This is one of my first projects and when I try to upload, the progress bar reaches over 90% before the following error occurs: Arduino: 1.8.12 (Mac OS X), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
/Users/philipliu/Documents/Arduino/Ultrasonic_sensor_with_buzzer/Ultrasonic_sensor_with_buzzer.ino: In function 'loop':
/Users/philipliu/Documents/Arduino/Ultrasonic_sensor_with_buzzer/Ultrasonic_sensor_with_buzzer.ino:40:53: warning: iteration 2 invokes undefined behavior [-Waggressive-loop-optimizations]
int noteDuration = 1000 / noteDurations[thisNote];
/Users/philipliu/Documents/Arduino/Ultrasonic_sensor_with_buzzer/Ultrasonic_sensor_with_buzzer.ino:36:37: note: within this loop
for (int thisNote = 0; thisNote < 8; thisNote++) {
/Users/philipliu/Library/Arduino15/packages/arduino/hardware/avr/1.8.3/cores/arduino/main.cpp: In function 'main':
Sketch uses 4608 bytes (1%) of program storage space. Maximum is 253952 bytes.
Global variables use 53 bytes (0%) of dynamic memory, leaving 8139 bytes for local variables. Maximum is 8192 bytes.
avrdude: ser_open(): can't open device "/dev/cu.Endurance-SerialPort-1": Resource busy
ioctl("TIOCMGET"): Inappropriate ioctl for device
avrdude: ser_send(): write error: Bad file descriptor
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
the selected serial port avrdude: stk500v2_getsync(): timeout communicating with programmer
does not exist or your board is not connected
My code is as follows:
#include <pitches.h>
#define echoPin 2 // attach pin D2 Arduino to pin Echo of HC-SR04
#define trigPin 3 //attach pin D3 Arduino to pin Trig of HC-SR04
// notes in the melody:
int melody[] = {
NOTE_C4, NOTE_C4
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
3, 3
// defines variables
long duration; // variable for the duration of sound wave travel
int distance; // variable for the distance measurement
pinMode(trigPin, OUTPUT); // Sets the trigPin as an OUTPUT
pinMode(echoPin, INPUT); // Sets the echoPin as an INPUT
// Clears the trigPin condition
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin HIGH (ACTIVE) for 10 microseconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance = duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
while (distance < 100) {
// to calculate the note duration, take one second divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
tone(8, melody[thisNote], noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note's duration
int pauseBetweenNotes = noteDuration * 1.10;
delay(pauseBetweenNotes);
// stop the tone playing:
noTone(8);
Maybe it's an error in my code? Thanks for your help
