Trying to open a Sketch to blink the on board LED
No connection established
Compilation error: No connection established
Care to elaborate?
You might want to look at this How to get the best out of this forum before you proceed any further.
We only know what you tell us, and without knowing what you have, we don't stand a chance.
So far you have told us nothing useful.
Hi @blanco. Please add a forum reply here to tell us which operating system you are using (e.g., "Windows")?
I ask because I would like to give you the appropriate instructions for your operating system.
Appreciate the help, I am using windows 10
I started my journey watching Rachel De Barros the light was working and it would print hello world. But when I went to adding the ESP 32 software, it all stopped. I started looking for help and that is how I ended up here.
My device maneger panel shows three com ports:
Communication port (com1)
Intel(R) Active management technology Sol (com 4)
USB serial device (com3)
On my IED board selection Arduino uno com3
The ESP32 board I ordered from amazon came three to a pack. I did not post the link cause I think I read we are not support to insert links. The uno board was given to me by my son a couple of years ago and its blue. I ordered an ESP32 board from Arduino should be in tomorrow. Thanks again for any help you can give me.
I'm going to ask you to provide some additional information that might help us to identify the problem.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Select File > Quit from the Arduino IDE menus if it is running.
    All Arduino IDE windows will close.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
    A context menu will open.
  5. Select "Open PowerShell window here" from the menu.
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait for Arduino IDE to finish starting.
  9. Perform whatever operation you did before when you encountered that "Compilation error: No connection established" error.
  10. Wait for the "Compilation error: No connection established" error to occur.
  11. Switch back to the PowerShell window.
  12. Press the Ctrl+Shift+A keyboard shortcut.
    This will select all the text in the PowerShell window.
  13. Press the Ctrl+C keyboard shortcut.
    This will copy the contents of the PowerShell window to the clipboard.
  14. Open a forum reply here by clicking the "Reply" button.
  15. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  16. Press the Ctrl+V keyboard shortcut.
    This will paste the output into the code block.
  17. Move the cursor outside of the code block markup before you add any additional text to your reply.
  18. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Have you installed the board manger ?
You need this before it will work with this board .
Read me
I think I was installing the board manager when it stoped working. I have no Libraries I put in the hello world scketch but it will not verify. And its showing : downloading : package.index.tar.bz2
But its not downloading like maybe lost comunication. I deleted the IDE from my computer hoping to start a new but when I downloaded the IDE again and opened it and downloading: package.index.tar.bz2 is still on the monitor screen. Thanks
OH WOW! Ill try and follow this instruction.
I was able to go as far as :users-leblanc-arduinoIDE
it gave me a couple of folders, one -global storage-location cache and a few more and a couple of JSON Files. but no exe. file or folder. and I have hiden items checked and file extensions
I tried it before deleting the program and reloading it I will do it again tomorrow.
This is expected. Arduino IDE stores some data files in C:\Users\leblanc\.arduinoIDE. This is not the Arduino IDE installation folder.
Please look in the specific locations I mentioned in my instructions:
If you don't find the Arduino IDE.exe file in either of those locations, let us know and we'll help you figure out where Arduino IDE is installed on your computer.
Okay I found the exe file, will try and follow your instruction you previously sent. I also did some google search and found that many others had something similar and that is that ( downloading index: package_index.tar.bz2 ) stopped downloading in the middle of the file download.
OH, I deleted the program and reinstalled it and it stropped in the same place.
