Arduino Uno as HDI/keyboard --> How is this component called?
Hello pros,
I was experimenting with the arduino as a keyboard. As I had many problems with the leonardo I aslo used the spparkfun pro micro which also caused many problems.
Now I found a workaround in
http://www.practicalarduino.com/projects/virtual-usb-keyboard
As I am afraid of making errors whith soldering I just wanted to know,if I can buy the component shown in
I also attached a picture.
Could anybody tell me how this component is called?
Many Thanks
Mario
Mario,
The jpg you attached is just a blank shield attached on top of an Arduino UNO. The author then use the shield to prototype the V-USB circuit.
I have some experience with V-USB on the Atmega328P chips. The library referenced is by Rancid Bacon and will NOT work without major changes on versions of the IDE > 1.0.6 so download and install 1.0.6 from here:
Previous Versions IDE
here are some of my references:
String Numeric Output
HID-serial
Pictures
V-USB & Excel
A/D Port Viewer using V-USB
Trinket Clone
Parts List
The 3.6 Zener diode is a critical component.
V-USB reference pages: V-USB - A Firmware-Only USB Driver for Atmel AVR Microcontrollers
Good luck!
Ray
My Projects
Added:
I've even gotten V-USB to work on a cheap tablet using the USB port with an OTG cable:
Flicker higher-resolution pixs:
Flickr 1
Flickr 2
What kind of problems did you have with the leonardo? Because leonardo works as HID easily thanks to atmega32u4
