Arduino Nano 33 BLE Sense not Driving Servos
Hello, I have been working on a code over the past week, where the Arduino would be using the onboard 9-axis IMU chip to approximate rotation. The code I have is working properly and will do the appropriate slowing whenever it reaches an angle threshold. The problem I am having, is that the servos are not even attempting to move. I know the BLE Sense uses 3.3 V on its output so I am powering the Servos using a separate power source where the ground is connected to the Arduino board. I really need the servos to move as that is the whole point of the code.
Below is the code. I have had to use the outdated board config in the code, because the new board config, does not work servo library with its MBed_nano architecture.
Code:
// Creator: Zachary D. Arnold
// Date Made: May 10, 2021
// Date Edited: May 11, 2021
// Modified By: Zachary D. Arnold
// Purpose: Creating a failsafe protocal for parachute deployment system on ENES 100 Bottle Rockets
// Board: Arduino Nano 33 BLE Sense
// Board in Code: Arduino Nano 33 BLE (from arduino MBed OS Boards)
//Required materials for correct setup:
// 1)Ardunino Nano 33 BLE/Ardunino Nano 33 BLE Sense (or any ardunino board with attachments for
// gyroscope [gyroscope needs to be a minimum of 3 axis {see commented code 2 for this use}])
// 2)2 Micro servo motors. (Can uses at smallest SG90's)
// 3)7 Male-to-female jumper cables. (If using boards with male headers [4 male-to-female when not
// using Nano 33 BLE board.])
// 4)1 Mini breadboard
// 5)6 Male-to-male jumper cables. (If using boards with male headers [12 male-to-male when not
// 6)1 9V Battery. (Dependent on the board setup)
// 7)1 RGB LED
// 8)3 220 Ohm Resistors
// 9)1 Power Supply Board with Supplied Case
// Section 1
// Use: Creates a section where constant variables are defined and where required libraries are added.
#include <Arduino_LSM9DS1.h>
//Includes a library which the arduino can use to access sensor data.
#include <Servo.h>
//Includes a library which the arduino can use to control motor outputs.
#define BLUE 2
//Creates a definition for a term that has a number connected to it.
#define GREEN 3
#define RED 4
float xa,ya,za,x,y,z;
//Creates variables that the code can reference later.
//These variables have a decimal point that "floats", which means that the variable has precision of
//6 to 7 digits. (This is not just to the right of the decimal, but in both directions.)
//Good for small numbers that will contain decimals.
//Also good for making pointers.
int n;
//Creates a variable that the code can reference later.
//This variable has only the integer. This means that no rounding or spproximation is made.
//Good for only numbers that will not ever contain decimals.
Servo servo1;
//Creates a servo motor for the code.
Servo servo2;
// Section 2
// Use: Creates a section where sensors can be initialized. This "loop" will only run once.
//The use of the term "void" tells the code to neglect any output that is not determined inside the
//loop.
//Starts the
servo1.attach(9);
//Tells the arduino what digital pin the servo motor is attached to.
servo2.attach(9);
servo1.write(90);
//Gives a command to the servo motor, which will act as the base position for this script.
servo2.write(90);
pinMode(RED, OUTPUT);
//Set the term "RED" to a pin, that is determined to be an output.
pinMode(GREEN, OUTPUT);
//Set the term "GREEN" to a pin, that is determined to be an output.
pinMode(BLUE, OUTPUT);
//Set the term "BLUE" to a pin, that is determined to be an output.
digitalWrite(RED, LOW);
//Tells the value of the pin connected to the term "Red".
//The use of "HIGH" acts like a one, where as "LOW" is a zero.
digitalWrite(GREEN, LOW);
//Tells the value of the pin connected to the term "GREEN".
digitalWrite(BLUE, HIGH);
//Tells the value of the pin connected to the term "BLUE".
n = 1;
//Defines a value for the constant "n".
//This is a 1 so we can start the loop below.
if (!IMU.begin()) {
//This type of statement is used to determine if the condition is true or false.
//The condition for this loop is defined inside the parentheses.
//The use of "!" says that the statement is not occuring.
Serial.println("Failed to initialize IMU!");
//The use of "Serial", opens communication between a device and the arduino.
//The use of "println", returns the number of bytes written.
//The use of parentheses tells the "println" function where to look and the quotation
//marks determine the use of characters.
digitalWrite(BLUE, LOW);
digitalWrite(RED, HIGH);
while (1);
//Creates a while loop. This type of loop will continue to run while the condition
//inside the parentheses is true.
while(!Serial);{
Serial.println("Started");
//Prints the term "Started once the loop has begun."