```Hmm. When I push (control+shift+A) it does not high light the text I (klick) Ctrl + C then I go to the reply <code> it do not see it type anything.`Use codeS C:\Program Files\Arduino IDE> &".\Arduino IDE"
PS C:\Program Files\Arduino IDE> ^C
PS C:\Program Files\Arduino IDE> C^C
PS C:\Program Files\Arduino IDE>  configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 524
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/leblanc/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-02-19T04:28:04.895Z root INFO Backend Object.initialize: 12.0 ms [Finished 1.660 s after backend start]
2025-02-19T04:28:04.897Z root INFO Backend Object.configure: 9.5 ms [Finished 1.660 s after backend start]
2025-02-19T04:28:04.897Z root INFO Backend s.onStart: 5.3 ms [Finished 1.660 s after backend start]
2025-02-19T04:28:04.899Z root INFO Backend s.configure: 0.9 ms [Finished 1.726 s after backend start]
2025-02-19T04:28:04.900Z root INFO Backend d.onStart: 0.7 ms [Finished 1.726 s after backend start]
2025-02-19T04:28:04.902Z root INFO Backend d.configure: 0.4 ms [Finished 1.726 s after backend start]
2025-02-19T04:28:04.904Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 66.2 ms [Finished 1.727 s after backend start]
2025-02-19T04:28:04.904Z root INFO Backend c.onStart: 1.0 ms [Finished 1.727 s after backend start]
2025-02-19T04:28:04.906Z root INFO Backend a.configure: 3.0 ms [Finished 1.731 s after backend start]
2025-02-19T04:28:04.910Z config INFO >>> Initializing CLI configuration...
2025-02-19T04:28:04.911Z root INFO Backend c.initialize: 1.4 ms [Finished 1.731 s after backend start]
2025-02-19T04:28:04.911Z root INFO Backend x.onStart: 2.0 ms [Finished 1.733 s after backend start]
2025-02-19T04:28:04.913Z config INFO Loading CLI configuration from c:\Users\leblanc\.arduinoIDE\arduino-cli.yaml...
2025-02-19T04:28:04.914Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-02-19T04:28:04.914Z root INFO Backend a.initialize: 1.2 ms [Finished 1.735 s after backend start]
2025-02-19T04:28:04.914Z root INFO Backend w.onStart: 2.9 ms [Finished 1.737 s after backend start]
2025-02-19T04:28:04.915Z root INFO Backend r.configure: 4.6 ms [Finished 1.737 s after backend start]
2025-02-19T04:28:04.915Z discovery-log INFO start
2025-02-19T04:28:04.915Z discovery-log INFO start new deferred
2025-02-19T04:28:04.915Z root INFO Backend d.initialize: 1.4 ms [Finished 1.739 s after backend start]
2025-02-19T04:28:04.915Z root INFO Backend y.onStart: 5.6 ms [Finished 1.743 s after backend start]
2025-02-19T04:28:04.915Z root INFO Backend r.configure: 4.6 ms [Finished 1.744 s after backend start]
2025-02-19T04:28:04.915Z root INFO Backend a.onStart: 1.3 ms [Finished 1.747 s after backend start]
2025-02-19T04:28:04.915Z root INFO Backend h.configure: 1.1 ms [Finished 1.747 s after backend start]
2025-02-19T04:28:04.916Z root INFO Backend s.configure: 0.4 ms [Finished 1.748 s after backend start]
2025-02-19T04:28:04.916Z root INFO Backend l.configure: 0.2 ms [Finished 1.748 s after backend start]
2025-02-19T04:28:04.924Z root INFO Theia app listening on http://127.0.0.1:52663.
2025-02-19T04:28:04.925Z root INFO Finished starting backend application: 9.7 ms [Finished 1.757 s after backend start]
2025-02-19T04:28:04.927Z root WARN The local plugin referenced by local-dir:/c%3A/Users/leblanc/.arduinoIDE/plugins does not exist.
2025-02-19T04:28:04.927Z root WARN The local plugin referenced by local-dir:/c%3A/Users/leblanc/.arduinoIDE/extensions does not exist.
2025-02-19T04:28:04.927Z root WARN The local plugin referenced by local-dir:C:\Users\leblanc\.arduinoIDE\plugins does not exist.
