Hi, I am a newbie to IoT so I have been using the out of the box Mkr wan 1300 to set up a LoraWan connection. Yesterday all worked Ok I went through the setup selected the board and it appeared in the Devices list as MKR wan 1300. I even achieved a send of some simple text message which arrived on the dashboard. I have an Arduino Pro gateway working all wonderful. I then wanted to tidy things up and repeat the install using exactly the same kit. I deleted the device and started to add it again. This is where I hit the problem
- Setup device, "Arduino MKR WAN 1300 found"
2.1) Make your device IoT-ready, Tick in stage 1
2.2) Make your device IoT-ready, "retrieving DevEUI from your board" FAILS
"failed to start the Lora Module"
I have reinstalled the Agent a number of times both 64 and 32 bit.
Part of the log from the “Agent”
Serial Ports:
"Name": "COM7",
"SerialNumber": "",
"IsOpen": true,
"VendorID": "0x2341",
"ProductID": "0x8053"
"P": "COM7",
"D": "Failed to start module\r\n"*
Interestingly if I use the “FirstConfiguration” from the “MKRWAN” example it works as it appears to use the library “#include <MKRWAN.h>”
“Welcome to MKR WAN 1300/1310 first configuration sketch
Register to your favourite LoRa network and we are ready to go!
Your module version is: ARD-078 1.2.3
Please make sure that the latest modem firmware is installed.
To update the firmware upload the 'MKRWANFWUpdate_standalone.ino' sketch.
Your device EUI is: aXXXXXXXXXXX9
Are you connecting via OTAA (1) or ABP (2)?”
If I use the same sketch but from “MKRWAN_v2” it gets a similar error to the
“Welcome to MKRWAN1300/1310 first configuration sketch
Failed to start module”
I'm guessing its an issue with libraries and possibly the fact that I did use "MKRWANFWUpdate_standalone.ino" on the board so it not exactly the same as when I first went through setup.
I have tried doing the setup of the board on the IOT cloud as a 3rd party device and have again got it to work and sent some simple text messages. Its just very frustrating, I must be missing something really simple.
any ideas would be welcomed.