// Section 3
// Use: Creates a section where the main script runs. This code will continue until it is told to exit.
//loop.
while (n == 1){
// LED Color:
digitalWrite(GREEN, HIGH);
//Angle Finding:
if(IMU.accelerationAvailable()){
  IMU.readAcceleration(xa,ya,za);
    //Tells the code what variables to attach the values read to.
    //These values are then attached to the variables for each run of the loop.
    //Each new iteration of the loop, overwrites the previous value.
  x = RAD_TO_DEG * (atan2(-ya,-za) + PI);
    //Uses trig functions to convert the radian values into degree values.
    //The trig function used is arctan. This is used by the term "atan2".
      //The "atan" tells what type of trig function is being used.
      //The "2" tells how many variables or terms are being defined by it.
    //The term "RAD_TO_DEG" is a constant defined inside the arduino coding.
  y = RAD_TO_DEG * (atan2(-xa,-za) + PI);
  z = RAD_TO_DEG * (atan2(-ya,-xa) + PI);
//Logic Statements:
  if (x >= 80 && x <= 280){
      //The use of the operator ">=" states greater than or equal to.
      //The use of the operator "<=" states less than or equal to.
      //The use of the logic term "&&" states both definition must be met to be true.
    servo1.write(45);
      //Moves the servo by giving it directions to change its position.
    servo2.write(45);
    delay (1000);
      //Makes a time (in milliseconds) the the code must wait until continuing.
  else if (y >= 80 && y <= 280){
      //This type of statement is used to determine another case of "if".
    servo1.write(45);
    servo2.write(45);
    delay (1000);
  if ((servo1.read() == 45)||(servo2.read() == 45)){
      //The use of the logic term "||" states either definitions must be met to be true.
    n = 0;
      //Redefines the value of n. This is done to exit the while loop.
    //LED Color:
  else{
      //This type of statement is used to determine all other possiblities when the "if"
      //statement is false.
      //By default, even if "else" is false. The code will view it as true, if all other "if"
      //statements are also false.
    n = 1;
      //Redefines the value of n. This is done so the loop can continue.
  //Prints angles:
    Serial.print("Angle X = ");
      //Prints the terms.
    Serial.println(x);
      //Prints the value of the variable.
    Serial.print("Angle Y = ");
      //Prints the terms.
    Serial.println(y);
    Serial.print("Angle Z = ");
      //Prints the terms.
    Serial.println(z);
    Serial.println("---------------------------------------------------");
      //Prints a devisor line for each iteration of the loop.
    delay(3);
      //Gives a small time delay so data can somewhat be monitered, while the loop is running.
// Section 4
// Use: Creates a section for extra comments.
//The use of these three buttons together will display a window where outputs can be seen as data:
// SHIFT + CTRL + M
//The use of these three buttons together will display a window where outputs can be seen as a graph:
// SHIFT + CTRL + L
// Section 5
// Use: Creates a section for conclusions.
//The use of this code should allow for the students bottle rocket projects to become safer for the
//students envolved while also increasing the safety for students in close proximity. This code also
//allows first year engineering students to experience arduino coding, and have a basic introduction
//into C++. This will aid these students throughout the rest of their engineering pathway. This also
//aids any students acquiring GEP requirements, by experiencing first hand the use of automation.
Try the sweep example to find out whether a 3V3 signal can actually command your servo. Good to see that you gave it separate power though.
Having 2 servos attached to the same pin isn't going to help.
It also doesn't help that there are so many comments that it's difficult to find any real code and some of the comments are very misleading e.g. your idea of what 'void' means.
Steve
Both previuos answers are legit. Troubleshoot accordingly.
The servos should work with a 3V3 logic level command signal, but it generally depends on the model.
If needed you could use a level shifter.
Handy reference:
https://www.arduinoplatform.com/arduino-digital-analog/logic-level-shifting-with-arduino/
Thank you all, I think the main issue is that the output supplied to servos, is not at a high enough voltage. I will correct this by replacing the servos used, and also moving some pins around.
Thank you, I did type most of the comments up quick so, they might have some errors. I corrected the void function and some of the object definitions. I will also move servo 2 over to pin 10. I did the same pin because the main goal was to keep the required materials down. Also, sorry for the amount of comments as I have been trying to fix this servo error for the past two days.
You also stated that some other comments were misleading, I always like feedback, and would appreciate if you could aid in pointing out some other commenting errors. If you cannot, thank you anyways.