2025-02-19T04:28:04.961Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["://raw.githubusercontent.com/esp...","https https://raw.githubusercontent.com/ric..."]},"directories":{"builtin":{"libraries":"C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\leblanc\\AppData\\Local\\Arduino15","user":"c:\\Users\\leblanc\\Documents\\Arduino"},"locale":"en"}
2025-02-19T04:28:04.961Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-02-19T04:28:04.961Z config INFO Loaded the CLI configuration.
2025-02-19T04:28:04.984Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/leblanc/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/leblanc/Documents/Arduino","additionalUrls":["://raw.githubusercontent.com/esp...","https https://raw.githubusercontent.com/ric..."],"network":"none","locale":"en"}
2025-02-19T04:28:04.984Z config INFO Validating the CLI configuration...
2025-02-19T04:28:04.986Z config INFO The CLI config is valid.
2025-02-19T04:28:04.986Z config INFO <<< Initialized the CLI configuration.
2025-02-19T04:28:05.035Z root INFO Resolve plugins list: 121.9 ms [Finished 1.866 s after backend start]
2025-02-19T04:28:05.329Z daemon INFO time="2025-02-18T22:28:05-06:00" level=info msg="arduino-cli version 1.1.1"
time="2025-02-18T22:28:05-06:00" level=info msg="Using config file: c:\\Users\\leblanc\\.arduinoIDE\\arduino-cli.yaml"
time="2025-02-18T22:28:05-06:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:52664
{"IP":"127.0.0.1","Port":"52664"}
2025-02-19T04:28:05.329Z daemon INFO Daemon is running.
2025-02-19T04:28:05.387Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Invalid additional URL: parse "://raw.githubusercontent.com/esp...": missing protocol scheme
2025-02-19T04:28:05.389Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Invalid additional URL: parse "https https://raw.githubusercontent.com/ric...": first path segment in URL cannot contain colon
2025-02-19T04:28:05.535Z daemon INFO time="2025-02-18T22:28:05-06:00" level=info msg="Checking signature" index="c:\\Users\\leblanc\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="c:\\Users\\leblanc\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
time="2025-02-18T22:28:05-06:00" level=info msg="Loading hardware from: c:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages"
time="2025-02-18T22:28:05-06:00" level=info msg="Loading package arduino from: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware"
time="2025-02-18T22:28:05-06:00" level=info msg="Missing signature file" index="C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json"
time="2025-02-18T22:28:05-06:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2025-02-18T22:28:05-06:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-02-18T22:28:05-06:00" level=info msg="Loading tools from dir: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\arduino\\tools"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="arduino:dfu-util@0.11.0-arduino5"
time="2025-02-18T22:28:05-06:00" level=info msg="Loading package builtin from: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\builtin"
time="2025-02-18T22:28:05-06:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-02-18T22:28:05-06:00" level=info msg="Loading tools from dir: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\builtin\\tools"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2025-02-18T22:28:05-06:00" level=info msg="Loading package esp32 from: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware"
time="2025-02-18T22:28:05-06:00" level=info msg="Missing signature file" index="C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\installed.json"
2025-02-19T04:28:05.958Z daemon INFO time="2025-02-18T22:28:05-06:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded platform" platform="esp32:esp32@3.1.1"
time="2025-02-18T22:28:05-06:00" level=info msg="Checking existence of 'tools' path: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2025-02-18T22:28:05-06:00" level=info msg="Loading tools from dir: C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\esp32\\tools"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:esp-rv32@2405"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:esp-x32@2405"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:esp32-arduino-libs@idf-release_v5.3-cfea4f7c-v1"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:esptool_py@4.9.dev3"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:mkspiffs@0.2.3"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:openocd-esp32@v0.12.0-esp32-20241016"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:riscv32-esp-elf-gdb@14.2_20240403"
time="2025-02-18T22:28:05-06:00" level=info msg="Loaded tool" tool="esp32:xtensa-esp-elf-gdb@14.2_20240403"
