Hey,
I've got a wierd problem that I can't seem to find the answer to browsing google. My IDE outputs an error when I try to upload a sketch to the arduino. Here's the console:
Sketch uses 84742 bytes (0%) of program storage space. Maximum is 10000000 bytes.
#!/bin/sh
starting download script
# clupload script to invoke lsz
# Copyright (C) 2014 Intel Corporation
# This library is free software; you can redistribute it and/or
# modify it under the terms of the GNU Lesser General Public
# License as published by the Free Software Foundation; either
Args to shell: C:\Users\Alex Nuta\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0/x86/bin C:\Users\Alex Nuta\AppData\Local\Temp\arduino_build_784874/Blink_v2.ino.elf COM6
# version 2.1 of the License, or (at your option) any later version.
COM PORT 6
Converted COM Port COM6 to tty port /dev/ttyS5
Sending Command String to move to download if not already in download mode
# This library is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# Lesser General Public License for more details.
# You should have received a copy of the GNU Lesser General Public
# License along with this library; if not, write to the Free Software
# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
echo "starting download script"
echo "Args to shell:" $*
# ARG 1: Path to lsz executable.
# ARG 2: Elf File to download
# ARG 3: COM port to use.
#path contains \ need to change all to /
path_to_exe=$1
fixed_path=${path_to_exe//\\/\/}
#COM ports are not always setup to be addressed via COM for redirect.
#/dev/ttySx are present. Howwever, COMy -> /dev/ttySx where x = y - 1
com_port_arg=$3
com_port_id=${com_port_arg/COM/}
echo "COM PORT" $com_port_id
tty_port_id=/dev/ttyS$((com_port_id-1))
echo "Converted COM Port" $com_port_arg "to tty port" $tty_port_id
echo "Sending Command String to move to download if not already in download mode"
echo "~sketch downloadGalileo" > $tty_port_id
Deleting existing sketch on target
#Move the existing sketch on target.
echo "Deleting existing sketch on target"
"$fixed_path/lsz.exe" --escape -c "mv -f /sketch/sketch.elf /sketch/sketch.elf.old" <> $tty_port_id 1>&0
Transfer incomplete
# Execute the target download command
#Download the file.
host_file_name=$2
"$fixed_path/lsz.exe" --escape --binary --overwrite $host_file_name <> $tty_port_id 1>&0
lsz: cannot open C:\Users\Alex: No such file or directory
lsz: cannot open Nuta\AppData\Local\Temp\arduino_build_784874/Blink_v2.ino.elf: No such file or directory
Can't open any requested files.
Transfer incomplete
Moving downloaded file to /sketch/sketch.elf on target
#mv the downloaded file to /sketch/sketch.elf
target_download_name="${host_file_name##*/}"
echo "Moving downloaded file to /sketch/sketch.elf on target"
"$fixed_path/lsz.exe" --escape -c "mv $target_download_name /sketch/sketch.elf; chmod +x /sketch/sketch.elf" <> $tty_port_id 1>&0
Retry 0: Got TIMEOUT
Transfer incomplete
What I've tried: Reinstalling IDE, I've searched the path where it said in the console it couldn't find the .ino.elf file however the file is there; the sketch I'm trying to upload is a modified blink example, I have tried with my actual sketch and there is no difference.
I've attached a photo of the path where the console said there's no file there.
Verifying a sketch works great, after searching google, reinstalling the IDE, verifying that files are there even tho the IDE doesn't find them, I don't know what else to do, please help!
