Hello all !
Let me sum up my many attempts with the famous forumula : ' doesn't work ! ’...
and I can't find any example here of a case as hopeless as mine...
i.e. : OK the IDE installs, but it's just a dead window.
examples ?
1- no card available, AVR core seems to be not pre-installed
2- preferences : are never saved ! whether it's trying to load a 3rd party pack in url for example https://espressif.github.io/arduino-esp32/package_esp32_index.json (just to show I'm not a total newbee !)
or to change language...
even after closing/reopening, nothing has been taken into account...
Please help ... please !
(W10 - with IDE 1.8.3 installed elsewhere)
TIA... Phil
here the powershell as advised. frightening !
PS C:\Program-Adds\Arduino IDE2> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program-Adds\Arduino IDE2\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 17492
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/Phi/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-22T11:12:40.870Z root INFO Backend Object.initialize: 6.2 ms [Finished 0.742 s after backend start]
2024-10-22T11:12:40.871Z root INFO Backend Object.configure: 4.4 ms [Finished 0.742 s after backend start]
2024-10-22T11:12:40.871Z root INFO Backend a.onStart: 2.2 ms [Finished 0.742 s after backend start]
2024-10-22T11:12:40.872Z root INFO Backend a.configure: 0.4 ms [Finished 0.772 s after backend start]
2024-10-22T11:12:40.873Z root INFO Backend d.onStart: 0.3 ms [Finished 0.772 s after backend start]
2024-10-22T11:12:40.874Z root INFO Backend d.configure: 0.2 ms [Finished 0.773 s after backend start]
2024-10-22T11:12:40.876Z root INFO Backend d.initialize: 30.5 ms [Finished 0.773 s after backend start]
2024-10-22T11:12:40.876Z root INFO Backend c.onStart: 0.3 ms [Finished 0.773 s after backend start]
2024-10-22T11:12:40.877Z root INFO Backend s.configure: 1.7 ms [Finished 0.775 s after backend start]
2024-10-22T11:12:40.879Z config INFO >>> Initializing CLI configuration...
2024-10-22T11:12:40.879Z root INFO Backend c.initialize: 0.8 ms [Finished 0.775 s after backend start]
2024-10-22T11:12:40.879Z root INFO Backend x.onStart: 1.1 ms [Finished 0.776 s after backend start]
2024-10-22T11:12:40.881Z config INFO Loading CLI configuration from c:\Users\Phi\.arduinoIDE\arduino-cli.yaml...
2024-10-22T11:12:40.881Z daemon INFO Starting daemon from C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\resources\arduino-cli.exe...
2024-10-22T11:12:40.881Z root INFO Backend s.initialize: 0.6 ms [Finished 0.777 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend w.onStart: 1.8 ms [Finished 0.778 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend r.configure: 2.8 ms [Finished 0.779 s after backend start]
2024-10-22T11:12:40.882Z discovery-log INFO start
2024-10-22T11:12:40.882Z discovery-log INFO start new deferred
2024-10-22T11:12:40.882Z root INFO Backend d.initialize: 0.6 ms [Finished 0.779 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend y.onStart: 3.1 ms [Finished 0.782 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend r.configure: 2.7 ms [Finished 0.782 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend s.onStart: 0.8 ms [Finished 0.784 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend h.configure: 0.8 ms [Finished 0.784 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend a.configure: 0.2 ms [Finished 0.785 s after backend start]
2024-10-22T11:12:40.882Z root INFO Backend l.configure: 0.1 ms [Finished 0.785 s after backend start]
2024-10-22T11:12:40.887Z root INFO Theia app listening on http://127.0.0.1:10469.
2024-10-22T11:12:40.887Z root INFO Finished starting backend application: 5.1 ms [Finished 0.790 s after backend start]
2024-10-22T11:12:40.888Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Phi/.arduinoIDE/plugins does not exist.
2024-10-22T11:12:40.888Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Phi/.arduinoIDE/extensions does not exist.
