Arduino ide doesn't start, stuck in loading
When I open Arduino IDE it freezes on the loading screen with the logo flashing.
I have read other posts on this topic and I have already verified that the 2 json libraries are present and not corrupt. I tried starting arduino ide with debugger() and this is my output
PS C:\Users\andre\AppData\Local\Programs\Arduino IDE> Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:35:44.802Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:35:44.802Z"}
Starting backend process. PID: 22316
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/andre/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-11-21T19:23:04.396Z root INFO Backend Object.initialize: 3.6 ms [Finished 0.340 s after backend start]
2023-11-21T19:23:04.396Z root INFO Backend Object.configure: 3.1 ms [Finished 0.340 s after backend start]
2023-11-21T19:23:04.396Z root INFO Backend a.onStart: 1.2 ms [Finished 0.340 s after backend start]
2023-11-21T19:23:04.397Z root INFO Backend a.configure: 0.3 ms [Finished 0.359 s after backend start]
2023-11-21T19:23:04.398Z root INFO Backend u.onStart: 0.2 ms [Finished 0.359 s after backend start]
2023-11-21T19:23:04.399Z root INFO Backend d.configure: 0.1 ms [Finished 0.359 s after backend start]
2023-11-21T19:23:04.399Z root INFO Backend d.initialize: 18.5 ms [Finished 0.359 s after backend start]
2023-11-21T19:23:04.400Z root INFO Backend c.onStart: 0.2 ms [Finished 0.359 s after backend start]
2023-11-21T19:23:04.400Z root INFO Backend s.configure: 1.1 ms [Finished 0.360 s after backend start]
2023-11-21T19:23:04.402Z config INFO >>> Initializing CLI configuration...
2023-11-21T19:23:04.402Z root INFO Backend c.initialize: 0.3 ms [Finished 0.360 s after backend start]
2023-11-21T19:23:04.402Z root INFO Backend P.onStart: 0.8 ms [Finished 0.361 s after backend start]
2023-11-21T19:23:04.403Z config INFO Loading CLI configuration from c:\Users\andre\.arduinoIDE\arduino-cli.yaml...
2023-11-21T19:23:04.403Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:04.403Z root INFO Backend s.initialize: 0.2 ms [Finished 0.362 s after backend start]
2023-11-21T19:23:04.404Z root INFO Backend w.onStart: 0.9 ms [Finished 0.362 s after backend start]
2023-11-21T19:23:04.404Z root INFO Backend r.configure: 2.0 ms [Finished 0.363 s after backend start]
2023-11-21T19:23:04.404Z discovery-log INFO start
2023-11-21T19:23:04.404Z discovery-log INFO start new deferred
2023-11-21T19:23:04.404Z root INFO Backend d.initialize: 0.3 ms [Finished 0.363 s after backend start]
2023-11-21T19:23:04.404Z root INFO Backend y.onStart: 2.0 ms [Finished 0.365 s after backend start]
2023-11-21T19:23:04.404Z root INFO Backend r.configure: 1.8 ms [Finished 0.365 s after backend start]
2023-11-21T19:23:04.405Z root INFO Backend s.onStart: 0.5 ms [Finished 0.367 s after backend start]
2023-11-21T19:23:04.405Z root INFO Backend h.configure: 0.6 ms [Finished 0.367 s after backend start]
2023-11-21T19:23:04.405Z root INFO Backend a.configure: 0.5 ms [Finished 0.368 s after backend start]
2023-11-21T19:23:04.405Z root INFO Backend s.configure: 0.1 ms [Finished 0.368 s after backend start]
2023-11-21T19:23:04.405Z root INFO Backend l.configure: 0.1 ms [Finished 0.368 s after backend start]
2023-11-21T19:23:04.408Z root INFO Theia app listening on http://localhost:55106.
2023-11-21T19:23:04.408Z root INFO Finished starting backend application: 4.0 ms [Finished 0.371 s after backend start]
2023-11-21T19:23:04.415Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/plugins does not exist.
2023-11-21T19:23:04.415Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/extensions does not exist.
2023-11-21T19:23:04.416Z root WARN The local plugin referenced by local-dir:C:\Users\andre\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\andre\Desktop\Arduinoprog\prova.ino
isTempSketch: false. Input was c:\Users\andre\Desktop\Arduinoprog\prova.ino
2023-11-21T19:23:04.432Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\andre\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\andre\\AppData\\Local\\Arduino15\\staging","user":"."},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-11-21T19:23:04.432Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-11-21T19:23:04.432Z config INFO Loaded the CLI configuration.
2023-11-21T19:23:04.433Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/andre/AppData/Local/Arduino15","sketchDirUri":"file:///.","additionalUrls":[],"network":"none","locale":"en"}
2023-11-21T19:23:04.433Z config INFO Validating the CLI configuration...
2023-11-21T19:23:04.433Z config INFO The CLI config is valid.
2023-11-21T19:23:04.433Z config INFO <<< Initialized the CLI configuration.
