Arduino UNO and Nano CH340G Schematics
It's explained in the datasheet of every ATMega processor. In short, if you apply a voltage around 12V to the Reset pin, the chip enters a programming mode that's normally not accessible that allows for instance fuses to be reprogrammed that are normally write-once.
Yes. That's what I meant by saying "It's common to route them side by side."
Ok, thxx
Is GND included in the "power supply" category?
No, although more strictly speaking I should say 'it depends', but given your schematic, just go with 'no'. It's OK to route such lines close to GND.
What will happen if my USB DATA- is a little longer than the USB DATA+
My DATA+ length is 9.325mm (BottomLayer)-Via Diameter (1mm) Hole (0.5mm)- 2.121mm (TopLayer)
My DATA- length is 13.419mm (BottomLayer)-Via Diameter (1mm) Hole (0.5mm)- 2.398mm (TopLayer)
There may be transfer errors and/or a failure of the USB chip to be recognized correctly & consistently.
You can introduce some angles in the shorter trace (DATA+) in order to make it longer.
Btw, usually there is no impact of such a small length difference, but when laying out a new PCB, there's no need to take the risk, IMO.
Okayy
Now:
My DATA+ length is 13.424mm (BottomLayer)-Via Diameter (1mm) Hole (0.5mm)- 2.121mm (TopLayer)
I can't make it closer than that...
Will that be gud?
I don't think it gets any better than that!
So its still bad?
Oh ok, now it can be the same length (13.418mm)
What's the most common diode to do this job?
I often see a diode near the icsp headers
but no markings there..
Just black background with a white strip to indicate the cathode
If I power my board only using 9v-jack and USB, do I still need to add the diode?
Any small signal diode will do. I often use MBR0520, but 1n4148 for instance would do just fine as well.
Doesn't matter where the power comes from.
The point is, that I won't use any 12v input
I'll say it again...
Screenshot (177)
Can I do that with a Digital Pin's Net?
(Combine 2 tracks to one just like on the pic)
If they're the same net, yes.