time="2025-02-18T22:28:05-06:00" level=info msg="Adding libraries dir" dir="C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.1.1\\libraries" isSingleLibrary=false location=platform
time="2025-02-18T22:28:05-06:00" level=info msg="Adding libraries dir" dir="C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" isSingleLibrary=false location=platform
time="2025-02-18T22:28:05-06:00" level=info msg="Loading libraries index file" index="c:\\Users\\leblanc\\AppData\\Local\\Arduino15\\library_index.json"
2025-02-19T04:28:06.624Z daemon INFO time="2025-02-18T22:28:06-06:00" level=info msg="Adding libraries dir" dir="C:\\Users\\leblanc\\AppData\\Local\\Arduino15\\libraries" isSingleLibrary=false location=ide
time="2025-02-18T22:28:06-06:00" level=info msg="Adding libraries dir" dir="c:\\Users\\leblanc\\Documents\\Arduino\\libraries" isSingleLibrary=false location=user
2025-02-19T04:28:07.447Z root INFO Deploy plugins list: 121.9 ms [Finished 4.280 s after backend start]
2025-02-19T04:28:08.329Z discovery-log INFO start resolved watching
2025-02-19T04:28:08.387Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM4","label":"COM4","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-02-19T04:28:08.387Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[],"hardwareId":""}},"error":""}
2025-02-19T04:28:08.389Z discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[{"name":"Arduino Uno","fqbn":"arduino:avr:uno","isHidden":false}],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x0043"],["serialNumber","74137363737351101180"],["vid","0x2341"]],"hardwareId":"74137363737351101180"}},"error":""}
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-02-19T04:28:09.309Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 388.5 ms [Finished 4.155 s after frontend start]
2025-02-19T04:28:09.334Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-02-19T04:28:09.946Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 408.3 ms [Finished 4.865 s after frontend start]
2025-02-19T04:28:10.026Z root INFO Start frontend contributions: 1319.3 ms [Finished 4.891 s after frontend start]
2025-02-19T04:28:10.026Z root INFO Changed application state from 'init' to 'started_contributions'.
2025-02-19T04:28:10.055Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2025-02-19T04:28:10.056Z root INFO >>> Restoring the layout state...
2025-02-19T04:28:10.056Z root INFO <<< Nothing to restore.
2025-02-19T04:28:10.130Z root INFO Initialize the workbench layout: 57.8 ms [Finished 5.032 s after frontend start]
2025-02-19T04:28:10.168Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2025-02-19T04:28:10.373Z root INFO [c8fdad1b-8ea0-43a9-97a7-667be6c71e6e] Waiting for backend deployment: 413.7 ms [Finished 5.289 s after frontend start]
Checking for update
2025-02-19T04:28:11.799Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952) starting instance
2025-02-19T04:28:11.861Z root INFO Replace loading indicator with ready workbench UI (animation): 964.6 ms [Finished 6.054 s after frontend start]
2025-02-19T04:28:11.862Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2025-02-19T04:28:11.862Z root WARN Linked preference "workbench.colorCustomizations" not found.
2025-02-19T04:28:11.882Z root INFO Frontend application start: 2590.1 ms [Finished 8.637 s after backend start]
Update for version 2.3.4 is not available (latest version: 2.3.4, downgrade is allowed).
2025-02-19T04:28:13.643Z root ERROR ---- !!!SLOW!!! DURATION: search took 1792.732 ms. Args: [{"type":"Updatable"}] ----
2025-02-19T04:28:13.652Z root INFO [c8fdad1b-8ea0-43a9-97a7-667be6c71e6e] Sync of 23 plugins: 2971.4 ms [Finished 8.261 s after frontend start]
2025-02-19T04:28:13.652Z root INFO [c8fdad1b-8ea0-43a9-97a7-667be6c71e6e] Loading plugin contributions
2025-02-19T04:28:13.652Z root INFO [c8fdad1b-8ea0-43a9-97a7-667be6c71e6e] Load contributions of 23 plugins: 54.5 ms [Finished 8.316 s after frontend start]
2025-02-19T04:28:13.652Z root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
2025-02-19T04:28:13.652Z root WARN a registered grammar configuration for 'cpp' language is overridden
2025-02-19T04:28:13.676Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
2025-02-19T04:28:13.676Z daemon INFO time="2025-02-18T22:28:13-06:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
time="2025-02-18T22:28:13-06:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
time="2025-02-18T22:28:13-06:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-02-19T04:28:13.679Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
2025-02-19T04:28:14.408Z daemon INFO time="2025-02-18T22:28:14-06:00" level=warning msg="unable to parse additional URL: ://raw.githubusercontent.com/esp..."
