]
2024-10-26T03:24:51.221Z root INFO Backend d.configure: 0.1 ms [Finished 0.400 s after backend start]
2024-10-26T03:24:51.221Z root INFO Backend d.initialize: 18.6 ms [Finished 0.401 s after backend start]
2024-10-26T03:24:51.222Z root INFO Backend c.onStart: 0.2 ms [Finished 0.401 s after backend start]
2024-10-26T03:24:51.222Z root INFO Backend s.configure: 1.0 ms [Finished 0.402 s after backend start]
2024-10-26T03:24:51.223Z config INFO >>> Initializing CLI configuration...
2024-10-26T03:24:51.223Z root INFO Backend c.initialize: 0.5 ms [Finished 0.402 s after backend start]
2024-10-26T03:24:51.223Z root INFO Backend x.onStart: 0.9 ms [Finished 0.403 s after backend start]
2024-10-26T03:24:51.224Z config INFO Loading CLI configuration from c:\Users\edsoo\.arduinoIDE\arduino-cli.yaml...
2024-10-26T03:24:51.224Z daemon INFO Starting daemon from C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-10-26T03:24:51.224Z root INFO Backend s.initialize: 0.3 ms [Finished 0.403 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend w.onStart: 1.1 ms [Finished 0.404 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend r.configure: 1.9 ms [Finished 0.404 s after backend start]
2024-10-26T03:24:51.224Z discovery-log INFO start
2024-10-26T03:24:51.224Z discovery-log INFO start new deferred
2024-10-26T03:24:51.224Z root INFO Backend d.initialize: 0.4 ms [Finished 0.405 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend y.onStart: 1.5 ms [Finished 0.406 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend r.configure: 1.2 ms [Finished 0.406 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend s.onStart: 0.3 ms [Finished 0.407 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend h.configure: 0.3 ms [Finished 0.407 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend a.configure: 0.1 ms [Finished 0.407 s after backend start]
2024-10-26T03:24:51.224Z root INFO Backend l.configure: 0.0 ms [Finished 0.407 s after backend start]
2024-10-26T03:24:51.226Z root INFO Theia app listening on http://127.0.0.1:52074.
2024-10-26T03:24:51.227Z root INFO Finished starting backend application: 2.2 ms [Finished 0.409 s after backend start]
2024-10-26T03:24:51.227Z root WARN The local plugin referenced by local-dir:/c%3A/Users/edsoo/.arduinoIDE/extensions does not exist.
2024-10-26T03:24:51.227Z root WARN The local plugin referenced by local-dir:/c%3A/Users/edsoo/.arduinoIDE/plugins does not exist.
2024-10-26T03:24:51.227Z root WARN The local plugin referenced by local-dir:C:\Users\edsoo\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\edsoo\OneDrive\Área de Trabalho\equalizador
isTempSketch: false. Input was c:\Users\edsoo\OneDrive\Área de Trabalho\equalizador\equalizador.ino
2024-10-26T03:24:51.243Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://dl.espressif.com/dl/package_esp32_index.json","https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\edsoo\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\edsoo\\OneDrive\\Documentos\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-10-26T03:24:51.243Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-10-26T03:24:51.243Z config INFO Loaded the CLI configuration.
2024-10-26T03:24:51.246Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/edsoo/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/edsoo/OneDrive/Documentos/Arduino","additionalUrls":["https://dl.espressif.com/dl/package_esp32_index.json","https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json"],"network":"none","locale":"en"}
2024-10-26T03:24:51.246Z config INFO Validating the CLI configuration...
2024-10-26T03:24:51.247Z config INFO The CLI config is valid.
2024-10-26T03:24:51.247Z config INFO <<< Initialized the CLI configuration.
2024-10-26T03:24:51.264Z root INFO Resolve plugins list: 40.4 ms [Finished 0.447 s after backend start]
2024-10-26T03:24:51.339Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="arduino-cli version 1.0.4"
time="2024-10-26T00:24:51-03:00" level=info msg="Using config file: c:\\Users\\edsoo\\.arduinoIDE\\arduino-cli.yaml"
time="2024-10-26T00:24:51-03:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:52075
{"IP":"127.0.0.1","Port":"52075"}
2024-10-26T03:24:51.339Z daemon INFO Daemon is running.