2023-11-21T19:23:04.441Z root INFO Resolve plugins list: 38.3 ms [Finished 0.404 s after backend start]
2023-11-21T19:23:04.445Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:04.446Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
    at Socket.<anonymous> (C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:46588)
    at Socket.emit (node:events:513:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at Readable.push (node:internal/streams/readable:234:10)
    at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2023-11-21T19:23:04.446Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:04.891Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:04+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:04.891Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:04.891Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:04.892Z daemon INFO time="2023-11-21T20:23:04+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:04.892Z daemon INFO time="2023-11-21T20:23:04+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:04+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:04+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55107
{"IP":"127.0.0.1","Port":"55107"}
Deamon è ora in ascolto su 127.0.0.1:55108
{"IP":"127.0.0.1","Port":"55108"}
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-11-21T19:23:05.563Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:05.564Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:05.564Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:05.564Z daemon INFO time="2023-11-21T20:23:04+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
Deamon è ora in ascolto su 127.0.0.1:55110
{"IP":"127.0.0.1","Port":"55110"}
2023-11-21T19:23:06.704Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:05+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:06.705Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:06.705Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:06.705Z daemon INFO time="2023-11-21T20:23:05+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:05+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:05+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55117
{"IP":"127.0.0.1","Port":"55117"}
2023-11-21T19:23:07.866Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:06+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:07.867Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:07.867Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:07.867Z daemon INFO time="2023-11-21T20:23:06+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:06+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:06+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55118
{"IP":"127.0.0.1","Port":"55118"}
2023-11-21T19:23:07.924Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:07.925Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:07.925Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:08.786Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 2549.6 ms [Finished 3.470 s after frontend start]
2023-11-21T19:23:08.787Z root WARN A command editor.action.toggleStickyScroll is already registered.
2023-11-21T19:23:08.789Z daemon INFO time="2023-11-21T20:23:07+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:08.790Z daemon INFO time="2023-11-21T20:23:07+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:07+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:07+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55119
{"IP":"127.0.0.1","Port":"55119"}
[49464:1121/202308.857:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ù"
2023-11-21T19:23:09.622Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 866.4 ms [Finished 4.352 s after frontend start]
2023-11-21T19:23:09.623Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:08+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:09.623Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:09.623Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:09.624Z daemon INFO time="2023-11-21T20:23:08+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:08+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:08+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55120
{"IP":"127.0.0.1","Port":"55120"}
2023-11-21T19:23:11.380Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:09+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:11.380Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:11.380Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:11.381Z daemon INFO time="2023-11-21T20:23:09+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:09+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:09+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55121
{"IP":"127.0.0.1","Port":"55121"}
2023-11-21T19:23:12.727Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 2539.0 ms [Finished 6.931 s after frontend start]
2023-11-21T19:23:12.728Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:11+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:12.728Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:12.728Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:12.729Z daemon INFO time="2023-11-21T20:23:11+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:11+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:11+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55122
{"IP":"127.0.0.1","Port":"55122"}
2023-11-21T19:23:14.531Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:12+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:14.531Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:14.532Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:14.532Z daemon INFO time="2023-11-21T20:23:12+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:12+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:12+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55123
{"IP":"127.0.0.1","Port":"55123"}
2023-11-21T19:23:15.211Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:14+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:15.212Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:15.212Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:15.213Z daemon INFO time="2023-11-21T20:23:14+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:14+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:14+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55124
{"IP":"127.0.0.1","Port":"55124"}
2023-11-21T19:23:16.399Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:15+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:16.400Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:16.400Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:16.400Z daemon INFO time="2023-11-21T20:23:15+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:15+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:15+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55125
{"IP":"127.0.0.1","Port":"55125"}
2023-11-21T19:23:17.568Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:16+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:17.568Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:17.568Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:17.568Z daemon INFO time="2023-11-21T20:23:16+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:16+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:16+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55128
{"IP":"127.0.0.1","Port":"55128"}
2023-11-21T19:23:19.252Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:17+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:19.252Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:19.252Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:19.253Z daemon INFO time="2023-11-21T20:23:17+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:17+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:17+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55129
{"IP":"127.0.0.1","Port":"55129"}
2023-11-21T19:23:20.562Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:19+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:20.563Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:20.563Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:20.564Z daemon INFO time="2023-11-21T20:23:19+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:19+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:19+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55130
{"IP":"127.0.0.1","Port":"55130"}
2023-11-21T19:23:21.312Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:20+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:21.313Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:21.313Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:21.313Z daemon INFO time="2023-11-21T20:23:20+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:20+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:20+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55131
{"IP":"127.0.0.1","Port":"55131"}
2023-11-21T19:23:22.147Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:21+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:22.147Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:22.148Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:22.157Z daemon INFO time="2023-11-21T20:23:21+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:21+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:21+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55132
{"IP":"127.0.0.1","Port":"55132"}
2023-11-21T19:23:23.355Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
