I'm not sure if this is an issue with my wiring, or probably just an issue with my wiring!
When BOTH buttons are pressed together, the Arduino (Micro) resets! Pressing either button is OK, pressing 2 buttons and there's an issue.
Both pins are set to INPUT
I've created some buttons, but with a pull up resistor as it's ground which will be sent when the button is pressed.
I've attached a rather ... fritz - could somebody see what's wrong?
Sorry, It's been a late night. I took another look at the PCB I've soldered and Turns out I'd not counted... and was connected to Reset so there we go. Dumb!!!!
