Arduino Nano RP2040 Connect Battery
Is this battery "500mAh 3.7V lithium polymer lipo rechargeable battery" compatible with Arduino nano rp2040 connect?
Only if connected to VIN and GND, since the nano rp 2040 connect does not have a JST battery connector. The red cable to VIN, and the black cable to GND. if the cable has a connector like this, this or this you will first need an adapter.
Thanks. But I need to have boost converter right because the input voltage of this board is 5 to 18 volts?