2024-10-26T03:24:51.429Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Checking signature" index="c:\\Users\\edsoo\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\edsoo\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-10-26T00:24:51-03:00" level=info msg="Missing signature file" index="c:\\Users\\edsoo\\AppData\\Local\\Arduino15\\package_esp32_index.json"
time="2024-10-26T00:24:51-03:00" level=info msg="Missing signature file" index="c:\\Users\\edsoo\\AppData\\Local\\Arduino15\\package_rp2040_index.json"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading hardware from: c:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading package arduino from: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-10-26T00:24:51-03:00" level=info msg="Missing signature file" index="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2024-10-26T00:24:51-03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-10-26T00:24:51-03:00" level=info msg="Missing signature file" index="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-20240930.arduino3\\installed.json"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded platform" platform="arduino:esp32@2.0.18-20240930.arduino3"
time="2024-10-26T00:24:51-03:00" level=info msg="Missing signature file" index="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.1.5\\installed.json"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded platform" platform="arduino:mbed_rp2040@4.1.5"
time="2024-10-26T00:24:51-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading tools from dir: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino2"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.10.0-arduino1"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="arduino:rp2040tools@1.0.6"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading package builtin from: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-10-26T00:24:51-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading tools from dir: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading package esp32 from: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2024-10-26T00:24:51-03:00" level=info msg="Missing signature file" index="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\installed.json"
2024-10-26T03:24:51.535Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded platform" platform="esp32:esp32@3.0.5"
time="2024-10-26T00:24:51-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading tools from dir: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2302"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2302"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:esp-xs2@2302"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:esp-xs3@2302"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.1-33fbade6"
2024-10-26T03:24:51.535Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.5.1"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.6"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
2024-10-26T03:24:51.539Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20230921"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20240821"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@11.2_20220823"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32s3-elf-gcc@esp-2021r2-patch5-8.4.0"
2024-10-26T03:24:51.541Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Loading package rp2040 from: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
2024-10-26T03:24:51.552Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Missing signature file" index="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\4.1.1\\installed.json"
2024-10-26T03:24:51.598Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded platform" platform="rp2040:rp2040@4.1.1"
time="2024-10-26T00:24:51-03:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loading tools from dir: C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@4.0.1-8ec9d6f"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc-riscv@4.0.1-8ec9d6f"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@4.0.1-8ec9d6f"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@4.0.1-8ec9d6f"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@4.0.1-8ec9d6f"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@4.0.1-8ec9d6f"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
time="2024-10-26T00:24:51-03:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed-1"
2024-10-26T03:24:51.616Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Searching tools required for platform rp2040:rp2040@4.1.1"
2024-10-26T03:24:51.624Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries" isSingleLibrary=false location=platform
time="2024-10-26T00:24:51-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\4.1.1\\libraries" isSingleLibrary=false location=platform
time="2024-10-26T00:24:51-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.18-20240930.arduino3\\libraries" isSingleLibrary=false location=platform
2024-10-26T03:24:51.661Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\mbed_rp2040\\4.1.5\\libraries" isSingleLibrary=false location=platform
time="2024-10-26T00:24:51-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2024-10-26T00:24:51-03:00" level=info msg="Loading libraries index file" index="c:\\Users\\edsoo\\AppData\\Local\\Arduino15\\library_index.json"
2024-10-26T03:24:51.842Z daemon INFO time="2024-10-26T00:24:51-03:00" level=info msg="Adding libraries dir" dir="C:\\Users\\edsoo\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-10-26T00:24:51-03:00" level=info msg="Adding libraries dir" dir="c:\\Users\\edsoo\\OneDrive\\Documentos\\Arduino\\libraries" isSingleLibrary=false location=user
2024-10-26T03:24:52.029Z root INFO Deploy plugins list: 40.4 ms [Finished 1.212 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-10-26T03:24:52.826Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 131.2 ms [Finished 1.515 s after frontend start]
2024-10-26T03:24:52.826Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-10-26T03:24:53.170Z discovery-log INFO start resolved watching
2024-10-26T03:24:53.174Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\edsoo\OneDrive\Área de Trabalho\equalizador\equalizador.ino>, response: <c:\Users\edsoo\OneDrive\Área de Trabalho\equalizador>.
2024-10-26T03:24:53.196Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 251.9 ms [Finished 1.916 s after frontend start]
2024-10-26T03:24:53.225Z root INFO Start frontend contributions: 587.5 ms [Finished 1.924 s after frontend start]
2024-10-26T03:24:53.227Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-10-26T03:24:53.251Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-10-26T03:24:53.251Z root INFO >>> Restoring the layout state...
