Arduino OPTA - Error updating wifi firmware
I'm using IDE 2.xx with OPTA and i made a program to connect by wifi.
The PLC as reported 2 errors "AlPlcLoad failed " and "WiFiFirmwareUpdater". I try to upload firmware as recommended but the PLC flashes red LED after upload. Can any one please help me
!! AlPlcLoad failed
Ligado a Modulo Wifi do OPTA - CONNECTED TO WIFI MODULE
A ligar a Rede Wifi:TP-Link_9C05 - TRYING TO CONNECT TO WIFI NETWORK
File not found
Please run the "WiFiFirmwareUpdater" sketch once to install the WiFi firmware.
Code:
#include <Nicla_Vision_System.h>
#include <Portenta_System.h>
#include <STM32H747_System.h>
#include <Ethernet.h>
#include <Arduino_Portenta_OTA.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiSSLClient.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#include <AlPlc_Opta.h>
#include <Arduino_ConnectionHandler.h>
#include <ArduinoIoTCloud.h>
bool digital01;
bool digital02;
// definições de ligação a a rede WIFI.........................................................................
#define SECRET_SSID "TP-Link_9C05" //Rede WIFI de Ligação
#define SECRET_PASS "31005212"     //Pass de WIFI
const char ssid[] = SECRET_SSID;        // your network SSID (name)
const char pass[] = SECRET_PASS;        // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;
#if !(defined(BOARD_HAS_WIFI) || defined(BOARD_HAS_GSM) || defined(BOARD_HAS_LORA) || \
      defined(BOARD_HAS_NB) || defined(BOARD_HAS_ETHERNET) || defined(BOARD_HAS_CATM1_NBIOT))
  #error ".....ERRO CONTROLADOR NÃO SUPORTA IOT CLOUD....."
#endif
//.....................................definições para IOT Cloud.......................................
#if defined(BOARD_HAS_SECRET_KEY)
  #define BOARD_ID "424194e5-3185-4464-bb02-ee7a9dc13f48"
#endif
struct PLCSharedVarsInput_t
PLCSharedVarsInput_t& PLCIn = (PLCSharedVarsInput_t&)m_PLCSharedVarsInputBuf;
struct PLCSharedVarsOutput_t
	bool out_digital01;
	bool out_digital02;
PLCSharedVarsOutput_t& PLCOut = (PLCSharedVarsOutput_t&)m_PLCSharedVarsOutputBuf;
AlPlc AxelPLC(-1662570896);
// shared variables can be accessed with PLCIn.varname and PLCOut.varname
WiFiClient client;
  	AxelPLC.InitFileSystem();
	  AxelPLC.Run();
 // check for the WiFi module:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("Comunicação com modulo Wifi Impossivel");
    // Fica preso nesta rotina
    while (true);
  Serial.println("Ligado a Modulo Wifi do OPTA");
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("A ligar a Rede Wifi:");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 3 seconds for connection:
    delay(3000);
  Serial.println("Ligado a rede Wifi");
  pinMode(LED_D0, OUTPUT); //led para sinalizar entrada 1
    pinMode(LED_D1, OUTPUT); // led para sinalizar entrada 2
      pinMode(LED_D2, OUTPUT); // led para sinalizar ligacao a wifi
        pinMode(A0, INPUT); // Entrada I1 como input
          pinMode(A1, INPUT); // Entrada I2 como input
if (digitalRead(A0) == LOW) // entrada sensor sala 1 desligado
if (digitalRead(A1) == LOW) // entrada sensor sala 2 desligado
digitalWrite (LED_D0, HIGH); // liga led1
digitalWrite (LED_D1, HIGH); // liga led2
digitalWrite (LED_D0, LOW); //Desliga led2
digitalWrite (LED_D1, LOW); //desliga led2
delay (500);
if (digitalRead(A0) == HIGH) // se entrada sensor sala 1 ligado
  digitalWrite (LED_D0, HIGH); // liga led status 1
  PLCOut.out_digital01 = HIGH;
if (digitalRead(A1) == HIGH) // se entrada sensor sala 2 ligado
  digitalWrite (LED_D1, HIGH); // liga led status 2
Please do not post in "Uncategorized"; see the sticky topics in https://forum.arduino.cc/c/using-arduino/uncategorized/184.
Your topic has been moved to a more suitable location on the forum (the "Opta" category does sound sensible.
I don't have any idea about your problem so can't help but thanks for using code tags in your first post :+1:
Thanks in advance.
Hi @anon30835434 ,
Please double press the RESET button to put the board in bootloader mode, then follow the steps shown in the tutorial below. This will reconfigure the Opta and update the WiFiFirmware.
Likewise, you can also update the WiFiFirmware via the WiFiFirmwareUpdater sketch available in Arduino IDE > Examples > STM32H747_System.
Best,
I'm having a similar problem, I can't format the QSPI, Update WiFi Firmware, nor use wifi. I found this while trying to connect to Arduino Cloud; the debug info said the wifi firmware version was 0.0.0. I also tried memory partitioning but as with the previous codes it didn't work. I found that there was a similar error related to the Giga R1 on Cannot Reinstall WiFi Firmware on Arduino Giga R1 #650, I'm thinking these two might be related
