Arduino Remote Trigger
This afternoon, I've made a project on my Arduino Uno. It is programmed to light a LED for each button I pressed on a remote control. I've used :
to make my project work! Below is the sketch for my project:
IRremote library download link >>>>>> http://www.dfrobot.com/image/data/DFR0107/IRremote.zip
#include <IRremote.h>                // use the library
int receiver = 8;                              // pin 1 of IR receiver to Arduino digital pin 8
IRrecv irrecv(receiver);                 // create instance of 'irrecv'
decode_results results;
int led1=2;
int led2=3;
int led3=4;
  Serial.begin(9600);                    // for serial monitor output
  irrecv.enableIRIn();                    // Start the receiver
  pinMode(led1,OUTPUT);
  pinMode(led2,OUTPUT);
  pinMode(led3,OUTPUT);
  if (irrecv.decode(&results))       // have we received an IR signal?
    Serial.println(results.value, HEX);  // display it on serial monitor in hexadecimal
    irrecv.resume();                                 // receive the next value
  }            // Your loop can do other things while waiting for an IR command
  //below is triggering mode
  //0x???? ????is the HEX code detected, must add 0x to trigger something
  switch(results.value){
    case 0x458:                   //1st push (UP Button Phillips)
    digitalWrite(led1,HIGH);
    case 0x10458:              //2nd push
    case 0x45A:                  //1st push (LEFT Button Phillips)
    digitalWrite(led2,HIGH);
    case 0x1045A:             //2nd push
    case 0x45B:                  //1st push (RIGHT Button Phillips)
    digitalWrite(led3,HIGH);
    case 0x1045B:             //2nd push
    case 0x45C:                 //1st push (OK Button Phillips)
    digitalWrite(led1,LOW);
    digitalWrite(led2,LOW);
    digitalWrite(led3,LOW);
    case 0x1045C:            //2nd push
    case 0x459:                 //1st push (DOWN Button Phillips)
    case 0x10459:            //2nd push
Wanna know how it works? Watch the video below!!!! Enjoy!
by Weng Fei