2024-10-26T03:24:53.252Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-10-26T03:24:53.253Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/edsoo/OneDrive/%C3%81rea%20de%20Trabalho/equalizador/equalizador.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":9,\"column\":37},\"position\":{\"lineNumber\":9,\"column\":37}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":415,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":435,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":268},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"arduino-sketchbook-widget"}
2024-10-26T03:24:53.253Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-10-26T03:24:53.309Z root INFO [dbd1de59-b47e-4e7a-a74a-8cf14a6d28b0] Waiting for backend deployment: 110.4 ms [Finished 2.028 s after frontend start]
2024-10-26T03:24:53.486Z daemon INFO time="2024-10-26T00:24:53-03:00" level=error msg="Killing discovery process: TerminateProcess: Access is denied." discovery=rp2040
time="2024-10-26T00:24:53-03:00" level=error msg="Waiting discovery process termination: exit status 0xc0000409" discovery=rp2040
2024-10-26T03:24:53.486Z daemon INFO panic: runtime error: invalid memory address or nil pointer dereference
[signal 0xc0000005 code=0x0 addr=0x8 pc=0xee8938]
goroutine 25 [running]:
github.com/arduino/pluggable-discovery-protocol-handler/v2.(*Client).Run(0xc000942240)
        /go/pkg/mod/github.com/arduino/pluggable-discovery-protocol-handler/v2@v2.2.0/client.go:281 +0x198
github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).startDiscovery(0xc0000a83c0, 0xc000942240)
        /home/build/internal/arduino/discovery/discoverymanager/discoverymanager.go:203 +0x95
github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).Start.func2(0x694c206f7420676e?)
        /home/build/internal/arduino/discovery/discoverymanager/discoverymanager.go:105 +0x3c
created by github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).Start in goroutine 66
        /home/build/internal/arduino/discovery/discoverymanager/discoverymanager.go:104 +0x1ae
2024-10-26T03:24:53.489Z discovery-log INFO error received
2024-10-26T03:24:53.489Z discovery-log ERROR Unexpected error occurred during the boards discovery. Error: 14 UNAVAILABLE: read ECONNRESET
    at t.callErrorFromStatus (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:912720)
    at Object.onReceiveStatus (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:940342)
    at Object.onReceiveStatus (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:933364)
    at C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1019505
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at a.makeServerStreamRequest (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:940109)
    at a.boardListWatch (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at y.createWrapper (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:76587)
    at y.start (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:77659)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-10-26T03:24:53.489Z discovery-log INFO received end
2024-10-26T03:24:53.489Z daemon INFO Daemon exited with exit code: 2.
2024-10-26T03:24:53.768Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796) starting instance
2024-10-26T03:24:54.243Z root INFO [dbd1de59-b47e-4e7a-a74a-8cf14a6d28b0] Sync of 23 plugins: 936.0 ms [Finished 2.964 s after frontend start]
2024-10-26T03:24:59.566Z root INFO <<< The layout has been successfully restored.
2024-10-26T03:24:59.615Z root INFO Initialize the workbench layout: 6330.5 ms [Finished 8.287 s after frontend start]
2024-10-26T03:24:59.617Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-10-26T03:24:59.617Z root INFO [dbd1de59-b47e-4e7a-a74a-8cf14a6d28b0] Loading plugin contributions
2024-10-26T03:24:59.617Z root INFO [dbd1de59-b47e-4e7a-a74a-8cf14a6d28b0] Load contributions of 23 plugins: 46.8 ms [Finished 8.335 s after frontend start]
2024-10-26T03:24:59.626Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-10-26T03:24:59.626Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-10-26T03:24:59.726Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2024-10-26T03:24:59.726Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2024-10-26T03:24:59.726Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2024-10-26T03:24:59.726Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2024-10-26T03:24:59.726Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2024-10-26T03:24:59.727Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
2024-10-26T03:24:59.727Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
2024-10-26T03:24:59.727Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2024-10-26T03:24:59.727Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2024-10-26T03:24:59.727Z root ERROR [hosted-plugin: 8796] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-10-26T03:24:59.897Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): PluginManagerExtImpl/init()
2024-10-26T03:24:59.908Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-arduino-api@0.1.2 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.961Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(cortex-debug@1.5.1 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.961Z root INFO [hosted-plugin: 8796] Debugger contribution has been registered: cortex-debug
2024-10-26T03:24:59.961Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-arduino-tools@0.1.3 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.962Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(cpp@1.52.1 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.962Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(json@1.46.1 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.963Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(json-language-features@1.46.1 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.964Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-bg@1.48.3 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.964Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-cs@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.965Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-de@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.965Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-es@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.966Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-fr@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.966Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-hu@1.48.3 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.967Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-it@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.967Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-ja@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.967Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-ko@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.968Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.968Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-pl@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.968Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.969Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-ru@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.969Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-tr@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.970Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-uk@1.48.3 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.971Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:24:59.971Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2024-10-26T03:25:00.013Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): PluginManagerExtImpl/loadPlugin(C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-10-26T03:25:00.017Z root INFO [hosted-plugin: 8796] calling activation function on Arduino IDE API for VS Code extensions
2024-10-26T03:25:00.026Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): PluginManagerExtImpl/loadPlugin(C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-10-26T03:25:00.053Z root INFO [hosted-plugin: 8796] calling activation function on JSON Language Features (built-in)
2024-10-26T03:25:00.086Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): PluginManagerExtImpl/loadPlugin(C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2024-10-26T03:25:00.115Z root INFO [hosted-plugin: 8796] calling activation function on VS Code Arduino Tools
2024-10-26T03:25:00.143Z root INFO [dbd1de59-b47e-4e7a-a74a-8cf14a6d28b0] Starting plugins.