2024-10-22T11:12:40.888Z root WARN The local plugin referenced by local-dir:C:\Users\Phi\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\Phi\Desktop\sketch_oct22a
isTempSketch: false. Input was c:\Users\Phi\Desktop\sketch_oct22a\sketch_oct22a.ino
2024-10-22T11:12:40.921Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2024-10-22T11:12:40.921Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2024-10-22T11:12:40.971Z root INFO Resolve plugins list: 90.7 ms [Finished 0.873 s after backend start]
2024-10-22T11:12:41.205Z daemon INFO time="2024-10-22T13:12:41+02:00" level=info msg="arduino-cli version 1.0.4"
time="2024-10-22T13:12:41+02:00" level=info msg="Using config file: c:\\Users\\Phi\\.arduinoIDE\\arduino-cli.yaml"
time="2024-10-22T13:12:41+02:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:10471
{"IP":"127.0.0.1","Port":"10471"}
2024-10-22T11:12:41.205Z daemon INFO Daemon is running.
2024-10-22T11:12:41.206Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"E:\\Documents\\Arduino","data":"C:\\Users\\Phi\\AppData\\Local\\Arduino15"}}
2024-10-22T11:12:41.206Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"E:\\Documents\\Arduino","data":"C:\\Users\\Phi\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2024-10-22T11:12:41.206Z config INFO Loaded the CLI configuration.
2024-10-22T11:12:41.238Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Phi/AppData/Local/Arduino15","sketchDirUri":"file:///e%3A/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-10-22T11:12:41.238Z config INFO Validating the CLI configuration...
2024-10-22T11:12:41.243Z config INFO The CLI config is valid.
2024-10-22T11:12:41.243Z config INFO <<< Initialized the CLI configuration.
2024-10-22T11:12:41.329Z daemon INFO time="2024-10-22T13:12:41+02:00" level=info msg="Checking signature" index="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2024-10-22T13:12:41+02:00" level=info msg="Loading hardware from: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading package arduino from: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2024-10-22T13:12:41+02:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-10-22T13:12:41+02:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading tools from dir: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading package builtin from: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2024-10-22T13:12:41+02:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading tools from dir: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading package esp32 from: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded platform" platform="esp32:esp32@1.0.6"
time="2024-10-22T13:12:41+02:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading tools from dir: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="esp32:esptool_py@3.0.0"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading package esp8266 from: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware"
2024-10-22T11:12:41.403Z daemon INFO time="2024-10-22T13:12:41+02:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded platform" platform="esp8266:esp8266@3.1.2"
time="2024-10-22T13:12:41+02:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading tools from dir: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="esp8266:mklittlefs@3.1.0-gcc10.3-e5f9fec"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="esp8266:mkspiffs@3.1.0-gcc10.3-e5f9fec"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="esp8266:python3@3.7.2-post1"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="esp8266:xtensa-lx106-elf-gcc@3.1.0-gcc10.3-e5f9fec"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading package rp2040 from: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded platform" platform="rp2040:rp2040@3.9.4"
time="2024-10-22T13:12:41+02:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
time="2024-10-22T13:12:41+02:00" level=info msg="Loading tools from dir: C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools"
2024-10-22T11:12:41.408Z daemon INFO time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-elf2uf2@2.2.0-d04e724"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@2.1.0-a-d3d2e6b"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-gcc@2.2.0-d04e724"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@2.1.0-a-d3d2e6b"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-mklittlefs@2.2.0-d04e724"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@2.1.0-a-d3d2e6b"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-openocd@2.2.0-d04e724"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-picotool@2.2.0-d04e724"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@2.1.0-a-d3d2e6b"
time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-pioasm@2.2.0-d04e724"
2024-10-22T11:12:41.411Z daemon INFO time="2024-10-22T13:12:41+02:00" level=info msg="Loaded tool" tool="rp2040:pqt-python3@1.0.1-base-3a57aed"
2024-10-22T11:12:41.473Z daemon INFO time="2024-10-22T13:12:41+02:00" level=info msg="Searching tools required for platform rp2040:rp2040@3.9.4"
time="2024-10-22T13:12:41+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries" isSingleLibrary=false location=platform
time="2024-10-22T13:12:41+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2024-10-22T13:12:41+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" isSingleLibrary=false location=platform
time="2024-10-22T13:12:41+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.9.4\\libraries" isSingleLibrary=false location=platform
time="2024-10-22T13:12:41+02:00" level=info msg="Loading libraries index file" index="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\library_index.json"
2024-10-22T11:12:41.780Z daemon INFO time="2024-10-22T13:12:41+02:00" level=info msg="Adding libraries dir" dir="C:\\Users\\Phi\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2024-10-22T13:12:41+02:00" level=info msg="Adding libraries dir" dir="E:\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2024-10-22T11:12:42.198Z root INFO Deploy plugins list: 90.7 ms [Finished 2.101 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-10-22T11:12:43.475Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 217.4 ms [Finished 2.448 s after frontend start]
2024-10-22T11:12:43.475Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-10-22T11:12:44.618Z discovery-log INFO start resolved watching
2024-10-22T11:12:44.629Z sketches-service WARN Warning! The request sketch path was different than the response sketch path from the CLI. This could be a potential bug. Request: <c:\Users\Phi\Desktop\sketch_oct22a\sketch_oct22a.ino>, response: <c:\Users\Phi\Desktop\sketch_oct22a>.