2025-02-19T04:28:14.460Z daemon INFO panic:
2025-02-19T04:28:14.461Z daemon INFO runtime error: invalid memory address or nil pointer dereference
2025-02-19T04:28:14.462Z daemon INFO [signal 0xc0000005 code=0x0 addr=0x8 pc=0x3f02b4]
goroutine 39 [running]:
net/url.(*URL).String(0x0)
        /usr/local/go/src/net/url/url.go:817 +0x34
2025-02-19T04:28:14.487Z daemon INFO github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).UpdateIndex.func1
2025-02-19T04:28:14.487Z daemon INFO (
2025-02-19T04:28:14.488Z daemon INFO ...
2025-02-19T04:28:14.488Z daemon INFO )
2025-02-19T04:28:14.488Z daemon INFO /home/build/commands/instances.go
2025-02-19T04:28:14.488Z daemon INFO :538
github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).UpdateIndex(0xc000008660, 0xc00636a040, {0x11f58f0, 0xc00584e170})
        /home/build/commands/instances.go:566 +0x79f
github.com/arduino/arduino-cli/rpc/cc/arduino/cli/commands/v1._ArduinoCoreService_UpdateIndex_Handler({0xe2dd40, 0xc000008660}, {0x11f33b8, 0xc00179dc20})
        /home/build/rpc/cc/arduino/cli/commands/v1/commands_grpc.pb.go:1220 +0x10a
google.golang.org/grpc.(*Server).processStreamingRPC(0xc00021ec00, {0x11f0308, 0xc008d6a900}
2025-02-19T04:28:14.489Z daemon INFO , {0x11f7a60, 0xc0003c6000
2025-02-19T04:28:14.491Z daemon INFO }
2025-02-19T04:28:14.491Z daemon INFO , 0xc007d5cd80, 0xc00039eb10, 0x196a280, 0x0)
        /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1688 +0x1208
2025-02-19T04:28:14.491Z daemon INFO google.golang.org/grpc.(*Server).handleStream(0xc00021ec00, {0x11f7a60, 0xc0003c6000}, 0xc007d5cd80)
        /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1809 +0xe3a
google.golang.org/grpc.(*Server).serveStreams.func2.1()
        /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1029 +0x8b
created by google.golang.org/grpc.(*Server).serveStreams.func2 in goroutine 9
2025-02-19T04:28:14.491Z daemon INFO /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1040
2025-02-19T04:28:14.491Z daemon INFO +0x125
2025-02-19T04:28:14.501Z discovery-log INFO error received
2025-02-19T04:28:14.501Z discovery-log ERROR Unexpected error occurred during the boards discovery. Error: 14 UNAVAILABLE: read ECONNRESET
    at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:921712)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:949334)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:942356)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1028497
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:949101)
    at s.boardListWatch (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at y.createWrapper (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:76707)
    at y.start (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:77779)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-02-19T04:28:14.501Z discovery-log INFO received end
2025-02-19T04:28:14.567Z daemon INFO Daemon exited with exit code: 2.