2024-10-26T03:25:00.150Z root INFO [hosted-plugin: 8796] PLUGIN_HOST(8796): PluginManagerExtImpl/loadPlugin(C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-10-26T03:25:00.183Z root INFO [hosted-plugin: 8796] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-10-26T03:25:00.183Z root INFO [hosted-plugin: 8796] calling activation function on Cortex-Debug
2024-10-26T03:25:00.186Z root INFO [hosted-plugin: 8796] GDB server console created
2024-10-26T03:25:00.195Z root INFO [dbd1de59-b47e-4e7a-a74a-8cf14a6d28b0] Start of 23 plugins: 574.7 ms [Finished 8.915 s after frontend start]
2024-10-26T03:25:01.655Z root INFO Frontend application start: 8867.0 ms [Finished 10.837 s after backend start]
Checking for update
2024-10-26T03:25:01.681Z root INFO Replace loading indicator with ready workbench UI (animation): 1630.8 ms [Finished 9.968 s after frontend start]
2024-10-26T03:25:01.684Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-10-26T03:25:01.684Z root WARN Linked preference "workbench.colorCustomizations" not found.
Update for version 2.3.3 is not available (latest version: 2.3.3, downgrade is allowed).
2024-10-26T03:25:21.341Z root ERROR Request loadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
    at Object.onReceiveStatus (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:938041)
    at Object.onReceiveStatus (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:933919)
    at processTicksAndRejections (node:internal/process/task_queues:77:11)
    at runNextTicks (node:internal/process/task_queues:64:3)
    at process.processImmediate (node:internal/timers:447:9)
for call at
    at a.makeUnaryRequest (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:937582)
    at a.loadSketch (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:835916
    at new Promise (<anonymous>)
    at B.doLoadSketch (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:835893)
2024-10-26T03:25:21.341Z root ERROR Request searchBoards failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at a.boardSearch (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:83505
    at y.handleListBoards (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:83484)
    at y.searchBoards (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:82894)
    at async u.onRequest (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1256308)
    at async c.handleRequest (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1247207)
2024-10-26T03:25:21.342Z root ERROR Request getInstalledBoards failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at a.boardListAll (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at y.getInstalledBoards (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:83069)
2024-10-26T03:25:21.342Z root ERROR Request search failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at a.platformSearch (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at n (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:85069)
    at y.search (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:85040)
for call at
    at a.libraryList (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at i (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:797066)
    at b.search (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:797044)
    at async r.value (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:3799)
2024-10-26T03:25:21.343Z root ERROR Request getSketchFolder failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at async B._isSketchFolder (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:841496)
    at async B.getSketchFolder (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:841331)
2024-10-26T03:25:21.343Z root ERROR Request getInstalledPlatforms failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:83227
    at y.getInstalledPlatforms (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:83204)
2024-10-26T03:25:21.344Z root ERROR Request getBoardUserFields failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at a.supportedUserFields (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at i (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:84743)
    at y.getBoardUserFields (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:84720)
2024-10-26T03:25:21.344Z root ERROR Request installed failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at c (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:798444)
    at b.list (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:798421)
    at async v.installed (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:786006)
2024-10-26T03:25:21.344Z root ERROR Request list failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-26T03:25:21.345Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at a.boardDetails (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at a (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:80998)
