Arduino + Mic + Pre-Amp = crap (SOLVED!!!)
i've been working on this project for two days non-stop and all i got now is frustration.
i'm making a sound trigger for high speed photography.
mic : electret mic
preamp : http://www.sparkfun.com/datasheets/BreakoutBoards/Amplified-Mic-v10.pdf , got no OPA344 and used LM324N instead. Using 9V to power it, and output measured using multimeter as 3.87V. Tested with PC speaker and it works.
rectifier : http://itp.nyu.edu/physcomp/sensors/Reports/CondenserMicrophones
result :
36
27
195
503
489
50
0
34
217
542
399
24
0
91
417
541
311
0
33
260
625
604
113
57
337
661
567
56
7
95
405
696
392
27
24
389
735
443
66
10
i've played with the A2D pin of my Arduino, using potentiometer. GND on the left pin, middle pin goes to A2D pin of Arduino, and 5V goes to the right pin. My Arduino is fine, it returns result from 0-1023, very stabil.
what else did i do wrong?
not enough gain?
already got 100x gain. it's now 3.8V, if i double the gain, wouldn't it be 7.6V?
my code :
int analogPin = 0;
int x;
  x=analogRead(analogPin);
  Serial.println(x);
  delay(200);
What do you get if you disconnect the microphone and ground the input of the amp?
refering to http://www.sparkfun.com/datasheets/BreakoutBoards/Amplified-Mic-v10.pdf, the other terminal of the mic as already attached to ground, so to test the scenario you gave i just unplugged the mic and short the 2 wire...
after the rectifier, it gives 4.02V
without rectifier, after the amp, it gives 4.46V
please note that regarding to schematics in http://itp.nyu.edu/physcomp/sensors/Reports/CondenserMicrophones I only take the rectifier part.
thank you for willing to help.
i think you were talking about the A2D reading,
here it is with the rectifier :
346
485
272
0
0
23
240
469
369
0
0
0
86
385
464
168
0
0
184
455
405
63
0
9
121
421
384
34
0
0
149
436
426
97
0
34
258
482
335
0
0
2
120
463
389
37
0
17
236
477
362
0
0
35
262
495
152
0
0
47
367
505
223
0
0
65
293
485
209
0
0
70
382
436
107
0
0
168
451
432
95
0
0
94
330
477
79
0
0
109
471
410
66
0
11
215
477
393
0
0
0
70
380
481
198
0
0
89
318
497
186
0
0
91
323
475
184
0
0
104
404
471
179
0
40
268
490
350
0
0
7
108
472
425
83
0
6
115
417
466
70
0
9
100
269
and here it's with amp only, no rectifier :
59
97
316
435
188
0
0
0
132
445
313
0
0
0
40
262
450
146
0
0
31
329
399
62
0
0
36
252
452
255
0
0
0
88
382
409
91
0
0
12
163
303
0
0
0
0
0
6
52
86
0
0
0
0
both case is with mic wire shorted and grounded.
Using a preamp and a rectifier gives you an unipolar voltage but it is still changing rapidly. If you want a continous voltage or at least a slow changing voltage you should add some filtering (the last part of the workshop). You must adapt the capacitor value to your need. The higher the capacitor will be the slower the voltage will change. Beware that this introduce some time delay in the system.
Well, if we take a look at this schematic, http://itp.nyu.edu/physcomp/sensors/Reports/CondenserMicrophones, there's already a low pass filter, isn't it?
should i make the capacitor value bigger and resistor smaller? (maintain the corner frequency value, yet have bigger capability to smoothen wave).
ok, i think i got it solved...
here is what the rectifier + filter part looks like before :
and here is how it is now :
can someone please explain how it is not the same?
the A2D reading is now very stabil, fluctuating only one unit (eg. 780-781), after some testing i now supply only 5V to the preamp, using a voltage regulator. The result is more delighting, i have more space between the ambient reading and max value (1023) allowing me to put higher threshold trigger value. At 5V supply, the ambient reading is now 508-509.
One more thing, how can i be sure that a very loud noise won't push the sound signal voltage beyond 5.5v?
thank you to those who have already helped earlier...
Well D4 is doing absolutely nothing both ends are connected to ground so you might as well take it out.
The second circuit looks like it has a common ground with the arduino, without one you can't expect to have a stable measurement.
As you only have a 5V supply the audio can't get any bigger.
i've read many of your post grumpy_mike, i have great respect for you :D.
is it always important to "commonize" the ground between multiple "sub-system"?
Yes it is.
Have a look at this page:-http://www.thebox.myzen.co.uk/Tutorial/Power.html
It explains why from the point of view of an arduino driving an output but the reasoning applies just the same for an input.
If you have ever used an oscilloscope you will know that you do need a ground connection as well as a signal connection before you get any readings that have not got large pickup voltages of the mains frequency on them.
Hope that helps.
Sorry wrong link, you actually want to read:-
http://www.thebox.myzen.co.uk/Tutorial/Power_Supplies.html