2024-10-22T11:12:44.669Z root WARN Frontend c.onStart took longer than the expected maximum 100 milliseconds: 978.2 ms [Finished 3.697 s after frontend start]
2024-10-22T11:12:44.732Z root INFO Start frontend contributions: 1582.3 ms [Finished 3.714 s after frontend start]
2024-10-22T11:12:44.732Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-10-22T11:12:44.781Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-10-22T11:12:44.782Z root INFO >>> Restoring the layout state...
2024-10-22T11:12:44.785Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-10-22T11:12:44.786Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/Phi/Desktop/sketch_oct22a/sketch_oct22a.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":9,\"column\":1},\"position\":{\"lineNumber\":9,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":9,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":52,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":true,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":268},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"boards-list-widget"}
2024-10-22T11:12:44.786Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-10-22T11:12:44.851Z root INFO [0bd6e1b8-8059-4c84-9bc4-8b1670de5da2] Waiting for backend deployment: 179.2 ms [Finished 3.879 s after frontend start]
2024-10-22T11:12:45.104Z daemon INFO time="2024-10-22T13:12:45+02:00" level=error msg="Killing discovery process: TerminateProcess: Acc├¿s refus├®." discovery=rp2040
time="2024-10-22T13:12:45+02:00" level=error msg="Waiting discovery process termination: exit status 0xc0000409" discovery=rp2040
2024-10-22T11:12:45.105Z daemon INFO panic: runtime error: invalid memory address or nil pointer dereference
[signal 0xc0000005 code=0x0 addr=0x8 pc=0x14e8938]
goroutine 85 [running]:
github.com/arduino/pluggable-discovery-protocol-handler/v2.(*Client).Run(0xc0003d8630)
/go/pkg/mod/github.com/arduino/pluggable-discovery-protocol-handler/v2@v2.2.0/client.go:281 +0x198
github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).startDiscovery(0xc0000a2410, 0xc0003d8630)
/home/build/internal/arduino/discovery/discoverymanager/discoverymanager.go:203 +0x95
github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).Start.func2(0x0?)
/home/build/internal/arduino/discovery/discoverymanager/discoverymanager.go:105 +0x3c
created by github.com/arduino/arduino-cli/internal/arduino/discovery/discoverymanager.(*DiscoveryManager).Start in goroutine 49
/home/build/internal/arduino/discovery/discoverymanager/discoverymanager.go:104 +0x1ae
2024-10-22T11:12:45.108Z discovery-log INFO error received
2024-10-22T11:12:45.108Z discovery-log ERROR Unexpected error occurred during the boards discovery. Error: 14 UNAVAILABLE: read ECONNRESET
at t.callErrorFromStatus (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:912720)
at Object.onReceiveStatus (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:940342)
at Object.onReceiveStatus (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:933364)
at C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1019505
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at a.makeServerStreamRequest (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:940109)
at a.boardListWatch (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1004397)
at y.createWrapper (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:76587)
at y.start (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:77659)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2024-10-22T11:12:45.108Z discovery-log INFO received end
2024-10-22T11:12:45.108Z daemon INFO Daemon exited with exit code: 2.
2024-10-22T11:12:45.564Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352) starting instance
2024-10-22T11:12:46.324Z root INFO [0bd6e1b8-8059-4c84-9bc4-8b1670de5da2] Sync of 23 plugins: 1478.1 ms [Finished 5.358 s after frontend start]
2024-10-22T11:12:46.766Z root INFO <<< The layout has been successfully restored.
