This is a professional CAD-CAM and CNC software integrated into a single package that is easy to setup and use. This nicely integrated solution will provide you with all the tools that you need to make your creative design and control your
cnc machine. The CAD (Computer Aided Design) allows you to create simple or complex geometry using the mouse of by entering coordinates. You can also use a picture and transform it to a format that can be loaded and modified. The tutorial videos which shows you how to perform basic and advanced tasks can easily be found under the help menu. The CAM (Computer Aided Manufacturing) is fusion within the CAD. Using the mouse you easily defined the direction and sequence of machining. The CNC (Computer numerical Control) has everything you need to control your CNC and directly execute what was created with the CAD-CAM. The CNC machining is done by clicking one button. You easily switch from CAD-CAM view to CNC view with one mouse click. The CAD-CAM has a guide that shows you what to do next with clear and easy to understand instructions. The CNC provides a graphical and text description on every task that you perform. There is an extented list of pre- defined configuration files. You can select your CNC from that list to automatically configure or enter the configuration parameters manually. It includes an automatic installer for the latest GRBL 1.1f Arduino firmware and a guided setup for the CH340 driver.This combination of design and machine control makes it very easy to start using cnc mill, cnc laser, or cnc xy-plotter machine and make awesome things.
You advertise it for Mach3 and LinuxCNC, but it's actually windows-only, or did I miss a thing?
Yes the all in one CAD-CAM and CNC is for GRBL 1.1 f.
For Mach 3 it is the regular CAD-CAM.
The All in one combined the CAD-CAM and CNC in a single software,
I've attached a video link to show how it works.
