My Arduino Nano 33 BLE is build in a case. So, when it is powered on i cannot see it.
I like to have an external led that indicates that the board is powered ON.
Wich voltagepin is the best to use?. I have read that when 5v pin is needed then you have to bridge 2 pads to get the 5v working.
I like to use the 3.3v output for the external led. But, is that possible? Do i have to connect the led directly? Or do i have to add a resistor in line between the 3.3v and the led ??
It will automatically close after a while (4 months currently). But marking it with a solution (thanks for that) is sufficient; you can see it as your selected solution was added to the opening post.
