Hello Paul Stoffregen and all others,
i found your nice library FreqMeasure and have a little Problem with my projekt „Kennfeldzündung“:
I can measure the speed of the ignition on Pin 8 and it shows me the RPM of the Motor,
but i need a signal (one per round) for making a delayed output wich goes tot he ignition-coil.
Do you have an idea, how to catch the high/low state on pin 8 while also measuring the frequency?
Regards,
Wolfram.
My code so far:
/* FreqMeasure - Example with LCD output
* http://www.pjrc.com/teensy/td_libs_FreqMeasure.html
* This example code is in the public domain.
#include <FreqMeasure.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, A2, 9, 10, 11, 12);
#define LCD_LED_BLUE A3
#define LCD_LED_GREEN A4
#define LCD_LED_RED A5
lcd.begin(20, 4);
lcd.print("Freq:");
FreqMeasure.begin();
pinMode(LCD_LED_RED, OUTPUT);
pinMode(LCD_LED_GREEN, OUTPUT);
pinMode(LCD_LED_BLUE, OUTPUT);
digitalWrite(LCD_LED_RED, LOW);
digitalWrite(LCD_LED_GREEN, LOW);
digitalWrite(LCD_LED_BLUE, LOW);
double sum = 0;
int count = 0;
if (FreqMeasure.available())
// average several reading together
sum = sum + FreqMeasure.read();
count = count + 1;
if (count > 10)
float frequency = FreqMeasure.countToFrequency(sum / count);
lcd.setCursor(0, 1);
lcd.print(frequency);
lcd.print(" Hz ");
float umin = map(frequency,0,100.0,0,6000.0);
lcd.setCursor(0, 3);
lcd.print(umin);
lcd.print(" Umin ");
sum = 0;
count = 0;
Hi Wolfram,
Just trying to understand better what you are trying to accomplish.
Are you trying to create a delayed HIGH/LOW signal every single revolution of the motor?
What kind of motor/driver are you using or what are you using to receive RPM (encoder/hall sensor)
And I can't see where PIN8 is being utilised for RPM in the example you posted.
pin 8 is defined in the library.
The Motor is a 2stroke bike motor and it has a contact which opens once a rpm.
depending on the measured rpm the signal of the contact should be outputted on another io more or less delayed.
this delayed output drives a power-fet wich turns the ignition-coil on/off.
Okay, I kinda think I know what your talking about, are you basically making your own CDI unit to control the ignition timing of the engine?
If so you said you are able to receive a correct rpm reading thanks to the library, are you then trying to send a HIGH signal through another Pin as the ignition signal after every revolution? can you do something like below.
void loop(){
if (digitalRead(8) == HIGH){
//pin 11 = FET ignition**
digitalWrite(11, HIGH)
delayMicroseconds(3);
digitalWrite(11, LOW)
Or are you trying to do something more complex then that?
that could work:
delayMicroseconds(delay); // delay value depending on rpm
delayMicroseconds(10); // defined on-time of coil
but, it must have priority to not miss a pulse, would irq may work?
the mesurement routine must wait if a pulse appears.
i will try this first:
#define FET 13
float zuenddelay = 8000.0;
lcd.begin(20, 4);
lcd.print("Freq:");
pinMode(FET, OUTPUT);
double sum = 0;
int count = 0;
count = count + 1;
if (count > 10)
int frequency = FreqMeasure.countToFrequency(sum / count);
lcd.print(" Hz ");
int umin = map(frequency, 0, 100, 0, 6000);
zuenddelay = map(frequency, 0, 100, 8000.0, 0.0);
lcd.setCursor(0, 2);
lcd.print(umin);
sum = 0;
count = 0;
delayMicroseconds(zuenddelay); // delay value depending on rpm
digitalWrite(FET, HIGH);
digitalWrite(FET, LOW);
lcd.setCursor(10, 3);
lcd.print(zuenddelay/1000);
lcd.print(" mS ");
// kontakt im irq, nur wenn nicht geschlossen messen!!
yep!
i will try it with an irq, see tonight the results on the scope...
for using the irq d2 and d8 must be tied together.
#define FET 13
#define KONTAKT 2 // D2 & D8 together
lcd.begin(20, 4);
lcd.print("Freq:");
attachInterrupt(0, kontakt, RISING);
double sum = 0;
int count = 0;
count = count + 1;
if (count > 10)
lcd.print(" Hz ");
zuenddelay = map(frequency, 0, 100, 16000.0, 0.0);
lcd.print(umin);
lcd.print(zuenddelay / 1000);
lcd.print(" mS ");
sum = 0;
count = 0;
void kontakt()
delayMicroseconds(1000); // defined on-time of coil
it seems to take a while before i can test it on the bike,
first i have to do some repairs on the motor...