2024-10-22T11:12:46.873Z root INFO Initialize the workbench layout: 2008.8 ms [Finished 5.799 s after frontend start]
2024-10-22T11:12:46.877Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-10-22T11:12:46.877Z root INFO [0bd6e1b8-8059-4c84-9bc4-8b1670de5da2] Loading plugin contributions
2024-10-22T11:12:46.879Z root INFO [0bd6e1b8-8059-4c84-9bc4-8b1670de5da2] Load contributions of 23 plugins: 102.0 ms [Finished 5.905 s after frontend start]
2024-10-22T11:12:46.895Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2024-10-22T11:12:46.896Z root WARN a registered grammar configuration for 'cpp' language is overridden
2024-10-22T11:12:47.410Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2024-10-22T11:12:47.410Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2024-10-22T11:12:47.410Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
2024-10-22T11:12:47.410Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2024-10-22T11:12:47.410Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2024-10-22T11:12:47.411Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2024-10-22T11:12:47.411Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2024-10-22T11:12:47.411Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
2024-10-22T11:12:47.411Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
2024-10-22T11:12:47.411Z root ERROR [hosted-plugin: 1352] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2024-10-22T11:12:47.481Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): PluginManagerExtImpl/init()
2024-10-22T11:12:47.489Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-arduino-api@0.1.2 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.610Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(cortex-debug@1.5.1 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.610Z root INFO [hosted-plugin: 1352] Debugger contribution has been registered: cortex-debug
2024-10-22T11:12:47.612Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-arduino-tools@0.1.3 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.616Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(cpp@1.52.1 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.624Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(json@1.46.1 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.626Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(json-language-features@1.46.1 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.629Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-bg@1.48.3 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.630Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-cs@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.638Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-de@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.642Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-es@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.644Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-fr@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.645Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-hu@1.48.3 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.646Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-it@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.648Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-ja@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.652Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-ko@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.656Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-nl@1.48.3 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.659Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-pl@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.661Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.662Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-ru@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.663Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-tr@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.665Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-uk@1.48.3 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.668Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.671Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\plugin-vscode-init)
2024-10-22T11:12:47.689Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): PluginManagerExtImpl/loadPlugin(C:\Program-Adds\Arduino IDE2\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2024-10-22T11:12:47.700Z root INFO [hosted-plugin: 1352] calling activation function on Arduino IDE API for VS Code extensions
2024-10-22T11:12:47.707Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): PluginManagerExtImpl/loadPlugin(C:\Program-Adds\Arduino IDE2\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2024-10-22T11:12:47.779Z root INFO [hosted-plugin: 1352] calling activation function on JSON Language Features (built-in)
2024-10-22T11:12:48.022Z root INFO Frontend application start: 4619.7 ms [Finished 7.924 s after backend start]
Checking for update
2024-10-22T11:12:48.079Z root INFO Replace loading indicator with ready workbench UI (animation): 872.7 ms [Finished 6.783 s after frontend start]
2024-10-22T11:12:48.079Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-10-22T11:12:48.079Z root WARN Linked preference "workbench.colorCustomizations" not found.
2024-10-22T11:12:48.118Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): PluginManagerExtImpl/loadPlugin(C:\Program-Adds\Arduino IDE2\resources\app\plugins\vscode-arduino-tools\extension\dist\extension.js)
2024-10-22T11:12:48.249Z root INFO [hosted-plugin: 1352] calling activation function on VS Code Arduino Tools
2024-10-22T11:12:48.302Z root INFO [0bd6e1b8-8059-4c84-9bc4-8b1670de5da2] Starting plugins.