    at y.getBoardDetails (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:80976)
for call at
2024-10-26T03:25:21.346Z root ERROR Failed to update platform, library indexes. Error: 14 UNAVAILABLE: No connection established
for call at
    at a.updateIndex (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:771327
    at C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:771675
    at v.doUpdateIndex (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:771654)
    at v.updatePlatformIndex (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:771299)
    at v.updateIndex (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:770667)
    at D.updateIndex (C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:773358)
2024-10-26T03:25:21.346Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-26T03:25:21.347Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-26T03:25:21.347Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
for call at
2024-10-26T03:25:21.348Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
for call at
for call at
2024-10-26T03:25:21.350Z root ERROR Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-26T03:25:21.350Z sketches-service ERROR Unexpected error occurred while loading sketch from 'file:///c%3A/Users/edsoo/OneDrive/%C3%81rea%20de%20Trabalho/equalizador'. Error: 14 UNAVAILABLE: No connection established
for call at
    at async C:\Users\edsoo\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:838459
2024-10-26T03:25:21.350Z root ERROR Request markAsRecentlyOpened failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-26T03:25:21.353Z store ERROR An unexpected error occurred while retrieving the board details for rp2040:rp2040:rpipico2. Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-26T03:25:21.354Z root INFO Failed to start language server. Original FQBN: rp2040:rp2040:rpipico2 Error: 14 UNAVAILABLE: No connection established
for call at
I don't have access to a PC this weekend. Check if there is a solution in these search results : Search results for '#software:ide-2-x panic: runtime error' - Arduino Forum
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Starting backend process. PID: 8096
Configuration directory URI: 'file:///c%3A/Users/Amna/.arduinoIDE'
2024-10-26T08:57:38.767Z root INFO Backend Object.initialize: 4.7 ms [Finished 0.561 s after backend start]
2024-10-26T08:57:38.768Z root INFO Backend Object.configure: 3.7 ms [Finished 0.561 s after backend start]
2024-10-26T08:57:38.768Z root INFO Backend a.onStart: 1.9 ms [Finished 0.561 s after backend start]
2024-10-26T08:57:38.769Z root INFO Backend a.configure: 0.4 ms [Finished 0.586 s after backend start]
2024-10-26T08:57:38.770Z root INFO Backend d.onStart: 0.3 ms [Finished 0.586 s after backend start]
2024-10-26T08:57:38.770Z root INFO Backend d.configure: 0.1 ms [Finished 0.586 s after backend start]
2024-10-26T08:57:38.771Z root INFO Backend d.initialize: 24.5 ms [Finished 0.586 s after backend start]
2024-10-26T08:57:38.771Z root INFO Backend c.onStart: 0.3 ms [Finished 0.586 s after backend start]
2024-10-26T08:57:38.772Z root INFO Backend s.configure: 1.2 ms [Finished 0.587 s after backend start]
2024-10-26T08:57:38.773Z config INFO >>> Initializing CLI configuration...
2024-10-26T08:57:38.773Z root INFO Backend c.initialize: 0.6 ms [Finished 0.588 s after backend start]
2024-10-26T08:57:38.774Z root INFO Backend x.onStart: 0.8 ms [Finished 0.588 s after backend start]
2024-10-26T08:57:38.774Z config INFO Loading CLI configuration from c:\Users\Amna\.arduinoIDE\arduino-cli.yaml...
2024-10-26T08:57:38.775Z daemon INFO Starting daemon from C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-10-26T08:57:38.775Z root INFO Backend s.initialize: 0.4 ms [Finished 0.589 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend w.onStart: 1.2 ms [Finished 0.590 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend r.configure: 1.9 ms [Finished 0.590 s after backend start]
2024-10-26T08:57:38.775Z discovery-log INFO start
2024-10-26T08:57:38.775Z discovery-log INFO start new deferred
2024-10-26T08:57:38.775Z root INFO Backend d.initialize: 0.4 ms [Finished 0.591 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend y.onStart: 2.0 ms [Finished 0.592 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend r.configure: 1.7 ms [Finished 0.592 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend s.onStart: 0.4 ms [Finished 0.594 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend h.configure: 0.4 ms [Finished 0.594 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend a.configure: 0.1 ms [Finished 0.594 s after backend start]
2024-10-26T08:57:38.775Z root INFO Backend l.configure: 0.1 ms [Finished 0.594 s after backend start]
2024-10-26T08:57:38.778Z root INFO Theia app listening on http://127.0.0.1:50367.
