Arduino UNO (ATMega328p) [osoyoo] - Can't connect via COM3 - Port is greyed out
-Windows 10 Home
-osoyoo Arduino UNO (chip ATMega328p)
-I have never been able to upload to this board
-In the Arduino IDE I get this message when I try to upload to the board:
C:\Users\ENDER\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\ENDER\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\ENDER\AppData\Local\Temp\arduino_build_24225/lesson1.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\ENDER\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
An error occurred while uploading the sketch
avrdude: ser_open(): can't open device "\\.\COM3": The system cannot find the file specified.
avrdude done.  Thank you.
My preferences.txt file used by the Arduino IDE:
board=uno
boardsmanager.additional.urls=
build.verbose=true
build.warn_data_percentage=75
cache.enable=true
compiler.cache_core=true
compiler.warning_level=all
console=true
console.auto_clear=true
console.error.file=stderr.txt
console.length=500
console.lines=4
console.output.file=stdout.txt
custom_cpu=diecimila_atmega328
editor.antialias=true
editor.auto_close_braces=true
editor.caret.blink=true
editor.code_folding=false
editor.divider.size=2
editor.external=false
editor.font=Monospaced,plain,12
editor.indent=true
editor.invalid=false
editor.keys.alternative_cut_copy_paste=true
editor.keys.home_and_end_beginning_end_of_doc=false
editor.keys.shift_backspace_is_delete=true
editor.languages.current=
editor.linenumbers=true
editor.save_on_verify=true
editor.tabs.expand=true
editor.tabs.size=2
editor.update_extension=true
editor.window.height.default=600
editor.window.height.min=290
editor.window.width.default=500
editor.window.width.min=400
export.applet.separate_jar_files=false
export.application.fullscreen=false
export.application.platform=true
export.application.stop=true
export.delete_target_folder=true
gui.scale=auto
last.folder=C:\Users\ENDER\Desktop\Tom Stuff\lesson1\lesson1\lesson1.ino
last.ide.1.8.11.daterun=1581485273
last.ide.1.8.11.hardwarepath=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.29.0_x86__mdqgnx93n4wtt\hardware
last.ide.1.8.12.daterun=1583004799
last.ide.1.8.12.hardwarepath=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.33.0_x86__mdqgnx93n4wtt\hardware
last.ide.1.8.9.daterun=1580167744
last.ide.1.8.9.hardwarepath=C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware
last.screen.height=900
last.screen.width=1600
last.serial.location=241,156,873,379
last.sketch.count=1
last.sketch.default.location=-8,-8,1616,884,224,6
last.sketch.default.path=C:\Users\ENDER\Desktop\Tom Stuff\lesson1\lesson1\lesson1.ino
last.sketch0.location=-8,-8,1616,884,224,6
last.sketch0.path=C:\Users\ENDER\Desktop\Tom Stuff\lesson1\lesson1\lesson1.ino
last.sketch1.location=-8,-8,1616,884,698,6
last.sketch1.path=C:\Users\ENDER\Desktop\Tom Stuff\sketches\ir_recv_send\ir_recv_send.ino
platform.auto_file_type_associations=true
preferences.readonly=false
preproc.color_datatype=true
preproc.enhanced_casting=true
preproc.imports.list=java.applet.*,java.awt.Dimension,java.awt.Frame,java.awt.event.MouseEvent,java.awt.event.KeyEvent,java.awt.event.FocusEvent,java.awt.Image,java.io.*,java.net.*,java.text.*,java.util.*,java.util.zip.*,java.util.regex.*
preproc.output_parse_tree=false
preproc.save_build_files=false
preproc.substitute_floats=true
preproc.substitute_unicode=true
preproc.web_colors=true
programmer=arduino:arduinoasispatmega32u4
proxy.manual.hostname=
proxy.manual.password=
proxy.manual.port=
proxy.manual.type=HTTP
proxy.manual.username=
proxy.pac.url=
proxy.type=auto
recent.sketches=C:\Users\ENDER\Desktop\Tom Stuff\lesson1\lesson1\lesson1.ino,C:\Users\ENDER\Desktop\lesson1\lesson1.ino,C:\Users\ENDER\Desktop\Tom Stuff\sketches\ir_recv_send\ir_recv_send.ino
run.display=1
run.options=
run.options.memory=false
run.options.memory.initial=64
run.options.memory.maximum=256
run.present.bgcolor=#666666
run.present.exclusive=false
run.present.stop.color=#cccccc
serial.databits=8
serial.debug_rate=9600
serial.line_ending=1
serial.parity=N
serial.port=COM3
serial.port.file=COM3
serial.port.iserial=953363336353515051D0
serial.show_timestamp=true
serial.stopbits=1
sketchbook.path=C:\Users\ENDER\Desktop\Tom Stuff\sketches
software=ARDUINO
target_package=arduino
target_platform=avr
theme.file=
update.check=true
update.id=-3391150697713786459
update.last=1583004811069
upload.using=bootloader
upload.verbose=true
upload.verify=true
I've tried to update / delete and reinstall the driver for the board ( I will admit, I am not sure which driver is the right one for my board) but I have never gotten this to work right.)
@knowltonArduino's deviceman.png:
Does the "AT91 Usb to Serial Converter" item disappear from Device Manager when you unplug the Uno from your computer?
is it missing a CH340 driver?
http://www.wch.cn/download/CH341SER_ZIP.html (mod edit)
Click on the blue box in the top CH341SER.ZIP section to download.
It looks a suspect site but this is the official site for that driver and it's the one that I've been using without problems.
Peter