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.linux as cortex-debug.armToolchainPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.osx as cortex-debug.armToolchainPath is null
Conflict in settings file Default: Ignoring cortex-debug.armToolchainPath.windows as cortex-debug.armToolchainPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.linux as cortex-debug.JLinkGDBServerPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.osx as cortex-debug.JLinkGDBServerPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.JLinkGDBServerPath.windows as cortex-debug.JLinkGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.openocdPath.linux as cortex-debug.openocdPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.osx as cortex-debug.openocdPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.openocdPath.windows as cortex-debug.openocdPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.linux as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.osx as cortex-debug.pyocdPath is null
2025-02-19T04:28:14.935Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.pyocdPath.windows as cortex-debug.pyocdPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.linux as cortex-debug.PEGDBServerPath is null
2025-02-19T04:28:14.936Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.osx as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.PEGDBServerPath.windows as cortex-debug.PEGDBServerPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.linux as cortex-debug.stutilPath is null
2025-02-19T04:28:14.936Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.stutilPath.osx as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stutilPath.windows as cortex-debug.stutilPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.linux as cortex-debug.stlinkPath is null
2025-02-19T04:28:14.936Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.osx as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stlinkPath.windows as cortex-debug.stlinkPath is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.linux as cortex-debug.stm32cubeprogrammer is null
2025-02-19T04:28:14.936Z root ERROR [hosted-plugin: 7952] Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.osx as cortex-debug.stm32cubeprogrammer is null
Conflict in settings file Default: Ignoring cortex-debug.stm32cubeprogrammer.windows as cortex-debug.stm32cubeprogrammer is null
2025-02-19T04:28:14.962Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): PluginManagerExtImpl/init()
2025-02-19T04:28:14.965Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-arduino-api@0.1.2 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.089Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(cortex-debug@1.5.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.089Z root INFO [hosted-plugin: 7952] Debugger contribution has been registered: cortex-debug
2025-02-19T04:28:15.090Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-arduino-tools@0.1.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.093Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.094Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.099Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.101Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-bg@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.102Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-cs@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.103Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-de@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.105Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-es@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.106Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-fr@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.107Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-hu@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.108Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-it@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.109Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-ja@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.109Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-ko@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.110Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.111Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-pl@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.111Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-pt-BR@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.112Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-ru@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.113Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-tr@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.114Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-uk@1.48.3 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.115Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-zh-hans@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.116Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): initializing(vscode-language-pack-zh-hant@1.80.0 with C:\Program Files\Arduino IDE\resources\app\lib\backend\plugin-vscode-init)
2025-02-19T04:28:15.124Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-api\extension\dist\extension.js)
2025-02-19T04:28:15.131Z root INFO [hosted-plugin: 7952] calling activation function on Arduino IDE API for VS Code extensions
2025-02-19T04:28:15.135Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
2025-02-19T04:28:15.193Z root INFO [hosted-plugin: 7952] calling activation function on JSON Language Features (built-in)
2025-02-19T04:28:15.238Z root INFO [c8fdad1b-8ea0-43a9-97a7-667be6c71e6e] Starting plugins.
2025-02-19T04:28:15.267Z root INFO [hosted-plugin: 7952] PLUGIN_HOST(7952): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js)
2025-02-19T04:28:15.325Z root INFO [hosted-plugin: 7952] Debug configuration provider has been registered: cortex-debug, trigger: 1
2025-02-19T04:28:15.326Z root INFO [hosted-plugin: 7952] calling activation function on Cortex-Debug
2025-02-19T04:28:15.334Z root INFO [hosted-plugin: 7952] GDB server console created
2025-02-19T04:28:15.343Z root INFO [c8fdad1b-8ea0-43a9-97a7-667be6c71e6e] Start of 23 plugins: 1920.9 ms [Finished 10.263 s after frontend start]
2025-02-19T04:28:35.339Z root ERROR Request updateIndex failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
    at processTicksAndRejections (node:internal/process/task_queues:77:11)
    at runNextTicks (node:internal/process/task_queues:64:3)