time="2023-11-21T20:23:22+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.356Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.356Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.356Z daemon INFO time="2023-11-21T20:23:22+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:22+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:22+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55133
{"IP":"127.0.0.1","Port":"55133"}
2023-11-21T19:23:23.390Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.391Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.391Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.412Z root INFO Deploy plugins list: 38.3 ms [Finished 19.375 s after backend start]
2023-11-21T19:23:23.418Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.426Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.426Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.426Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.432Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
time="2023-11-21T20:23:23+01:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2023-11-21T20:23:23+01:00" level=info msg="Executing `arduino-cli daemon`"
Deamon è ora in ascolto su 127.0.0.1:55136
{"IP":"127.0.0.1","Port":"55136"}
2023-11-21T19:23:23.453Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.454Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.454Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.454Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.465Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.466Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55137
{"IP":"127.0.0.1","Port":"55137"}
2023-11-21T19:23:23.482Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.483Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.483Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.483Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.492Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.493Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55138
{"IP":"127.0.0.1","Port":"55138"}
2023-11-21T19:23:23.509Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.511Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.511Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.511Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.519Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.520Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55139
{"IP":"127.0.0.1","Port":"55139"}
2023-11-21T19:23:23.532Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.541Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.541Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.542Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.549Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
Deamon è ora in ascolto su 127.0.0.1:55140
{"IP":"127.0.0.1","Port":"55140"}
2023-11-21T19:23:23.560Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.572Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
Deamon è ora in ascolto su 127.0.0.1:55141
{"IP":"127.0.0.1","Port":"55141"}
2023-11-21T19:23:23.575Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.576Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.577Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.593Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.604Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.605Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55142
{"IP":"127.0.0.1","Port":"55142"}
2023-11-21T19:23:23.610Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.610Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.611Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.628Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.638Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.640Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55143
{"IP":"127.0.0.1","Port":"55143"}
2023-11-21T19:23:23.648Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.649Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.650Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.665Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.676Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.678Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55144
{"IP":"127.0.0.1","Port":"55144"}
2023-11-21T19:23:23.686Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.686Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.687Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.705Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.715Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.716Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55145
{"IP":"127.0.0.1","Port":"55145"}
2023-11-21T19:23:23.717Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.717Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.717Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.736Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.746Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.747Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55146
{"IP":"127.0.0.1","Port":"55146"}
2023-11-21T19:23:23.748Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.749Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.749Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.767Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.777Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.777Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.778Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.778Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.787Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55147
{"IP":"127.0.0.1","Port":"55147"}
2023-11-21T19:23:23.796Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.807Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.808Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55148
{"IP":"127.0.0.1","Port":"55148"}
2023-11-21T19:23:23.813Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.813Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.813Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.833Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.844Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.846Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55149
{"IP":"127.0.0.1","Port":"55149"}
2023-11-21T19:23:23.849Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.851Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.851Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.867Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.878Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.878Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55150
{"IP":"127.0.0.1","Port":"55150"}
2023-11-21T19:23:23.884Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.884Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.884Z daemon INFO Starting daemon from C:\Users\andre\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2023-11-21T19:23:23.902Z daemon INFO time="2023-11-21T20:23:23+01:00" level=warning msg="Unable to get Documents Folder: The system cannot find the file specified."
2023-11-21T19:23:23.913Z daemon INFO time="2023-11-21T20:23:23+01:00" level=info msg="Using config file: c:\\Users\\andre\\.arduinoIDE\\arduino-cli.yaml"
2023-11-21T19:23:23.914Z daemon INFO Deamon è ora in ascolto su 127.0.0.1:55151
{"IP":"127.0.0.1","Port":"55151"}
2023-11-21T19:23:23.922Z daemon INFO Unable to get Documents Folder: The system cannot find the file specified.
2023-11-21T19:23:23.923Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the file specified.
The message I notice repeating endlessly after it gets stuck loading
Hi @andrea13121312.
On startup, Arduino IDE queries the Windows operating system for the location of your user "Documents" folder. The reason Arduino IDE is not starting is because when it makes this query Windows responds that the "Documents" folder doesn't exist. Since that folder should always exist, the IDE fails to start with this "Unable to get Documents Folder: ..." error.
Traditionally, the default location of the "Documents" folder was a path with this format:
C:\Users\<username>\Documents
(where <username> is your Windows username)
Although that is the default, it is possible to customize the location of this folder. If the location was changed to a drive that is not accessible (e.g., a USB drive that is unplugged), that could cause the "Unable to get Documents Folder: ..." error.
If you have the Windows "OneDrive folder syncing" feature enabled, the "Documents" folder is located under the OneDrive storage by default, at a path with this format:
C:\Users\<username>\OneDrive\Documents
(where the name of the Documents folder might actually be the localized equivalent)
It is also possible the folder could be located on alternative cloud storage providers (e.g., Dropbox).
When other users reported encountering this "Unable to get Documents Folder: ..." error, we often found that the problem was caused by them having disabled OneDrive in some manner, or else by them not having a connection to the OneDrive service.
Can you think of anything unusual about your system that might cause Arduino IDE to not be able to access your "Documents" folder?
Yes, the problem was that Arduino IDE couldn't find the Documents folder since I uninstalled One Drive before installing Arduino IDE. To resolve this I reinstalled Windows and that solved the problem. Thanks for your help
You are welcome. I'm glad it is working now.
Regards,
Per