2024-10-26T08:57:38.778Z root INFO Finished starting backend application: 2.9 ms [Finished 0.596 s after backend start]
2024-10-26T08:57:38.779Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Amna/.arduinoIDE/plugins does not exist.
2024-10-26T08:57:38.779Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Amna/.arduinoIDE/extensions does not exist.
2024-10-26T08:57:38.779Z root WARN The local plugin referenced by local-dir:C:\Users\Amna\.arduinoIDE\plugins does not exist.
2024-10-26T08:57:38.788Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json","https://raw.githubusercontent.com/RAKwireless/RAKwireless-Arduino-BSP-Index/main/package_rakwireless_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\Amna\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\Amna\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Amna\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\Amna\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-10-26T08:57:38.788Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-10-26T08:57:38.788Z config INFO Loaded the CLI configuration.
Restoring workspace roots: h:\.shortcut-targets-by-id\1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH\1 Jon - Amna shared folder\Code\firmware_0_5_0
isTempSketch: false. Input was h:\.shortcut-targets-by-id\1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH\1 Jon - Amna shared folder\Code\firmware_0_5_0\autoSeq.ino
2024-10-26T08:57:38.807Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Amna/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Amna/Documents/Arduino","additionalUrls":["https://github.com/earlephilhower/arduino-pico/releases/download/global/package_rp2040_index.json","https://raw.githubusercontent.com/RAKwireless/RAKwireless-Arduino-BSP-Index/main/package_rakwireless_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"],"network":"none","locale":"en"}
2024-10-26T08:57:38.807Z config INFO Validating the CLI configuration...
2024-10-26T08:57:38.808Z config INFO The CLI config is valid.
2024-10-26T08:57:38.808Z config INFO <<< Initialized the CLI configuration.
2024-10-26T08:57:38.829Z root INFO Resolve plugins list: 55.2 ms [Finished 0.647 s after backend start]
2024-10-26T08:57:39.069Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="arduino-cli version 1.0.4"
time="2024-10-26T13:57:39+05:00" level=info msg="Using config file: c:\\Users\\Amna\\.arduinoIDE\\arduino-cli.yaml"
time="2024-10-26T13:57:39+05:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:50368
{"IP":"127.0.0.1","Port":"50368"}
2024-10-26T08:57:39.070Z daemon INFO Daemon is running.
2024-10-26T08:57:39.159Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Checking signature" index="c:\\Users\\Amna\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\Amna\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="c:\\Users\\Amna\\AppData\\Local\\Arduino15\\package_rp2040_index.json"
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="c:\\Users\\Amna\\AppData\\Local\\Arduino15\\package_rakwireless_index.json"
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="c:\\Users\\Amna\\AppData\\Local\\Arduino15\\package_esp32_index.json"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading hardware from: c:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading package arduino from: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
2024-10-26T08:57:39.223Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\installed.json"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded platform" platform="arduino:renesas_uno@1.2.1"
time="2024-10-26T13:57:39+05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading tools from dir: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="arduino:arm-none-eabi-gcc@7-2017q4"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="arduino:bossac@1.9.1-arduino5"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="arduino:openocd@0.11.0-arduino2"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading package builtin from: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-10-26T13:57:39+05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading tools from dir: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading package esp32 from: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\installed.json"
2024-10-26T08:57:39.379Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded platform" platform="esp32:esp32@3.0.5"
time="2024-10-26T13:57:39+05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading tools from dir: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2302"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2302"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:esp-xs2@2302"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:esp-xs3@2302"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.1-33fbade6"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.6"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20240821"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@12.1_20231023"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@12.1_20231023"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading package rakwireless from: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rakwireless\\hardware"
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rakwireless\\hardware\\esp32\\2.0.3\\installed.json"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded platform" platform="rakwireless:esp32@2.0.3"
time="2024-10-26T13:57:39+05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rakwireless\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading tools from dir: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rakwireless\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rakwireless:esptool_py@3.1.0"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rakwireless:mklittlefs@3.0.0-gnu12-dc7f933"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rakwireless:mkspiffs@0.2.3"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rakwireless:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r1"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rakwireless:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r1"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rakwireless:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r1"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading package rp2040 from: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
time="2024-10-26T13:57:39+05:00" level=info msg="Missing signature file" index="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\4.0.2\\installed.json"
2024-10-26T08:57:39.495Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded platform" platform="rp2040:rp2040@4.0.2"
time="2024-10-26T13:57:39+05:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loading tools from dir: C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@2.2.0-d04e724"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@2.2.0-8a9af99-2"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@2.2.0-8a9af99-2"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@2.2.0-efe2103"