    at process.processImmediate (node:internal/timers:447:9)
for call at
    at s.init (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776931
    at new Promise (<anonymous>)
    at v.initInstance (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776897)
    at v.updateIndex (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:777936)
    at async u.onRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1265300)
    at async c.handleRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1256199)
2025-02-19T04:28:35.339Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:947033)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:942911)
for call at
    at s.makeUnaryRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:946574)
    at s.loadSketch (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:843354
    at B.doLoadSketch (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:843331)
    at async B._isSketchFolder (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:848934)
2025-02-19T04:28:35.340Z root ERROR Request maybeLoadSketch failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.747Z root ERROR Request getBoardUserFields failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at s.supportedUserFields (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at i (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:84900)
    at y.getBoardUserFields (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:84877)
2025-02-19T04:29:25.748Z root ERROR Request installed failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at s.libraryList (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at c (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:805684)
    at b.list (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:805661)
    at async v.installed (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:793246)
2025-02-19T04:29:25.749Z root ERROR Request getInstalledPlatforms failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at s.platformSearch (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:83384
    at y.getInstalledPlatforms (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:83361)
2025-02-19T04:29:25.751Z root ERROR Request list failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.751Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
    at s.boardDetails (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at s (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:81155)
    at y.getBoardDetails (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:81133)
2025-02-19T04:29:25.752Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.753Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.754Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.755Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.756Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.881Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.883Z store ERROR An unexpected error occurred while retrieving the board details for arduino:avr:uno. Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.884Z store ERROR An unexpected error occurred while retrieving the board details for arduino:avr:uno. Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.886Z store ERROR An unexpected error occurred while retrieving the board details for arduino:avr:uno. Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.943Z store ERROR An unexpected error occurred while retrieving the board details for arduino:avr:uno. Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.944Z store ERROR An unexpected error occurred while retrieving the board details for arduino:avr:uno. Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.954Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.956Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.961Z root INFO Failed to start language server. Original FQBN: arduino:avr:uno Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:25.984Z store ERROR An unexpected error occurred while retrieving the board details for arduino:avr:uno. Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:32.041Z root ERROR Request getBoardDetails failed with error: 14 UNAVAILABLE: No connection established Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:32.066Z store ERROR An unexpected error occurred while retrieving the board details for arduino:avr:uno. Error: 14 UNAVAILABLE: No connection established
for call at
2025-02-19T04:29:32.071Z root ERROR Have not received the full compile summary from the CLI while running the compilation. {}
 tags to format code for the forum`
The cause of the problem is that you put some invalid URLs in Arduino IDE's "Additional Boards Manager URLs" preference.
I'll provide instructions you can follow to fix it:
  2. Delete the file at the following path:
    C:\Users\leblanc\.arduinoIDE\arduino-cli.yaml
    :warning: Please be careful when deleting things from your computer. When in doubt, back up!
  3. Start Arduino IDE.
  4. Select File > Preferences... from the Arduino IDE menus.
    The "Preferences" dialog will open.
  5. Hover the mouse pointer over the code block below:
    https://espressif.github.io/arduino-esp32/package_esp32_index.json
  6. An icon that looks like two pieces of paper will appear near the right side of the code block. Click that icon.
    This will copy the contents of the code block to the clipboard.
  7. Click on the text input field to the right of the "Additional Boards Manager URLs" preference in the dialog.
  8. Press the Ctrl+V keyboard shortcut.
    This will paste the text you copied at step (6) into the field, replacing the selected text.
  9. The URL I provided above is for the "esp32" boards platform. If you need URLs for any other types of 3rd party boards, you can also add them in the "Additional Boards Manager URLs" now, separated with commas (,). But be very careful to triple check that the URLs you add are valid and not corrupted in any way.
  10. Click the "OK" button.
    The "Preferences" dialog will close.
Hopefully after doing that the problem will no longer occur.
FYI, the Arduino developers have already made a fix for the problem of the IDE not handling invalid URLs gracefully. The fix was made after the time of the last Arduino IDE release, but at least we can be glad that users will not encounter this problem going forward.
THANK YOU! Long process but you got me started. thank You again.
You are welcome. I'm glad if I was able to be of assistance.
Regards, Per
