Arduino matrix buttons not working,
I made a 3*5 arduino matrix buttons, used A2-A5, but not works well, actually, not response at all.
byte rows[] = {9,10,11};
const int rowCount = sizeof(rows)/sizeof(rows[0]);
// JP2 and JP3 are outputs
////byte cols[] = {8,9,10};
////byte cols[] = {8,16,17,18,19};
byte cols[] = {8,A2,A3,A4,A5};
const int colCount = sizeof(cols)/sizeof(cols[0]);
byte keys[colCount][rowCount];
    for(int x=0; x<rowCount; x++) {
        Serial.print(rows[x]); Serial.println(" as input");
        pinMode(rows[x], INPUT);
    for (int x=0; x<colCount; x++) {
        Serial.print(cols[x]); Serial.println(" as input-pullup");
        pinMode(cols[x], INPUT_PULLUP);
void readMatrix() {
    // iterate the columns
    for (int colIndex=0; colIndex < colCount; colIndex++) {
        // col: set to output to low
        byte curCol = cols[colIndex];
        pinMode(curCol, OUTPUT);
        digitalWrite(curCol, LOW);
        // row: interate through the rows
        for (int rowIndex=0; rowIndex < rowCount; rowIndex++) {
            byte rowCol = rows[rowIndex];
            pinMode(rowCol, INPUT_PULLUP);
            keys[colIndex][rowIndex] = digitalRead(rowCol);
            pinMode(rowCol, INPUT);
        // disable the column
        pinMode(curCol, INPUT);
void printMatrix() {
        if (rowIndex < 10)
            Serial.print(F("0"));
        Serial.print(rowIndex); Serial.print(F(": "));
            Serial.print(keys[colIndex][rowIndex]);
            if (colIndex < colCount)
                Serial.print(F(", "));
        Serial.println("");
    Serial.println("");
    readMatrix();
    if (Serial.read()=='!')
        printMatrix();
The post102.1 is the Serial Monitor.
A complete schematic would help here.
Showing connections to Arduino.
What model Arduino are you using?
Please do not post screen shots of the serial monitor. Copy text from serial monitor and paste it into your post between code tags.
        printMatrix();
Because of the if-statement here, the output will only appear when you enter a "!" on the serial monitor.
Hi you are declaring every pins as INPUT you need OUTPUT pins (rows) too.
Danisupra:
Please read the code in the original post.
Have you googled
arduino keypad
try this; Arduino Playground - Keypad Library
Tom... :slight_smile:
