I am new to arduino and I have starts posting my project based on arduino on arduino project hub.
I want to ask that can I post project not based on arduino on arduino project hub or not
Thanks on advance
Thanks on advance
I have deleted your other cross-post @krishna_agarwal.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please take some time to pick the forum category that best suits the subject of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide you will find at the top of every forum category. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation,
Per
Ok I got you could you pls response to my first topic
There is no rule against it:
https://create.arduino.cc/projecthub/guidelines
There is this you should be aware of:
the content you submit for publication goes through a manual moderation process
But even if they don't approve it, you will still be able to link people directly to it and it will also be published on hackster.io (Arduino Project Hub is based on hackster.io)