time="2024-10-26T13:57:39+05:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
time="2024-10-26T13:57:39+05:00" level=info msg="Searching tools required for platform rp2040:rp2040@4.0.2"
time="2024-10-26T13:57:39+05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rakwireless\\hardware\\esp32\\2.0.3\\libraries" isSingleLibrary=false location=platform
2024-10-26T08:57:39.497Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.0.5\\libraries" isSingleLibrary=false location=platform
2024-10-26T08:57:39.509Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.2.1\\libraries" isSingleLibrary=false location=platform
time="2024-10-26T13:57:39+05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
2024-10-26T08:57:39.514Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\4.0.2\\libraries" isSingleLibrary=false location=platform
time="2024-10-26T13:57:39+05:00" level=info msg="Loading libraries index file" index="c:\\Users\\Amna\\AppData\\Local\\Arduino15\\library_index.json"
2024-10-26T08:57:39.745Z daemon INFO time="2024-10-26T13:57:39+05:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Amna\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-10-26T13:57:39+05:00" level=info msg="Adding libraries dir" dir="c:\\Users\\Amna\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-10-26T08:57:39.891Z root INFO Deploy plugins list: 55.2 ms [Finished 1.709 s after backend start]
2024-10-26T08:57:40.822Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 142.3 ms [Finished 1.929 s after frontend start]
2024-10-26T08:57:40.822Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-10-26T08:57:41.711Z discovery-log INFO start resolved watching
2024-10-26T08:57:41.871Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <h:\.shortcut-targets-by-id\1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH\1 Jon - Amna shared folder\Code\firmware_0_5_0\autoSeq.ino>, response: <h:\.shortcut-targets-by-id\1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH\1 Jon - Amna shared folder\Code\firmware_0_5_0>.
2024-10-26T08:57:41.903Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 920.9 ms [Finished 3.044 s after frontend start]
2024-10-26T08:57:41.932Z root INFO Start frontend contributions: 1331.3 ms [Finished 3.052 s after frontend start]
2024-10-26T08:57:41.932Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-10-26T08:57:41.960Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-10-26T08:57:41.961Z root INFO >>> Restoring the layout state...
2024-10-26T08:57:41.963Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-10-26T08:57:41.963Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/firmware_0_5_0.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":70,\"column\":7},\"position\":{\"lineNumber\":70,\"column\":11}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":47,\"column\":1},\"firstPositionDeltaTop\":-2},\"contributionsState\":{\"editor.contrib.findController\":{\"widgetViewZoneVisible\":false,\"scrollTop\":938},\"editor.contrib.folding\":{\"lineCount\":308,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/autoSeq.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":64,\"column\":9},\"position\":{\"lineNumber\":64,\"column\":28}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":44,\"column\":1},\"firstPositionDeltaTop\":-5},\"contributionsState\":{\"editor.contrib.findController\":{\"widgetViewZoneVisible\":false,\"scrollTop\":855},\"editor.contrib.folding\":{\"lineCount\":196,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":true}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/autoSeq1.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":26,\"column\":18},\"position\":{\"lineNumber\":26,\"column\":18}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":388,\"column\":1},\"firstPositionDeltaTop\":-11},\"contributionsState\":{\"editor.contrib.findController\":{\"widgetViewZoneVisible\":false,\"scrollTop\":7364},\"editor.contrib.folding\":{\"lineCount\":428,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/autoSeq2.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":true,\"selectionStart\":{\"lineNumber\":1019,\"column\":18},\"position\":{\"lineNumber\":1019,\"column\":29}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":999,\"column\":1},\"firstPositionDeltaTop\":-11},\"contributionsState\":{\"editor.contrib.findController\":{\"widgetViewZoneVisible\":false,\"scrollTop\":19006},\"editor.contrib.folding\":{\"lineCount\":1039,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":true}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/autoSeq3.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":354,\"column\":6},\"position\":{\"lineNumber\":354,\"column\":6}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":327,\"column\":1},\"firstPositionDeltaTop\":-11},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":367,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/batteryCode.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":82,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/errorCode.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":39,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/flowCode.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":45,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///h%3A/.shortcut-targets-by-id/1-WfKZJ4bEXuS5a7D6G4IrYcfyfDZSaYH/1%20Jon%20-%20Amna%20shared%20folder/Code/firmware_0_5_0/motor2Code.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":1,\"column\":1},\"position\":{\"lineNumber\":1,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":41,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":4}},"mainPanelPinned":[false,false,false,false,false,false,false,false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":127,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"},\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"},\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"},\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2024-10-26T08:57:41.963Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-10-26T08:57:41.993Z root INFO [84ce7533-7ef9-4121-a4c4-c6f8f4cf70f1] Waiting for backend deployment: 86.5 ms [Finished 3.132 s after frontend start]
2024-10-26T08:57:42.214Z daemon INFO time="2024-10-26T13:57:42+05:00" level=error msg="Killing discovery process: TerminateProcess: Access is denied." discovery=rp2040
time="2024-10-26T13:57:42+05:00" level=error msg="Waiting discovery process termination: exit status 0xc0000409" discovery=rp2040
2024-10-26T08:57:42.617Z daemon INFO panic: runtime error: invalid memory address or nil pointer dereference
[signal 0xc0000005 code=0x0 addr=0x8 pc=0x1128938]
goroutine 29 [running]:
github.com/arduino/pluggable-discovery-protocol-handler/v2.(*Client).Run(0xc00038ac60)
github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).startDiscovery(0xc0001d9540, 0xc00038ac60)
github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).Start.func2(0xc903240c903240c?)
