I was thinking, all that arduino power can do so much more than only counting and showing ...
I have some thoughts on the housing for the screen and zero buttons.
because the workshop is a dirty place, i'm going to put the LCD behind a piece off (acrylic)glass in a closed housing.
I want to put CNY 70 Vishay under the screen and also behind the glass, the idea is that when I put my finger on the glass the CNY 70 zeros the counts.
I'm not an electronic engineer so i don't have any idea if this works, someone an idea, or a better component that does the job even better?
I don't know for sure, but i seriously doubt that would work.
Reason is the sensor consists of an IR LED and an IR receiver.
That's a light source and you seem to be planning to have it light a spot on a reflective surface.
Maybe, if you put it right up against the glass, you might be able to get it to work, but as you can see the component housing has some edge and a reflective surface itself.
That will probably cause some interesting effects.
I almost forgot I still have to make the RPM code.
I used all the interupts for the DRO. I'm now wondering if the DRO leaves enough time (cycle-time) for reading and processing 2500RPM
and not miss any encoder pulses.
This code counts the number of pulses on pin5 during 1000ms, multiplying that by 60 gives me RPM.
I tried to get it integrated on my original code but it unfortunately i cant get it to work.