2024-10-22T11:12:48.434Z root INFO [hosted-plugin: 1352] PLUGIN_HOST(1352): PluginManagerExtImpl/loadPlugin(C:\Program-Adds\Arduino IDE2\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <PID.pde> and sketch folder name <demo_PID_processing>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Mouse.pde> and sketch folder name <demo_PID_processing>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Screen.pde> and sketch folder name <demo_PID_processing>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Checkbox.pde> and sketch folder name <demo_PID_processing>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Variables.pde> and sketch folder name <demo_PID_processing>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <PID.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <record_V13_050823_GREAT!.ino> and sketch folder name <RECORDS>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Mouse.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Screen.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Checkbox.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <Variables.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.458Z sketches-service WARN Mismatching sketch file <controlePortail_NANO_VFinale2024.ino> and sketch folder name <controlePortail_NANO_VFinale2023_recol0324_up6>. Skipping
2024-10-22T11:12:48.459Z sketches-service WARN Mismatching sketch file <Mouse.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.459Z sketches-service WARN Mismatching sketch file <Screen.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.459Z sketches-service WARN Mismatching sketch file <Checkbox.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.459Z sketches-service WARN Mismatching sketch file <Variables.pde> and sketch folder name <source>. Skipping
2024-10-22T11:12:48.459Z sketches-service WARN Mismatching sketch file <controlePortail_NANO_VFinale2024.ino> and sketch folder name <controlePortail_NANO_VFinale2023_recol0324_up6>. Skipping
2024-10-22T11:12:48.499Z root INFO [hosted-plugin: 1352] Debug configuration provider has been registered: cortex-debug, trigger: 1
2024-10-22T11:12:48.501Z root INFO [hosted-plugin: 1352] calling activation function on Cortex-Debug
2024-10-22T11:12:48.514Z root INFO [hosted-plugin: 1352] GDB server console created
2024-10-22T11:12:48.538Z root INFO [0bd6e1b8-8059-4c84-9bc4-8b1670de5da2] Start of 23 plugins: 1654.0 ms [Finished 7.571 s after frontend start]
Update for version 2.3.3 is not available (latest version: 2.3.3, downgrade is allowed).
2024-10-22T11:13:11.221Z root ERROR Request loadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
at Object.onReceiveStatus (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:938041)
at Object.onReceiveStatus (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:933919)
at processTicksAndRejections (node:internal/process/task_queues:77:11)
at runNextTicks (node:internal/process/task_queues:64:3)
at process.processImmediate (node:internal/timers:447:9)
for call at
at a.makeUnaryRequest (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:937582)
at a.loadSketch (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1004397)
at C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:835916
at new Promise (<anonymous>)
at B.doLoadSketch (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:835893)
2024-10-22T11:13:11.222Z root ERROR Request search failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
at a.platformSearch (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1004397)
at n (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:85069)
at y.search (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:85040)
at async u.onRequest (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1256308)
at async c.handleRequest (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1247207)
2024-10-22T11:13:11.223Z root ERROR Request searchBoards failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
at a.boardSearch (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1004397)
at C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:83505
at y.handleListBoards (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:83484)
at y.searchBoards (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:82894)
2024-10-22T11:13:11.224Z root ERROR Request getInstalledBoards failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
at a.boardListAll (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1004397)
at y.getInstalledBoards (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:83069)
2024-10-22T11:13:11.225Z root ERROR Request getBoardPackage failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
at async y.getBoardPackage (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:82539)
2024-10-22T11:13:11.226Z root ERROR Request search failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.227Z root ERROR Request search failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
at a.libraryList (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1004397)
at i (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:797066)
at b.search (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:797044)
at async r.value (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:3799)
2024-10-22T11:13:11.228Z root ERROR Request getSketchFolder failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
at async B._isSketchFolder (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:841496)
at async B.getSketchFolder (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:841331)
2024-10-22T11:13:11.231Z root ERROR Request installed failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
at c (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:798444)
at b.list (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:798421)
at async v.installed (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:786006)
2024-10-22T11:13:11.231Z root ERROR Request list failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.232Z root ERROR Failed to update platform, library indexes. Error: 14 UNAVAILABLE: No connection established
for call at
at a.updateIndex (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:1004397)
at C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:771327
at C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:771675
at v.doUpdateIndex (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:771654)
at v.updatePlatformIndex (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:771299)
at v.updateIndex (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:770667)
at D.updateIndex (C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:773358)
2024-10-22T11:13:11.234Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.235Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.236Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.237Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.238Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.239Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.240Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.241Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.243Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.244Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.245Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.246Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.247Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
for call at
2024-10-22T11:13:11.248Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.250Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.287Z root ERROR Error: 14 UNAVAILABLE: No connection established
for call at
2024-10-22T11:13:11.289Z sketches-service ERROR Unexpected error occurred while loading sketch from 'file:///c%3A/Users/Phi/Desktop/sketch_oct22a'. Error: 14 UNAVAILABLE: No connection established
for call at
at async C:\Program-Adds\Arduino IDE2\resources\app\lib\backend\main.js:2:838459
2024-10-22T11:13:11.289Z root ERROR Request markAsRecentlyOpened failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