created by github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).Start in goroutine 39
2024-10-26T08:57:42.632Z discovery-log INFO error received
2024-10-26T08:57:42.632Z discovery-log ERROR Unexpected error occurred during the boards discovery. Error: 14 UNAVAILABLE: read ECONNRESET
    at t.callErrorFromStatus (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:912720)
    at Object.onReceiveStatus (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:940342)
    at Object.onReceiveStatus (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:933364)
    at C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1019505
for call at
    at a.makeServerStreamRequest (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:940109)
    at a.boardListWatch (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at y.createWrapper (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:76587)
    at y.start (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:77659)
2024-10-26T08:57:42.632Z discovery-log INFO received end
2024-10-26T08:57:42.632Z root ERROR Request getSketchFolder failed with error: 14 UNAVAILABLE: read ECONNRESET Error: 14 UNAVAILABLE: read ECONNRESET
    at Object.onReceiveStatus (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:938041)
    at Object.onReceiveStatus (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:933919)
for call at
    at a.makeUnaryRequest (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:937582)
    at a.loadSketch (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
    at C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:835916
    at B.doLoadSketch (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:835893)
    at async B._isSketchFolder (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:841496)
    at async B.getSketchFolder (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:841331)
    at async u.onRequest (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1256308)
    at async c.handleRequest (C:\Users\Amna\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1247207)
2024-10-26T08:57:42.632Z daemon INFO Daemon exited with exit code: 2.
2024-10-26T08:57:42.632Z root INFO [hosted-plugin: 12444] PLUGIN_HOST(12444) starting instance
2024-10-26T08:57:43.166Z root INFO [84ce7533-7ef9-4121-a4c4-c6f8f4cf70f1] Sync of 23 plugins: 1175.4 ms [Finished 4.308 s after frontend start]
I m facing same issue, here is the output of powershell. Arduino keeps on loading but doesn't display GUI, just white screen.
These issues started from the time I upgraded from 2.3.2 to 2.3.3.
Thank You
Hi @amna09! I could solve my issue by downloading the version 2.3.2 again in Release 2.3.2 · arduino/arduino-ide · GitHub
It's working very well in this version, but I don't know any solution to the new version 2.3.3.
@sterretje Thank you a lot, I could find the version 2.3.2 in the search results that you indicated.
I tried same and it is working with 2.3.2, I tried earlier to search for previous version but couldn't find it. Thank You for the link
Hi @edson81 and @amna09. I know you were already able to work around the problem by switching to using Arduino IDE 2.3.2, but I wanted to add a note here that the Arduino developers have already prepared a fix for the bug of Arduino IDE freezing if a pluggable discovery tool crashes:
So hopefully at least the next version of Arduino IDE won't have this issue.
Note that this doesn't address the question of why the "Raspberry Pi Pico/RP2040" boards platform's pluggable discovery tool is crashing on your computer. That is a 3rd party platform so the responsibility for fixing the bug in its pluggable discovery tool is the responsibility of the maintainers of that project, not of the Arduino developers. However, the inability of Arduino IDE to gracefully handle the crash of a pluggable discovery tool is a secondary bug in the Arduino software and that bug is what has been addressed by the fix I mentioned above.
